Identify 9 pin connector of pulse Pulse-Eight NUC CEC Adapter
I have bought n Pulse-Eight NUC CEC Adapter,
supposedly with cable for 4th gen: 4th Gen cable harness for NUC HDMI-CEC Adapter : Pulse-Eight
but unfortunately came with cable for 6th gen:
6th/7th/8th Gen cable harness for NUC HDMI-CEC Adapter : Pulse-Eight
Does anyone knows the name of the black 9 pin connector (5+4) on this cable?
If i could buy one, then i could connect some jumper cables to it and would solve my issue.
Both of the black connectors in the 2 links look like standard 2.54mm (0.1in) pitch connectors. If that's the case then you are looking for a plastic 2x5 crimp socket housing.
Possibly like this one:
I just compared an individual female jumper cable (2.54mm) and seems much wider then then each of this female holes in the black socket housing.
Actually i tried to connect individual jumper cables to the pins on the chip, and its not possible to connect 2 together, there not enough spacing between the pins, so i would say i need something smaller then 2.54mm, probably 2mm.
I measured the 9pin socket connector and it has 10mm of width and 4mm height, so most likely its 2mm pitch
Probably this one?:
I would measure the distance between actual pins - measure distance across a whole row of pins and divide down to get the actual pin spacing.
And divide the total distance by the number of pin spaces, or the total number of pins less one.
Tom... :smiley: :+1: :coffee: :australia:
