I have a solar charger (BatteryMinder brand) that we adopted to use for an arduino project.
Despite their claims, the thing was not weather resistant & the board lasted a short time. Well; some of the components lasted a short time. Rust was not our friend.
10 resistors & 2 diodes were rusted thru at one end. The resistors are easy to identify (except 1 is about 2x as thick as the rest); but two diodes look like standard 14n148 type diodes (one is a bit bigger). They will not provide me any support or schematics; so I am on my own to fix it.
There were a couple other diodes on the board that looked healthy and similar sizes; so I unsoldered them to test them with a transistor/component tester. One tested out as a good diode with uf=789 and IR=4na; the other tested with uf=704, IR=10uA -- note that I was able to test the 1st one repeatidly and got similar results; the 2nd one now fails as a diode and is sub 1.5 ohm in one direction and .6ohm the other... (so now I actually have 3 diodes I need to identify).
Is there a way to know / guess what diode would work w/o schematic? are their markings that I just can't see w/o proper magnification? IOW: is there a way I can replace these diodes ?
My camera has dead batteries, but I'll go buy some if pictures will help...
Thanks
