If LED is already on Serial Monitor must display "LED is already on"
I want to turn LED ON/OFF through serial monitor by sending 1,0 Respectively. If LED is already OFF and i send "0" Serial Monitor must reply "LED is already OFF" same in the case of LED ON. here's my Code.
int led = 13;
int x;
int y;
int s;
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
  Serial.println("READY");
  if (Serial.available() > 0) {
    x = Serial.read();
    y = digitalRead(led);
    if (x == '1') {
      digitalWrite(led, HIGH);
      Serial.println("LED is ON");
      delay(10);
    if (x == '0') {
      Serial.println("LED is OFF");
      delay(10);
    if (x == 's') {
      Serial.println(y);
Do you think "&&" might be part of your answer?
Or maybe just a simple "else"?
why can't you turn off the led in void setup:
int pin = 13;
int pin_state = 0;
void setup(){
digitalWrite(pin, pin_state);
Serial.println("--Ready--");
void loop(){
if(Serial.available() > 0){
if(Serial.read() == '1'){
pin_state = 1;
}else{
pin_state = 0;
delay(10);
