safa1
1
In setup: I turn 40 into binary.
In Loop I want to blink led but led doesn't blink.
int arr[20];
int dec = 40;
int i = 0, ArrLen;
if(dec > 0)
while(dec > 0)
arr[i] = dec % 2;
i++;
dec = dec / 2;
for(byte i = 0; i < 7; i++){
if(arr[i]>0){digitalWrite(D0,HIGH);}
else {digitalWrite(D0,LOW);}
Serial.print(arr[i]);
delay(50);
Serial.println("");
delay(5000);
Did you forget to do something to D0 in setup?
(NB: this is NOT an installation issue)
@safa1
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
blh64
5
That if statement is not necessary. You will get the same result with or without it.
system
Closed
6
