My name is Tom and im new to the arduino stuff. I really like it and i'm using to build a counter for school.
I'm building this with two ir distance sensors. I can run the code and open up the terminal window and seeing 0 shooting past.
When i move my hand in front of the sensor it will be all 1's, so far so good. Now i want to combine this setup with 2 led's.
1 green led and 1 red one. If the counter is below four the green light will stay on, if it's 4 the red light will come up. The second sensor will count down. So it is a 2-way counter for people. If someone goes in a room it will be + and if he leaves it will be -.
pinMode(13, OUTPUT);
pinMode(10, OUTPUT);
int sensorValue = analogRead(A0);
int sensorValue2 = analogRead(A2);
int totaal[0];
if ( sensorValue < 100 )
totaal[0] ++;
delay(2000);
if ( totaal[0] = 4 )
digitalWrite(13, HIGH);
Serial.println("test")
Serial.println(totaal[0],DEC);
Now i only put the red light in but the problem i have is that it just starts red immediately after starting up the arduino. Maybe the if statement counts the lines in terminal, i dont know excactly. Do you guys have some advice for coding this if statement with the value of the count = max 4
I did put text in the if and it just started to put in the text from the start in, am i missing something ?
Thanks in advance
It actually works if i use my old code, it stores the number in the array. If it passes it again it will increase with 1 ( ++ )
Ah ok i changed it to ==, removed the else ( it does nothing indeed )
But totaal[0] does not have to be reset to 0, it just has to stay at 4 until someone leaves the room. Than it will go 3 2 1.
It's like traffic light for a room.
If i run it now i'll get -15872 in my terminal, it will count up but i need it to start at zero.
if i put that code in it , the value will start at 15872, i changed the
if ( totaal[0] == 4 )
to
if ( totaal[0] == -15870 )
that worked, it started spit out test when it counted to -15870.
Now i only need it to start at 0.
Ok i read comment #2, ye i understand it says 0 elements but the terminal window will count 1,2,3,4,5 etc, so thats strange
Your variable is declared inside loop, so it goes out of scope at the end of loop. It is also never initialized. Global variables and static variables ARE initialized, by the compiler, to 0. Heap variables, declared in a function, are not.
Ok, ye that makes sense. Im also a bit new to c so i appreciate the help. I now declared totaal[1] out of the loop ( i put it just above void loop(). If i run the program it will count up really fast without moving my hand in front of the sensor.
ok, i replaced it by an int, it now works !
I was using the array because that was working, i tried the int but i didn't placed it outside the loop i guess. Thanks for the useful info about arrays
I will work on the 2nd sensor and see how that goes. Again thanks for the fast responses.
