I'm a fairly new Arduino user, and I need help figuring things out!
I haven't used arduino that much, but since I've started, I've received countless error messages, even when I'm using pre-provided code. What could I be doing wrong?
You are making the same error that many beginners make. You assume the members of this forum have psychic superpowers.
Welcome to the forum.
Your wrong is : not following the forum rules. Read
You’re right; there are thousands of possible errors, but you’re likely encountering only a handful. Writing a manual for every possible error and permutation isn’t practical. To get accurate help, please provide detailed information about your setup, as @ruilviana and others have requested. Many of us prefer an annotated schematic over Fritzing diagrams or pictures.
If your IDE is installed correctly AND your sketch is in a folder of the same name, then the next probable error possibly is you have not installed the correct libraries from the #include line(s)
Run some of the examples in the ide.
And get those to work ?
File /examples/basic
Here is a tutorial how to adjust the Arduino-IDE to report all possible details about the compiler-errors
