That part http://rocky.digikey.com/WebLib/ECS/Web%20Data/ECS-100%20Series.pdf
needs power & gnd connnected.
Connect its output to XTAL1 (datasheet 9.8 ).
Change the clock bits to 0000 in the Low fuse byte (datasheet 9.2 and Table 28-9), and burn the bootloader to set them.
CrossRoads:
Thanks for responding.
I'm not sure which datasheet you're referring to. I've checked the one for ATMega and the data sheet I posted and there was no mention of Table 28-9.
Also, I've never worked with a crystal oscillator before. Is its only job to generate a (roughly) square pulse at the housing-specified frequency? How do I set the "clock bits"?
"Is its only job to generate a (roughly) square pulse at the housing-specified frequency?"
I'm sure it will be much better than roughly - it will be a very sharp, crisp, 0-5V, 50% duty cycle square wave.
