const int swPin = 12;
const int VrxPin = A5;
const int VryPin = A0;
// Set the initial variable values
int xDirection = 0;
int yDirection = 0;
int switchState = 1;
pinMode(swPin, INPUT);
// The joystick button is always HIGH, unless the button is pressed
digitalWrite(swPin, HIGH);
// Read the analog joystick values
xDirection = analogRead(VryPin);
yDirection = analogRead(VrxPin);
// Read the push button state
switchState = digitalRead(swPin);
// Print the values read to the serial monitor
Serial.print("Switch: ");
Serial.println(switchState);
Serial.print("X-axis: ");
Serial.println(xDirection);
Serial.print("Y-axis: ");
Serial.println(yDirection);
Serial.println("");
// Because the switch is HIGH when it is NOT pressed we have to invert the read values
// We use the exclamation mark in front of the variable name which converts HIGH in LOW and vice versa
if (!switchState) {
Serial.println("Switch pressed");
// We do not exacty use 512 as the center of the joystick position, since the analogue value can
// fluctuate. The center is approx. 500, therefore we use a margin of 20.
// Determine the joystick direction on the X-axis
if (xDirection < 480) {
Serial.println("Left");
} else if (xDirection > 520) {
Serial.println("Right");
// Determine the joystick direction on the Y-axis
if (yDirection < 480) {
Serial.println("Down");
} else if (yDirection > 520) {
Serial.println("Up");
Code above is just missing a } to end loop
Then the original post seems to duplicate the code again, this with the ending } included:
int xDirection = 0;
int yDirection = 0;
Serial.println("");
if (!switchState) {
(Code broken up by Moderator)
