i keep getting this error messege Error compiling for board Adafruit Trinket (ATtiny85 @ 16MHz). im new to arduino but it been programing for 2 years this code is for a robot using the adafruit trinket 3v at 16mhz connected to 2 servos and an hm-10 bt component i keep gettng this error over and over again and im not sure whats wrong.
#include <SoftwareSerial.h>
#include <Servo.h>
///1001
///2002
///3003
///4004
///5005
///6006
///7007 back to original
const int x=1;
const int y=2;
Servo Servo1;
Servo Servo2;
SoftwareSerial BTSerial(x,y); //RX|TX
void setup(){
BTSerial.begin(9600); // default baud rate
int servoPin = 3;
int servoPin2 = 4;
// Create a servo object
Servo1.attach(servoPin);
Servo2.attach(servoPin2);
int x = 1001;
void loop(){
//read from the HM-10 and print in the Serial
if(BTSerial.available()== x)
Servo1.write(0);
Servo2.write(0);
Servo2.write(180);
Servo2.write(0);
if(BTSerial.available()== x * 7)
Servo1.write(0);
heres the error
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp: In function 'void __vector_3()':
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp:82:44: error: cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'volatile uint16_t* {aka volatile unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'
handle_interrupts(_timer1, &TCNT1, &OCR1A);
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp: In function 'void initISR(timer16_Sequence_t)':
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp:129:5: error: 'TCCR1B' was not declared in this scope
TCCR1B = _BV(CS11); // set prescaler of 8
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp:136:5: error: 'TIFR1' was not declared in this scope
TIFR1 |= _BV(OCF1A); // clear any pending interrupts;
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr\Servo.cpp:137:5: error: 'TIMSK1' was not declared in this scope
TIMSK1 |= _BV(OCIE1A) ; // enable the output compare interrupt
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Using library Servo at version 1.1.2 in folder: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
