i´m trying to read a bmp image from SD card and draw it on my ST7796 display but with no luck. I only get this here: (Video) VID_20250317_123734.mp4 - Google Drive
I´m using a Arduino Uno R3. This is the display: 4 Inch LCD TFT Touch Display Binghe 4 Inch LCD Display Touch Module with Touch Pen 320 x 480 Resolution Driver ST7796S 4-Wire SPI Compatible with Arduino: Amazon.de: Computer & Accessories
I´m using the Adafruit_ST7796S GFX libary. When i run the ST7796S_demo.ino evertyhings works well. But when i use the Ardafruit ImageReader example (please see code below) i get the result you can see in the video. And i don´t know why. I tried also different bmp images, but always the same.
// Adafruit_ImageReader test for Adafruit ST7789 320x240 TFT Breakout for Arduino.
// Demonstrates loading images to the screen, to RAM, and how to query
// image file dimensions.
// Requires three BMP files in root directory of SD card:
// parrot.bmp, miniwoof.bmp and wales.bmp.
// As written, this uses the microcontroller's SPI interface for the screen
// (not 'bitbang') and must be wired to specific pins (e.g. for Arduino Uno,
// MOSI = pin 11, MISO = 12, SCK = 13). Other pins are configurable below.
#include <Adafruit_GFX.h> // Core graphics library
//#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SdFat.h> // SD card & FAT filesystem library
#include <Adafruit_SPIFlash.h> // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
#include <Adafruit_ST7796S.h>
// Comment out the next line to load from SPI/QSPI flash instead of SD card:
#define USE_SD_CARD
// TFT display and SD card share the hardware SPI interface, using
// 'select' pins for each to identify the active device on the bus.
#define SD_CS 10 // SD card select pin
#define TFT_CS 9 // TFT select pin
#define TFT_DC A3 // TFT display/command pin
#define TFT_RST A4 // Or set to -1 and connect to Arduino RESET pin
#if defined(USE_SD_CARD)
SdFat SD; // SD card filesystem
Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
#else
// SPI or QSPI flash filesystem (i.e. CIRCUITPY drive)
#if defined(__SAMD51__) || defined(NRF52840_XXAA)
Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS,
PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
#else
#if (SPI_INTERFACES_COUNT == 1)
Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
#else
Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
#endif
#endif
Adafruit_SPIFlash flash(&flashTransport);
FatVolume filesys;
Adafruit_ImageReader reader(filesys); // Image-reader, pass in flash filesys
#endif
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
Adafruit_ST7796S tft =Adafruit_ST7796S(TFT_CS, TFT_DC, TFT_RST);
Adafruit_Image img; // An image loaded into RAM
int32_t width = 0, // BMP image dimensions
height = 0;
void setup(void) {
analogWrite(A0,150);
ImageReturnCode stat; // Status from image-reading functions
#if !defined(ESP32)
while(!Serial); // Wait for Serial Monitor before continuing
#endif
tft.init(320, 480, 0, 0, ST7796S_RGB);
//tft.init(320, 480); // Init ST7789 320x240
// The Adafruit_ImageReader constructor call (above, before setup())
// accepts an uninitialized SdFat or FatVolume object. This MUST
// BE INITIALIZED before using any of the image reader functions!
Serial.print(F("Initializing filesystem..."));
// SD card is pretty straightforward, a single call...
if(!SD.begin(SD_CS, SD_SCK_MHZ(10))) { // Breakouts require 10 MHz limit due to longer wires
Serial.println(F("SD begin() failed"));
for(;;); // Fatal error, do not continue
#else
// SPI or QSPI flash requires two steps, one to access the bare flash
// memory itself, then the second to access the filesystem within...
if(!flash.begin()) {
Serial.println(F("flash begin() failed"));
for(;;);
if(!filesys.begin(&flash)) {
Serial.println(F("filesys begin() failed"));
for(;;);
#endif
Serial.println(F("OK!"));
// Fill screen blue. Not a required step, this just shows that we're
// successfully communicating with the screen.
tft.fillScreen(ST77XX_BLUE);
// Load full-screen BMP file 'purple.bmp' at position (0,0) (top left).
// Notice the 'reader' object performs this, with 'tft' as an argument.
Serial.print(F("Loading purple.bmp to screen..."));
stat = reader.drawBMP("/01.bmp", tft, 0, 0);
reader.printStatus(stat); // How'd we do?
// Query the dimensions of image 'miniwoof.bmp' WITHOUT loading to screen:
Serial.print(F("Querying miniwoof.bmp image size..."));
stat = reader.bmpDimensions("/02.bmp", &width, &height);
if(stat == IMAGE_SUCCESS) { // If it worked, print image size...
Serial.print(F("Image dimensions: "));
Serial.print(width);
Serial.write('x');
Serial.println(height);
// Load small BMP 'wales.bmp' into a GFX canvas in RAM. This should fail
// gracefully on Arduino Uno and other small devices, meaning the image
// will not load, but this won't make the program stop or crash, it just
// continues on without it. Should work on Arduino Mega, Zero, etc.
Serial.print(F("Loading wales.bmp to canvas..."));
stat = reader.loadBMP("/03.bmp", img);
delay(2000); // Pause 2 seconds before moving on to loop()
/* //for(int r=0; r<4; r++) { // For each of 4 rotations...
tft.setRotation(0); // Set rotation
tft.fillScreen(0); // and clear screen
// Load 4 copies of the 'miniwoof.bmp' image to the screen, some
// partially off screen edges to demonstrate clipping. Globals
// 'width' and 'height' were set by bmpDimensions() call in setup().
for(int i=0; i<4; i++) {
reader.drawBMP("/miniwoof.bmp", tft,
(tft.width() * i / 3) - (width / 2),
(tft.height() * i / 3) - (height / 2));
delay(1000); // Pause 1 sec.
// Draw 50 Welsh dragon flags in random positions. This has no effect
// on memory-constrained boards like the Arduino Uno, where the image
// failed to load due to insufficient RAM, but it's NOT fatal.
for(int i=0; i<50; i++) {
// Rather than reader.drawBMP() (which works from SD card),
// a different function is used for RAM-resident images:
img.draw(tft, // Pass in tft object
(int16_t)random(-img.width() , tft.width()) , // Horiz pos.
(int16_t)random(-img.height(), tft.height())); // Vert pos
// Reiterating a prior point: img.draw() does nothing and returns
// if the image failed to load. It's unfortunate but not disastrous.
reader.drawBMP("/03.bmp", tft, 0, 0);
delay(2000); // Pause 2 sec.
