URGENT HELP NEEDED - bmpDraw Function is not working for my 13" SPI 240x240 TFT ST7789V2 + SDCard Module + Arduino Pro Mini 3.3V logic
Hello, I am using 3.3V logic Arduino pro mini(8MHz) to display a bitmap image on my display. Simple test code is working just fine without the SD module. But when the SD module and SDCard attached with a 97x97 pixel bitmap image inside, it is not displaying the image on the screen. Serial Monitor says it's loaded but it is only initializing the screen and filling the screen with blue color as written in the void setup(void). The bmpDraw function is not working I think. Could you please help me out :frowning:
display: MDT0130A3IH-SPI.pdf (1.3 MB)
Serial Monitor Output:
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h> // include Adafruit ST7789 display library
#include <SPI.h>             // include Arduino SPI library
#include <SD.h>              // include Arduino SD library
// define ST7789 TFT display connections
#define TFT_CS        10
#define TFT_RST        9
#define TFT_DC         8
#define TFT_MOSI 11  // Data out
#define TFT_SCLK 13  // Clock out
#define button   2  // button pin
//// initialize Adafruit ST7789 TFT library
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
void setup(void) {
  pinMode(TFT_CS, OUTPUT);
  digitalWrite(TFT_CS, HIGH);
  pinMode(button, INPUT_PULLUP);
  // initialize ST7735S TFT display
  tft.init(240,240);
  tft.setRotation(0);
  tft.fillScreen(ST77XX_BLUE);
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("failed!");
    while(1);  // stay here
  Serial.println("OK!");
  File root = SD.open("/");  // open SD card main root
  printDirectory(root, 0);   // print all files names and sizes
  root.close();              // close the opened root
  while (true) {
    File entry =  root.openNextFile();  // open file
    if (! entry) {
      // no more files
      root.close();
      return;
    uint8_t nameSize = String(entry.name()).length();  // get file name size
    String str1 = String(entry.name()).substring( nameSize - 4 );  // save the last 4 characters (file extension)
    if ( str1.equalsIgnoreCase(".bmp") ){  // if the file has '.bmp' extension
      bmpDraw(entry.name(), 0, 0);        // draw it
    entry.close();  // close the file
    while( digitalRead(button) ) ;  // wait for button press
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; //Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.startWrite();
        tft.setAddrWindow(x, y, w, h);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            tft.endWrite();
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              Serial.print(F("bmpFile.read: ")); Serial.println(bmpFile.read(sdbuffer, sizeof(sdbuffer)));
              buffidx = 0; // Set index to beginning
              tft.startWrite();
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.color565(r,g,b));
          } // end pixel
        } // end scanline
        tft.endWrite();
        Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
 bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
void printDirectory(File dir, int numTabs) {
  while (true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
    for (uint8_t i = 0; i < numTabs; i++) {
      Serial.print('\t');
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println("/");
      printDirectory(entry, numTabs + 1);
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.println(entry.size(), DEC);
    entry.close();
And here is my connection. Well I changed the arduino uno to pro mini and change the level shifter connections of course but the logic is the same.
It looks like a memory problem.
Your program already looks too voluminous for a Pro mini board, and you also added SD module, that itself required a big memory buffer.
What's the memory using message gives you an Arduino IDE after compilation?
Is it before or after the adding the SD code?
Sorry, just updated the screenshot. There was an issue with the programmer and it didn't uploaded the program. Needed to reboot and everything is okay now and the used memory sized changed to %79.
Those particular micro SD card modules normally need modifying if there is another SPI device on the bus, such as the display.
Here is my SPI connections but of course there is a level shifter in between SDModule and Display since their logic level is different. What kind of modification do you mean? Can you give more details please? There are lots of examples out there using same same connection setup for the SPI bus and they appear to be working :confused:
https://www.youtube.com/watch?v=iqqFn2jn3p8
And discussed here;
Easier to get an SD card module that works properly with other SPI devices.
An SPI device is supposed to release the MISO line if its CS is not asserted - so that another device can use it. But your microSD module probably runs MISO through the level shifter, so it's always asserted. Here's a schematic showing what needs to be changed:
And here's a picture of the mod. You cut one trace and add one wire.
Alternatively, you can get the Adafruit microSD module, which does things correctly.
Thanks guys! I wasn’t aware of that! I’ll try fixing my sdCard module and let you know the results :pray::pray::pray:
FWIW SD cards seem to tri State the MISO internally. So if you stay with 3.3 volts you can get an SD card with no electronics, only the pinout.
Okay I modified the SD module as in the video. But result is still the same. :confused:
I also bought the Adafruit microSD module. But I suppose I will see the same result again since the modification didn't work :frowning:
Does the SD card work by itself without the display connected? You could run the CardInfo example in the SD library and see if it works.
Yes, it is working. After the modification it is still not allowing display to use SPI bus. I have this below code to just display the image from a c-array data. Without the SD card code entry it is loading the image on the display. As soon as I add the SDcard sections, only SDCard module is working display is not showing the picture.
Displaying image from c-array data without SDCard initialization - working fine
//Checked with evive / Arduino Mega
//Compatible with SPI based TFT (user can modify TFT codes and library)
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library
#define TFT_CS        10
#define TFT_RST        9
#define TFT_DC         8
const uint16_t wifi_icon [] PROGMEM = {0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x31a6, 0x31a6, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x2124, 0x2124, 0x2124, 0x2965, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3185, 0x3185, 0x3185, 0x3185, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2945, 0x5acb, 0x8c71, 0x9cf3, 0x8410, 0x4208, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3186, 0x31a7, 0x29a8, 0x29ca, 0x29cb, 0x29eb, 0x29eb, 0x29cb, 0x29c9, 0x29a8, 0x31a7, 0x3185, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x2965, 0x9cf3, 0xffff, 0xffff, 0xffff, 0xffff, 0xef5d, 0x6b6d, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3186, 0x29c9, 0x21ed, 0x2230, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a31, 0x220f, 0x21ec, 0x29a8, 0x3186, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0x8c71, 0xffff, 0xffff, 0xffdf, 0xffff, 0xffdf, 0xffff, 0xffdf, 0x528a, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x31a7, 0x21ec, 0x1a31, 0x1a53, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x1a53, 0x2230, 0x29cb, 0x3186, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2965, 0x39c7, 0xef5d, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xad75, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3187, 0x21ed, 0x1a52, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x1a31, 0x29eb, 0x3186, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x52aa, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6ba, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29ca, 0x1a32, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x2230, 0x29a8, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x528a, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd69a, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3186, 0x220e, 0x1a53, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x29eb, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0xdefb, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0x9cf3, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x31a7, 0x2230, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x220e, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2945, 0x6b6d, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xe71c, 0x39e7, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x31a7, 0x1a31, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x220f, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x73ae, 0xe71c, 0xffff, 0xffff, 0xffff, 0xc638, 0x4a69, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x31a7, 0x1a31, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x220e, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2124, 0x2945, 0x5acb, 0x738e, 0x4228, 0x2104, 0x2965, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x220f, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x21ec, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2965, 0x3186, 0x8c51, 0xad75, 0xb596, 0xad75, 0x6b6d, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a73, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a33, 0x1a33, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0xce59, 0xb5b6, 0x632c, 0x52aa, 0x73ae, 0xdedb, 0x94b2, 0x2124, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29c9, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1a53, 0x1232, 0x11f2, 0x09f2, 0x1212, 0x1a53, 0x2273, 0x2273, 0x2273, 0x2273, 0x1a53, 0x1212, 0x09f2, 0x1212, 0x1a33, 0x1a73, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a31, 0x3187, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0xb596, 0xa534, 0x18e3, 0x2124, 0x2945, 0x2104, 0x3186, 0xdedb, 0x738e, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2230, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a73, 0x1232, 0x09f2, 0x1232, 0x32f4, 0x6437, 0x9d7a, 0xb63b, 0xd6dd, 0xe73e, 0xef7e, 0xef7e, 0xdf3e, 0xcebd, 0xb61b, 0x8d19, 0x5bf6, 0x2ab4, 0x1212, 0x09f2, 0x1a33, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x21ed, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2965, 0x4a49, 0xd69a, 0x3186, 0x3186, 0x31a6, 0x31a6, 0x31a6, 0x2104, 0x6b4d, 0xc618, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29cb, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1232, 0x09f2, 0x2ad4, 0x7cb8, 0xc69c, 0xf7df, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xef7e, 0xb61b, 0x6437, 0x2273, 0x09f2, 0x1a53, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29a8, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2124, 0x6b4d, 0xb5b6, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x2965, 0x4228, 0xc638, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a31, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x09f2, 0x32f4, 0x9d7a, 0xef9e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xdf1d, 0x7cb8, 0x2273, 0x11f2, 0x1a73, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x220e, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x52aa, 0xc638, 0x2945, 0x31a6, 0x3186, 0x3186, 0x31a6, 0x2945, 0x52aa, 0xc638, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29ca, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1212, 0x1a53, 0x84d8, 0xef9e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xdf1d, 0x5bf6, 0x1212, 0x1a33, 0x1a73, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x31a7, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x2965, 0xce79, 0x6b6d, 0x18c3, 0x31a6, 0x31a6, 0x3186, 0x18c3, 0xb596, 0x94b2, 0x2104, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220e, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x09f2, 0x3b14, 0xcebc, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xa5ba, 0x2273, 0x1212, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x29eb, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2945, 0x5aeb, 0xdefb, 0x738e, 0x3186, 0x3186, 0x39c7, 0xa514, 0xce59, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x31a7, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x09f2, 0x5bd6, 0xef9e, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xd6fd, 0xbe3b, 0xa5ba, 0x9d9a, 0x9d9a, 0xaddb, 0xbe5c, 0xdf3d, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6dd, 0x3af4, 0x09f2, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x5acb, 0xc618, 0xbdf7, 0xb5b6, 0xce79, 0xad75, 0x39c7, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29c9, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1232, 0x7498, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xbe3b, 0x7478, 0x3b35, 0x2293, 0x1212, 0x09f2, 0x09f2, 0x09f2, 0x09f2, 0x1232, 0x2a93, 0x4355, 0x84d8, 0xcebd, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xe75e, 0x4b75, 0x1212, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a32, 0x31a7, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2124, 0x18c3, 0x528a, 0x632c, 0x4208, 0x10a2, 0x3186, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ec, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1212, 0xb61b, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xa5ba, 0x4335, 0x1232, 0x09f2, 0x09d2, 0x09f2, 0x1232, 0x1a53, 0x2273, 0x1a73, 0x1a53, 0x1212, 0x09d2, 0x09f2, 0x09f2, 0x1a53, 0x5bd6, 0xc67c, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0x7498, 0x09f2, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29c9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x4a49, 0xb5b6, 0xc638, 0xbdf7, 0xc638, 0x94b2, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220f, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1232, 0xadfb, 0xffff, 0xffdf, 0xffff, 0xffff, 0xcedd, 0x4b95, 0x1212, 0x11f2, 0x11f2, 0x2a93, 0x5bf6, 0x9539, 0xbe3b, 0xcebd, 0xdf1d, 0xd6fd, 0xcebc, 0xadfb, 0x84f9, 0x4b95, 0x1a53, 0x09f2, 0x11f2, 0x1232, 0x6c57, 0xef7e, 0xffff, 0xffdf, 0xffff, 0xffff, 0x7cd8, 0x09f2, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x29ec, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x2945, 0x4a69, 0xe71c, 0x8c71, 0x39e7, 0x31a6, 0x4a69, 0xbdd7, 0xbdf7, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2230, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a33, 0x1232, 0xbe7c, 0xffff, 0xffff, 0xa5ba, 0x1a53, 0x1212, 0x11f2, 0x32d4, 0x8d39, 0xe73e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6dd, 0x7498, 0x2273, 0x11f2, 0x09f2, 0x32f4, 0xc69c, 0xffff, 0xffff, 0x8d39, 0x09f2, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x220d, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x2945, 0xc618, 0x7bef, 0x18c3, 0x3186, 0x3186, 0x2945, 0x18e3, 0xbdf7, 0x8c51, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a31, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a32, 0x1a53, 0xc67c, 0x9559, 0x09f2, 0x1a32, 0x1a33, 0x7cb8, 0xef7e, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6fd, 0x5bf6, 0x1212, 0x1212, 0x1a53, 0xbe3b, 0x9559, 0x09f2, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x528a, 0xce59, 0x2945, 0x31a6, 0x3186, 0x3186, 0x31a6, 0x2945, 0x5aeb, 0xc638, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a33, 0x1a53, 0x1a33, 0x1212, 0x2a93, 0xbe3b, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x9539, 0x1212, 0x1232, 0x1a33, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2124, 0x632c, 0xb5b6, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x2965, 0x4228, 0xc638, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a32, 0x32f4, 0xdf1d, 0xffff, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xb61b, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2945, 0x4a69, 0xce79, 0x2965, 0x3186, 0x31a6, 0x3186, 0x31a6, 0x2124, 0x630c, 0xc618, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a32, 0x32d4, 0xdf1d, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xdf3e, 0xbe5c, 0xa5ba, 0xaddb, 0xc67c, 0xef7e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xb5fb, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x2945, 0xbdf7, 0x8c71, 0x18c3, 0x2965, 0x2965, 0x2124, 0x2104, 0xce59, 0x8410, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a31, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1212, 0x2ab4, 0xdf3d, 0xffff, 0xffdf, 0xffff, 0xffff, 0xadfb, 0x53b6, 0x2293, 0x1212, 0x11f2, 0x11f2, 0x1232, 0x32d4, 0x6437, 0xc69c, 0xffff, 0xffff, 0xffdf, 0xffff, 0xb61b, 0x1232, 0x1a33, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x220e, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x2965, 0x4208, 0xdedb, 0x9cf3, 0x4a69, 0x4228, 0x5aeb, 0xce59, 0xad75, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2230, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1212, 0x32f4, 0xdf1d, 0xffff, 0xe73e, 0x53b6, 0x09f2, 0x09f2, 0x09d2, 0x1212, 0x1a33, 0x1a33, 0x1212, 0x09d2, 0x09f2, 0x1232, 0x7498, 0xf7df, 0xffff, 0xb61b, 0x1a32, 0x1a33, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x21ed, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x39e7, 0xa514, 0xbdd7, 0xbdd7, 0xbdd7, 0x8430, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220e, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x11f2, 0x3b35, 0xb61b, 0x32f4, 0x09f2, 0x1212, 0x32d4, 0x7cb8, 0xb5fb, 0xcebc, 0xc69c, 0xa5da, 0x6c37, 0x2273, 0x1212, 0x09f2, 0x5bd6, 0xb61b, 0x1a53, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x29cb, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2124, 0x2104, 0x5aeb, 0x738e, 0x4228, 0x18c3, 0x3186, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29ec, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a33, 0x1212, 0x1a32, 0x1232, 0x7478, 0xe77e, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6fd, 0x5396, 0x1212, 0x1a32, 0x1232, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29a9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2124, 0x6b4d, 0xce79, 0xbdd7, 0xad75, 0xce59, 0xbdf7, 0x4208, 0x2965, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29a9, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x1212, 0x8cf9, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0x53d6, 0x1212, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a31, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0x632c, 0xdefb, 0x630c, 0x2965, 0x2945, 0x3186, 0x9492, 0xd69a, 0x39c7, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x1a31, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1212, 0x53b6, 0xf7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffdf, 0xffff, 0xd6fd, 0x32f4, 0x1a32, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a53, 0x220e, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0xd69a, 0x630c, 0x18e3, 0x31a6, 0x31a6, 0x3186, 0x10a2, 0xa534, 0x9cf3, 0x2104, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x09f2, 0x53b6, 0xf7bf, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xd6fd, 0x2ab4, 0x1212, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x5acb, 0xc618, 0x2945, 0x31a6, 0x3186, 0x3186, 0x31a6, 0x2965, 0x528a, 0xc638, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29a9, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x09f2, 0x53b6, 0xffdf, 0xffff, 0xffff, 0xffff, 0xffff, 0xe73e, 0x32d4, 0x1212, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a31, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2124, 0x632c, 0xbdd7, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x2965, 0x4228, 0xce59, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220f, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x09f2, 0x6417, 0xffff, 0xffff, 0xffff, 0xe75e, 0x3b14, 0x1212, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x21ec, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2965, 0x4228, 0xd6ba, 0x31a6, 0x2965, 0x31a6, 0x31a6, 0x31a6, 0x2104, 0x738e, 0xbdf7, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29c9, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x09f2, 0x6417, 0xffff, 0xef7e, 0x3b14, 0x1212, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a32, 0x31a7, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0xad55, 0xb596, 0x18e3, 0x2124, 0x2945, 0x18e3, 0x39c7, 0xdefb, 0x632c, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220e, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a73, 0x09d2, 0x6c57, 0x5396, 0x09f2, 0x2273, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a54, 0x29eb, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0xbdd7, 0xc638, 0x73ae, 0x632c, 0x8c51, 0xdedb, 0x8430, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x31a7, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a73, 0x1212, 0x1232, 0x1a73, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a53, 0x2230, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2965, 0x738e, 0xa534, 0xad55, 0x9cd3, 0x52aa, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29ca, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x29a8, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2124, 0x39e7, 0x738e, 0x8c51, 0x630c, 0x2965, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x31a6, 0x2945, 0x9492, 0xd6ba, 0xa534, 0x9492, 0xbdd7, 0xd6ba, 0x630c, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x220e, 0x1a54, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x29eb, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0x8430, 0xd69a, 0x39c7, 0x2104, 0x2124, 0x18e3, 0x632c, 0xe71c, 0x4a49, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x220e, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x29ec, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2965, 0x39c7, 0xd6ba, 0x4a49, 0x2124, 0x31a6, 0x31a6, 0x31a6, 0x18c3, 0x8c51, 0xad75, 0x2104, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a52, 0x1a53, 0x1a53, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x630c, 0xbdf7, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x2965, 0x4a49, 0xc638, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29cb, 0x1a52, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a31, 0x29a8, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x31a6, 0x2945, 0x630c, 0xbdf7, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x2965, 0x4a49, 0xce59, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29a7, 0x220f, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x21ed, 0x3186, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2965, 0x39c7, 0xd6ba, 0x4228, 0x2945, 0x39c7, 0x31a6, 0x39c7, 0x18c3, 0x8c51, 0xad75, 0x2104, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x29ca, 0x2230, 0x1a53, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x1a53, 0x220e, 0x29a8, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x31a6, 0x2124, 0x8c51, 0xce79, 0x31a6, 0x2104, 0x2124, 0x18e3, 0x5aeb, 0xe71c, 0x4a69, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3186, 0x29c9, 0x220e, 0x1a32, 0x1a53, 0x1a54, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a54, 0x1a53, 0x2231, 0x21ed, 0x29a8, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x2945, 0x9cd3, 0xd69a, 0x9cf3, 0x8c71, 0xb596, 0xdedb, 0x632c, 0x2124, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x31a7, 0x29ca, 0x21ed, 0x220f, 0x1a31, 0x1a32, 0x1a52, 0x1a52, 0x1a52, 0x1a52, 0x1a32, 0x2231, 0x220f, 0x21ec, 0x29c9, 0x3186, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x2124, 0x528a, 0x8430, 0x9492, 0x7bef, 0x39c7, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3185, 0x3186, 0x31a7, 0x29a8, 0x29a8, 0x29a8, 0x29a8, 0x31a7, 0x3186, 0x3185, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x31a6, 0x2965, 0x2124, 0x2124, 0x2124, 0x3186, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186};
  tft.init(240, 240);           // Init ST7789 240x2400
  Serial.println(F("Initialized"));
  uint16_t time = millis();
  time = millis() - time;
//Case 2: Multi Colored Images/Icons
  int h = 97, w = 97, row, col, buffidx=0;
      //To read from Flash Memory, pgm_read_XXX is required.
      //Since image is stored as uint16_t, pgm_read_word is used as it uses 16bit address
      tft.drawPixel(col, row, pgm_read_word(wifi_icon + buffidx));
//      Serial.print(F("pgm_read_word(wifi_icon + buffidx)")); Serial.println(pgm_read_word(wifi_icon + buffidx)); // After uncommenting this line, you will receive compiling error saying that you've raeched out of your program storadge. It means you need to use c-array data.
      buffidx++;
    } // end pixel
Displaying image from c-array data with SDCard initialization - No picture on the display, SDCard module is reading info
#include <SPI.h>
#include <SD.h>
#define TFT_CS        10
#define TFT_RST        9
#define TFT_DC         8
0x3186, 0x3186, 0x31a6, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2945, 0x2965, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x2965, 0x5acb, 0x4a49, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x29a7, 0x29a9, 0x29a9, 0x29a7, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x18c3, 0x73ae, 0xffff, 0xef7d, 0x4a49, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29ca, 0x2210, 0x1a32, 0x1a53, 0x1a53, 0x1a52, 0x2210, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x10a2, 0x8430, 0xffff, 0xf7be, 0x528a, 0x2945, 0x31a6, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ee, 0x1a54, 0x1a73, 0x1a73, 0x1a53, 0x1a53, 0x1a53, 0x1a73, 0x1a54, 0x220e, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2965, 0x3186, 0x9cf3, 0x7bef, 0x2124, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ee, 0x1a74, 0x1a52, 0x09f2, 0x09f2, 0x1212, 0x1212, 0x09f2, 0x09f2, 0x1a52, 0x1a74, 0x220e, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x630c, 0x4208, 0x52aa, 0x4a69, 0x2965, 0x3186, 0x3186, 0x3185, 0x29ca, 0x1a54, 0x11f2, 0x1a32, 0x5bd6, 0xa59a, 0xcebc, 0xcebc, 0xa5ba, 0x5bf6, 0x1a32, 0x11f2, 0x1a54, 0x29ca, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x630c, 0x4208, 0x52aa, 0x528a, 0x2945, 0x3186, 0x3186, 0x3185, 0x220f, 0x1233, 0x4355, 0xcebd, 0xffff, 0xffff, 0xdf3e, 0xdf3d, 0xffff, 0xffff, 0xd6dd, 0x4b75, 0x1233, 0x2230, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2965, 0x31a6, 0x8c51, 0x73ae, 0x2945, 0x3186, 0x3186, 0x3185, 0x2987, 0x1a32, 0x1232, 0xd6dd, 0xffff, 0x7cb8, 0x4b95, 0x5bf6, 0x5bf6, 0x4b95, 0x7c98, 0xffff, 0xdf1d, 0x1a32, 0x1a32, 0x29a7, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x630c, 0x4208, 0x52aa, 0x528a, 0x2945, 0x3186, 0x3185, 0x29a8, 0x1a53, 0x1212, 0x3b15, 0x5bf6, 0x84f9, 0xf7bf, 0xffff, 0xffff, 0xffdf, 0x8d19, 0x5bd6, 0x3b35, 0x1212, 0x1a53, 0x29a9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x630c, 0x4228, 0x52aa, 0x4a69, 0x2965, 0x3186, 0x3185, 0x29a8, 0x1a53, 0x1a53, 0x09f2, 0x2ab3, 0xffdf, 0xc69c, 0x6437, 0x6417, 0xbe5c, 0xffff, 0x32d4, 0x09f2, 0x1a53, 0x1a53, 0x29a9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2965, 0x31a6, 0x8c51, 0x73ae, 0x2965, 0x3186, 0x3186, 0x3185, 0x2987, 0x1a32, 0x1a53, 0x1a53, 0x1a32, 0x2293, 0x63f6, 0xbe5c, 0xbe5c, 0x6417, 0x2a93, 0x1232, 0x1a53, 0x1a53, 0x1a32, 0x29a7, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x632c, 0x39e7, 0x52aa, 0x528a, 0x2945, 0x3186, 0x3186, 0x3185, 0x220f, 0x1a53, 0x1a52, 0x2273, 0x09f2, 0x4b95, 0xffff, 0xffff, 0x53b6, 0x09f2, 0x2273, 0x1a53, 0x1a53, 0x220f, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x5aeb, 0x4a49, 0x5acb, 0x4a69, 0x2965, 0x3186, 0x3186, 0x3185, 0x29a9, 0x1a53, 0x1a53, 0x1a53, 0x2273, 0x09d2, 0x53b6, 0x53d6, 0x09d2, 0x1a73, 0x1a53, 0x1a52, 0x1a53, 0x29c9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2965, 0x31a6, 0x8c51, 0x73ae, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a54, 0x1a53, 0x1a52, 0x1a53, 0x1212, 0x1212, 0x1a53, 0x1a52, 0x1a52, 0x1a54, 0x21ed, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x632c, 0x39c7, 0x528a, 0x528a, 0x2945, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x21ed, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x1a53, 0x21ed, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x2124, 0x5aeb, 0x52aa, 0x630c, 0x4a49, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x29a9, 0x220f, 0x1a32, 0x1a53, 0x1a52, 0x1a32, 0x220f, 0x29a9, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x52aa, 0x4a49, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3186, 0x29a8, 0x29a8, 0x3187, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
0x3186, 0x3186, 0x2945, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3185, 0x3185, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186, 0x3186,
//  pinMode(TFT_CS, OUTPUT);
//  digitalWrite(TFT_CS, HIGH);
//  pinMode(button, INPUT_PULLUP);
  if (!SD.begin(4)) {
      buffidx++;
    } // end pixel
  while (true) {
    if (! entry) {
      // no more files
      Serial.print('\t');
    entry.close();
I started suspecting from the level shifter :thinking:
Level shifter datasheet
If you've switched to a 3.3V 8MHz Pro Mini, why do you need a level shifter?
I need to apologize for not reading carefully enough. The SD module you are using needs to be powered with 5V at Vcc. That's the input to the 3.3V regulator on the module. If you power it with 3.3V, the result would be unpredictable. The Adafruit module may give you the option of powering with 5V or 3.3V. Can you provide a link to the Adafruit module you ordered?
While the 8MHz Pro Mini can be powered with 5V, I assume you are powering it with 3.3V. If that's the case, and if the display operates on 3.3V, then you should not be using a level shifter. I would also say that those TI level shifters are notorious for not working well except under certain limited conditions.
I was disappointed to find the Adafruit has the same problem as the "generic" board.
see their schematic here.
The Adafruit does not have the same issue, but it is for 3.3Volts only.
I know my modification to the "generic" board works, it is different than the one in the previous post. I will try to find my original instructions.
