Hello Everyone,
I am the beginner of the arduino.
I am trying to use the mega 2560 R3 and SD shield to store the data.
SD shield with RTC
I used the PC software to set the frequency at 50Hz which provided by the IMU. In the PC datalogging function, i could able to store 500 data at 10s (0.02s/per data).
However, when i adopted Arduino Mega 2560 R3, i only can save 50+ data in 10s.
Here is my code.
#include "N1Lib.h"
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
N1Lib N1info;
U8 inChar[100];
U8 i;
U32 Succpack;
F32 pitch;
F32 roll;
F32 yaw;
F32 AccX;
F32 AccY;
F32 AccZ;
F32 AirHeight;
const int chipSelect = 4;
File dataFile;
Serial1.begin(115200);
Serial.print("Initializing SD card...");
if (!SD.begin(10, 11, 12, 13)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
while(Serial1.available()) {
inChar[i] = Serial1.read();
if (i ==49) {
i=0;
Succpack = N1info.SuccPackageCnt();
N1info.N1_RawDataRx( &inChar[0], 50);
else i++;
if(N1info.SuccPackageCnt()!=Succpack){
pitch = N1info.N1_GetPitch();
roll = N1info.N1_GetRoll();
yaw = N1info.N1_GetYaw();
AccX = N1info.N1_GetAccX();
AccY = N1info.N1_GetAccY();
AccZ = N1info.N1_GetAccZ();
AirHeight = N1info.N1_GetAirHeight();
File dataFile = SD.open("IMU.txt", FILE_WRITE);
if (dataFile) {
dataFile.print(pitch);
dataFile.print(" ");
dataFile.print(roll);
dataFile.print(yaw);
dataFile.print(AccX);
dataFile.print(AccY);
dataFile.print(AccZ);
dataFile.println(AirHeight);
dataFile.close();
Serial.println("error opening IMU.txt");
Here is my question.
How can i write the data to SD through Mega 2560 which have same data no of the PC (500data at 10s)?
I have searched some information about fast write. There is a lib call SdFat-master. Can it apply in Mega 2560??
Thank you for your kindly help.
