jyu:
Hi, do you guys have resources for induction AC motor control without using a VFD controller
So basically my application is
arduino will control the on and off of the motor via sensor and relays
when turning on and turning off the motor it would not jerk the motor, it would slowly start and slowly stop.
How can I slowly start and slowly stop the motor without using a VFD controller
You can't. And besides, a VFD will have a very small range of frequencies that will run the motor because it was designed to be run at your mains frequency.
It all depends upon how you define “slowly”. There are devices called “soft-starts” for AC induction motors. They vary the voltage using thyristors and can only operate over a very limited range of speed and time. They are used primarily for three phase motors as single phase motors generally don’t lend themselves to being soft-started without stalling and/or overheating.
To be able to run an AC motor at a specific or fully variable speed, you must change the applied voltage and frequency, in proportion, at the same time. For example, if you have a 230 volt 50 Hz motor, a VFD running the motor at half speed is outputting 115 volts at 25 Hz. A VFD achieves this with PWM but it is far more complex than the PWM coming out of an Arduino being used for DC motor control.
VFD’s are designed for 3 phase motors. The motor must also be designed to run at lower speeds and still dissipate the heat generated. It is difficult to vary the speed of a single phase AC motor and I know of only one company building single phase VFD’s, Invertek out of the UK.
A proper 3 phase AC motor and appropriately sized VFD is the proper approach for anything exceeding a few hundred watts. For a low power application, DC may be cheaper and easier.
Your requirements conflict - to control induction motor speed you need at least a V/f controller. Attempting to control the speed of some induction motors without frequency control may lead to stall and catch fire behaviour.
Depending on the rotor design you can arrange for a motor to handle stall conditions without massive current draw, or medium current draw or massive current draw - this is all to do with the rotor bar depth and profile, its not something you can compensate for externally without V/f control.
Put another way some motors are able to handle partial stall, others are not. If not they rapidly overheat
during stall (requiring rapid start up - an induction motor going slowly is in a stall condition and the windings may be dissipating over 100 times their design power - this is catch-fire levels)
