Hello Arduino Community,
I want to have an infinite loop for the strings so they repeat forever.
I need your help to continue with my project!
thanks.
You have not given enough detail to enable help to be given
I assume that you realise that the loop() function repeats forever
Post the code that you are having trouble with and explain what you want to do
Some popular infinite loops are:
// This repeats forever
for (;;)
//This repeats forever
while (true)
# define EVER (;;)
for EVER {
My favourite infinite loop
//code goes here
Im following a library tutorial from heltec cause I'm using an esp8266 oled board.
I want to infinite loop the following lines
// Some test data
const char* test[] = {
"XD",
";D" ,
"8)",
"(^_^)",
":o",
Here is the full code I have been programming.
THANKS FOR YOUR HELP GUYS!
#include "Arduino.h"
#include "heltec.h"
// Adapted from Adafruit_SSD1306
void drawLines() {
for (int16_t i = 0; i < DISPLAY_WIDTH; i += 4) {
Heltec.display->drawLine(0, 0, i, DISPLAY_HEIGHT - 1);
Heltec.display->display();
delay(10);
for (int16_t i = 0; i < DISPLAY_HEIGHT; i += 4) {
Heltec.display->drawLine(0, 0, DISPLAY_WIDTH - 1, i);
delay(10);
delay(250);
Heltec.display->clear();
Heltec.display->drawLine(0, DISPLAY_HEIGHT - 1, i, 0);
delay(10);
for (int16_t i = DISPLAY_HEIGHT - 1; i >= 0; i -= 4) {
Heltec.display->drawLine(0, DISPLAY_HEIGHT - 1, DISPLAY_WIDTH - 1, i);
delay(10);
delay(250);
for (int16_t i = DISPLAY_WIDTH - 1; i >= 0; i -= 4) {
Heltec.display->drawLine(DISPLAY_WIDTH - 1, DISPLAY_HEIGHT - 1, i, 0);
delay(10);
Heltec.display->drawLine(DISPLAY_WIDTH - 1, DISPLAY_HEIGHT - 1, 0, i);
delay(10);
delay(250);
Heltec.display->drawLine(DISPLAY_WIDTH - 1, 0, 0, i);
delay(10);
Heltec.display->drawLine(DISPLAY_WIDTH - 1, 0, i, DISPLAY_HEIGHT - 1);
delay(10);
delay(250);
void drawRect(void) {
for (int16_t i = 0; i < DISPLAY_HEIGHT / 2; i += 2) {
Heltec.display->drawRect(i, i, DISPLAY_WIDTH - 2 * i, DISPLAY_HEIGHT - 2 * i);
delay(10);
void fillRect(void) {
uint8_t color = 1;
for (int16_t i = 0; i < DISPLAY_HEIGHT / 2; i += 3) {
Heltec.display->setColor((color % 2 == 0) ? BLACK : WHITE); // alternate colors
Heltec.display->fillRect(i, i, DISPLAY_WIDTH - i * 2, DISPLAY_HEIGHT - i * 2);
delay(10);
color++;
// Reset back to WHITE
Heltec.display->setColor(WHITE);
void drawCircle(void) {
for (int16_t i = 0; i < DISPLAY_HEIGHT; i += 2) {
Heltec.display->drawCircle(DISPLAY_WIDTH / 2, DISPLAY_HEIGHT / 2, i);
delay(10);
// This will draw the part of the circel in quadrant 1
// Quadrants are numberd like this:
// 0010 | 0001
// 0100 | 1000
Heltec.display->drawCircleQuads(DISPLAY_WIDTH / 2, DISPLAY_HEIGHT / 2, DISPLAY_HEIGHT / 4, 0b00000001);
delay(200);
Heltec.display->drawCircleQuads(DISPLAY_WIDTH / 2, DISPLAY_HEIGHT / 2, DISPLAY_HEIGHT / 4, 0b00000011);
delay(200);
Heltec.display->drawCircleQuads(DISPLAY_WIDTH / 2, DISPLAY_HEIGHT / 2, DISPLAY_HEIGHT / 4, 0b00000111);
delay(200);
Heltec.display->drawCircleQuads(DISPLAY_WIDTH / 2, DISPLAY_HEIGHT / 2, DISPLAY_HEIGHT / 4, 0b00001111);
void printBuffer(void) {
// Initialize the log buffer
// allocate memory to store 8 lines of text and 30 chars per line.
Heltec.display->setLogBuffer(2, 30);
// Some test data
"XD",
";D" ,
"8)",
"(^_^)",
":o",
for (uint8_t i = 0; i < 11; i++) {
// Print to the screen
Heltec.display->println(test*);*
- // Draw it to the internal screen buffer*
- Heltec.display->drawLogBuffer(0, 0);*
- // Display it on the screen*
- Heltec.display->display();*
- delay(500);*
_ Heltec.begin(true /DisplayEnable Enable/, true /Serial Enable/);_ - Heltec.display->setContrast(255);*
- drawLines();*
- delay(1000);*
- Heltec.display->clear();*
- drawRect();*
- delay(1000);*
- fillRect();*
- delay(1000);*
- drawCircle();*
- delay(1000);*
- printBuffer();*
- delay(1000);*
void loop() { }
You want to repeatedly print several smileys ?
More likely you did not Read this before posting a programming question where it advises the use of code tags to avoid the forum software interpreting some character combinations incorrectly. Please revise your post and put code tags around the code
Yes I want to repeat smileys.
I want to repeat the following lines
"XD",
";D" ,
"(._.)",
"8)",
"(*_*)",
"(^_^)",
":o",
#include "heltec.h"
void drawLines() {
delay(10);
delay(10);
delay(250);
delay(10);
delay(10);
delay(250);
delay(10);
delay(10);
delay(250);
delay(10);
delay(10);
delay(250);
delay(10);
uint8_t color = 1;
delay(10);
color++;
delay(10);
// 0010 | 0001
// 0100 | 1000
delay(200);
delay(200);
delay(200);
"XD",
";D" ,
"(._.)",
"8)",
"(*_*)",
"(^_^)",
":o",
Heltec.display->println(test[i]);
Heltec.begin(true /*DisplayEnable Enable*/, true /*Serial Enable*/);
drawLines();
drawRect();
fillRect();
drawCircle();
printBuffer();
void loop() { }
Just call "printBuffer" in loop()?
What went wrong when you tried that?
