I have been familiarizing myself with the Duinotech Mega 2560 R3 with WIFI main board (Jaycar part XC4421) and I have a question. It has both a built-in PCB antenna and a U.FL coax connector to connect an external WIFI antenna. I am from a radio / electronics background and the RF output trace from the ESP8266 WIFI Chip pin 2 appears to go to both the U.FL socket center pin via a 30pF cap and the PCB Antenna via a 6.8uH inductor.
The image below shows this: -
Can anyone confirm that I can plug in an external antenna without changing any smd components please? It looks like you can!
As an aside, there is very little information out there for this board... that I can find anyway...
There was a schematic with the brand name RobotDyn for the same board but I found quite a few differences in the dip switch wiring.
I documented this board's schematic as per the image below: -
It may help someone I hope?
Thanks for any help. Regards RB
