INMP441 and MAX98357A
Hello !
I wanna build some project what is able to record voice, store it into wav file and send it to server to get translation (speech to text), and I try to use MAX98357A as speaker from ChatGPT. For this I try to use two libraries:
<driver/i2s_h> for the mic and <Audio.h> for the speaker. And when I verify my code in Arduino IDE i didn’t get any errors, but after building and uploading this code i get following:
CONFLICT! The new i2s driver can't work along with the legacy i2s driver.
Is it possible to fix this ?
It would be good if we could see this code, please post it.
It would be even better if you also told us what Arduino you are trying this on.
It would be great if you would realise that ChatGPT can not even tell you how many r 's there are in "Raspberry"
#include <EEPROM.h>
#include <DNSServer.h>
#include <HTTPClient.h>
#include <HTTPUpdate.h>
#include <NTPClient.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <WiFiUdp.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <FS.h>
#include <LittleFS.h>
#include <ArduinoJson.h>
#include <TimeLib.h>
#include <vector>
#include <algorithm>
#include <ctime>
#include "Audio.h"
#include "esp_heap_caps.h"
#include "driver/temperature_sensor.h"
#include <driver/i2s.h>
// ==========================AUDIO OUTPUT============================
#define MAX98357A_I2S_DOUT  37
#define MAX98357A_I2S_BCLK 36
#define MAX98357A_I2S_LRC  35
Audio audio;
const size_t audioBufferSize = 64 * 1024;
uint8_t* audioBufferPSRAM = nullptr;
// ==========================MIC======================================
#define I2S_WS 15
#define I2S_SD 13
#define I2S_SCK 2
#define I2S_PORT I2S_NUM_0
#define I2S_SAMPLE_RATE (16000)
#define I2S_SAMPLE_BITS (16)
#define I2S_READ_LEN (16 * 1024)
#define RECORD_TIME (5)
#define I2S_CHANNEL_NUM (1)
#define FLASH_RECORD_SIZE (I2S_CHANNEL_NUM * I2S_SAMPLE_RATE * I2S_SAMPLE_BITS / 8 * RECORD_TIME)
File file;
const char filename[] = "/audio.wav";
const int headerSize = 44;
const char* transcription = "";
void initFile() {
  LittleFS.remove(filename);
  file = LittleFS.open(filename, "w");
  if (!file) {
    Serial.println("File is not available!");
    return;
  uint8_t header[headerSize];
  wavHeader(header, FLASH_RECORD_SIZE);
  file.write(header, headerSize);
  scanFiles();
void i2sInit() {
  i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
    .sample_rate = I2S_SAMPLE_RATE,
    .bits_per_sample = i2s_bits_per_sample_t(I2S_SAMPLE_BITS),
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
    .communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
    .dma_buf_count = 8,
    .dma_buf_len = 1024,
    .use_apll = false,
    .tx_desc_auto_clear = true,
    .fixed_mclk = 0
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  const i2s_pin_config_t pin_config = {
    .bck_io_num = I2S_SCK,
    .ws_io_num = I2S_WS,
    .data_out_num = -1,
    .data_in_num = I2S_SD
  i2s_set_pin(I2S_PORT, &pin_config);
void i2s_adc_data_scale(uint8_t *d_buff, uint8_t *s_buff, uint32_t len) {
  uint32_t j = 0;
  uint32_t dac_value = 0;
  for (int i = 0; i < len; i += 2) {
    dac_value = ((((uint16_t)(s_buff[i + 1] & 0xf) << 8) | ((s_buff[i + 0]))));
    d_buff[j++] = 0;
    d_buff[j++] = dac_value * 256 / 2048;
void i2s_adc(void *arg) {
  int i2s_read_len = I2S_READ_LEN;
  int flash_wr_size = 0;
  size_t bytes_read;
  char *i2s_read_buff = (char *)calloc(i2s_read_len, sizeof(char));
  uint8_t *flash_write_buff = (uint8_t *)calloc(i2s_read_len, sizeof(char));
  i2s_read(I2S_PORT, (void *)i2s_read_buff, i2s_read_len, &bytes_read, portMAX_DELAY);
  Serial.println(" *** Recording Start *** ");
  initFile();
  while (flash_wr_size < FLASH_RECORD_SIZE) {
    i2s_adc_data_scale(flash_write_buff, (uint8_t *)i2s_read_buff, i2s_read_len);
    file.write((const uint8_t *)flash_write_buff, i2s_read_len);
    flash_wr_size += i2s_read_len;
    ets_printf("Sound recording %u%%\n", flash_wr_size * 100 / FLASH_RECORD_SIZE);
    ets_printf("Never Used Stack Size: %u\n", uxTaskGetStackHighWaterMark(NULL));
  file.close();
  free(i2s_read_buff);
  i2s_read_buff = NULL;
  free(flash_write_buff);
  flash_write_buff = NULL;
  scanFiles();
  if (WiFi.status() == WL_CONNECTED) {
    uploadaudioFile();
  vTaskDelete(NULL);
void wavHeader(uint8_t *header, int wavSize) {
  header[0] = 'R';
  header[1] = 'I';
  header[2] = 'F';
  header[3] = 'F';
  unsigned int fileSize = wavSize + headerSize - 8;
  header[4] = (uint8_t)(fileSize & 0xFF);
  header[5] = (uint8_t)((fileSize >> 8) & 0xFF);
  header[6] = (uint8_t)((fileSize >> 16) & 0xFF);
  header[7] = (uint8_t)((fileSize >> 24) & 0xFF);
  header[8] = 'W';
  header[9] = 'A';
  header[10] = 'V';
  header[11] = 'E';
  header[12] = 'f';
  header[13] = 'm';
  header[14] = 't';
  header[15] = ' ';
  header[16] = 0x10;
  header[17] = 0x00;
  header[18] = 0x00;
  header[19] = 0x00;
  header[20] = 0x01;
  header[21] = 0x00;
  header[22] = 0x01;
  header[23] = 0x00;
  header[24] = 0x80;
  header[25] = 0x3E;
  header[26] = 0x00;
  header[27] = 0x00;
  header[28] = 0x00;
  header[29] = 0x7D;
  header[30] = 0x01;
  header[31] = 0x00;
  header[32] = 0x02;
  header[33] = 0x00;
  header[34] = 0x10;
  header[35] = 0x00;
  header[36] = 'd';
  header[37] = 'a';
  header[38] = 't';
  header[39] = 'a';
  header[40] = (uint8_t)(wavSize & 0xFF);
  header[41] = (uint8_t)((wavSize >> 8) & 0xFF);
  header[42] = (uint8_t)((wavSize >> 16) & 0xFF);
  header[43] = (uint8_t)((wavSize >> 24) & 0xFF);
void uploadaudioFile() {
  Serial.println("Uploading audio file...");
  WiFiClient client;
  HTTPClient http;
  http.begin(client, stt_url);
  http.addHeader("X-API-KEY", encrypted_api_key);
  http.addHeader("Content-Type", "audio/wav");
  File uploadaudioFile = LittleFS.open(filename, "r");
  if (!uploadaudioFile) {
    Serial.println("Failed to open file for reading");
    return;
  int httpResponseCode = http.sendRequest("POST", &uploadaudioFile, uploadaudioFile.size());
  if (httpResponseCode > 0) {
    Serial.printf("File uploaded successfully, response code: %d\n", httpResponseCode);
    String response = http.getString();
    Serial.println("Response from server: ");
    Serial.println(response);
    DynamicJsonDocument doc(1024);
    DeserializationError error = deserializeJson(doc, response);
    if (!error) {
      const char* transcription = doc["transcription"];
      Serial.print("Transcription: ");
      Serial.println(transcription);
      Serial.println("Failed to parse JSON response");
    Serial.printf("Error uploading file: %s\n", http.errorToString(httpResponseCode).c_str());
  uploadaudioFile.close();
  http.end();
void waitForSpeechEnd() {
    while (audio.isRunning()) {
        audio.loop();
        yield();
  if (psramFound()) {
    Serial.println("PSRAM found and ready to use");
    Serial.println("No PSRAM found");
  audioBufferPSRAM = (uint8_t*)heap_caps_malloc(audioBufferSize, MALLOC_CAP_SPIRAM);
  if (audioBufferPSRAM == nullptr) {
    Serial.println("Error: Failed to allocate audio buffer in PSRAM");
    Serial.println("Audio buffer allocated in PSRAM");
  i2sInit();
  xTaskCreate(i2s_adc, "i2s_adc", 4096, NULL, 2, NULL);
  audio.setPinout(MAX98357A_I2S_BCLK, MAX98357A_I2S_LRC, MAX98357A_I2S_DOUT);
  audio.setVolume(100);
  audio.connecttospeech("TEST TEST", "en");
  waitForSpeechEnd();
Here is the code
What about that question?
Now I'm using ESP32-S3-WROOM-1 (N16R8)
did you ever find a fix for this? having the exact same problem.
