The original code for filter has no input and output pins, when I add them I have an error.
Need help to solve this problem.
_1khz_filter_pins:6: error: expected constructor, destructor, or type conversion before '(' token
pinMode(PA6, INPUT_ANALOG); //void setup
_1khz_filter_pins:7: error: expected constructor, destructor, or type conversion before '(' token
pinMode(PA7, PWM); //void setup
_1khz_filter_pins:12: error: expected constructor, destructor, or type conversion before '(' token
pwmWrite(PA7, ledFadeValue);
exit status 1
#include <stdio.h>
#include <stdint.h>
//added by me
int inputPin = PA6; //analog input pin
int outputPin = PA7; // PWM output pin
//int analogOut;
// pinMode(INPUT, analog);
// pinMode(OUTPUT, PWM);
// original
// Filter Code Definitions
// maximum number of inputs that can be handled
// in one function call
#define MAX_INPUT_LEN 80
// maximum length of filter than can be handled
#define MAX_FLT_LEN 63
// buffer to hold all of the input samples
#define BUFFER_LEN (MAX_FLT_LEN - 1 + MAX_INPUT_LEN)
// array to hold input samples
double insamp[ BUFFER_LEN ];
// FIR init
void firFloatInit( void )
memset( insamp, 0, sizeof( insamp ) );
// the FIR filter function
void firFloat( double *coeffs, double *input, double *output,
int length, int filterLength )
double acc; // accumulator for MACs
double *coeffp; // pointer to coefficients
double *inputp; // pointer to input samples
int n;
int k;
// put the new samples at the high end of the buffer
memcpy( &insamp[filterLength - 1], input,
length * sizeof(double) );
// apply the filter to each input sample
for ( n = 0; n < length; n++ ) {
// calculate output n
coeffp = coeffs;
inputp = &insamp[filterLength - 1 + n];
acc = 0;
for ( k = 0; k < filterLength; k++ ) {
acc += (*coeffp++) * (*inputp--);
output[n] = acc;
// shift input samples back in time for next time
memmove( &insamp[0], &insamp[length],
(filterLength - 1) * sizeof(double) );
// Test program
// bandpass filter centred around 1000 Hz
// sampling rate = 8000 Hz
#define FILTER_LEN 63
double coeffs[ FILTER_LEN ] =
-0.0448093, 0.0322875, 0.0181163, 0.0087615, 0.0056797,
0.0086685, 0.0148049, 0.0187190, 0.0151019, 0.0027594,
-0.0132676, -0.0232561, -0.0187804, 0.0006382, 0.0250536,
0.0387214, 0.0299817, 0.0002609, -0.0345546, -0.0525282,
-0.0395620, 0.0000246, 0.0440998, 0.0651867, 0.0479110,
0.0000135, -0.0508558, -0.0736313, -0.0529380, -0.0000709,
0.0540186, 0.0766746, 0.0540186, -0.0000709, -0.0529380,
-0.0736313, -0.0508558, 0.0000135, 0.0479110, 0.0651867,
0.0440998, 0.0000246, -0.0395620, -0.0525282, -0.0345546,
0.0002609, 0.0299817, 0.0387214, 0.0250536, 0.0006382,
-0.0187804, -0.0232561, -0.0132676, 0.0027594, 0.0151019,
0.0187190, 0.0148049, 0.0086685, 0.0056797, 0.0087615,
0.0181163, 0.0322875, -0.0448093
void intToFloat( int16_t *input, double *output, int length )
int i;
for ( i = 0; i < length; i++ ) {
output[i] = (double)input[i];
void floatToInt( double *input, int16_t *output, int length )
int i;
if ( input[i] > 32767.0 ) {
input[i] = 32767.0;
} else if ( input[i] < -32768.0 ) {
input[i] = -32768.0;
// convert
output[i] = (int16_t)input[i];
// number of samples to read per loop
#define SAMPLES 80
int main( void )
int size;
int16_t input[SAMPLES];
int16_t output[SAMPLES];
double floatInput[SAMPLES];
double floatOutput[SAMPLES];
FILE *in_fid;
FILE *out_fid;
// open the input waveform file
in_fid = fopen( "input.pcm", "rb" );
if ( in_fid == 0 ) {
printf("couldn't open input.pcm");
return -1;
// open the output waveform file
out_fid = fopen( "outputFloat.pcm", "wb" );
if ( out_fid == 0 ) {
printf("couldn't open outputFloat.pcm");
return-1;
// initialize the filter
firFloatInit();
// process all of the samples
do {
// read samples from file
size = fread( input, sizeof(int16_t), SAMPLES, in_fid );
// convert to doubles
intToFloat( input, floatInput, size );
// perform the filtering
firFloat( coeffs, floatInput, floatOutput, size,
FILTER_LEN );
// convert to ints
floatToInt( floatOutput, output, size );
// write samples to file
fwrite( output, sizeof(int16_t), size, out_fid );
} while ( size != 0 );
fclose( in_fid );
fclose( out_fid );
return 0;
