INPUT_PULLUP not working
Hi!
I have a button connected to my Arduino Uno and I'm using pinMode(2, INPUT_PULLUP); and it's not working. Using pinMode(2, INPUT); and a physical pullup resistor works, though.
Full code: NeoPixel_Hue_Rotater.ino (11.6 KB)
Any help would be appreciated! :grin:
tinkerer9
Please post a simple sketch here that illustrates it not working
Please post a wiring diagram, and photo of your setup.
Please follow post #2 and #3. :+1:
Many members are reluctant to download code. It is too much a pain in the keester to deal with. Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
How do you know that the internal pullup is not working?
Was going to upload a video - but that doesn't work.
When hitting the button, sometimes it works and sometimes not.
It's a little messy, but here's a photo:
Sorry. Here's the code:
   NeoPixel Hue Rotater
   by Max Parisi
   Credit to Adrianotiger for the NeoPixel code (generated from https://adrianotiger.github.io/Neopixel-Effect-Generator/)
   Rotates a hue around a 52-led NeoPixel strip connected to pin 8. Use button connected to pin 2 for 'on/off,' pot connected pin A0 for brightness, pot connected to A1 for speed. Wiring on https://www.tinkercad.com/things/jzduDRLzSIJ-neopixel-hue-rotater.
#include <dht.h>
class Strip
  public:
    uint8_t   effect;
    uint8_t   effects;
    uint16_t  effStep;
    unsigned long effStart;
    Adafruit_NeoPixel strip;
    Strip(uint16_t leds, uint8_t pin, uint8_t toteffects, uint16_t striptype) : strip(leds, pin, striptype) {
      effect = -1;
      effects = toteffects;
      Reset();
    void Reset() {
      effStep = 0;
      effect = (effect + 1) % effects;
      effStart = millis();
struct Loop
  uint8_t currentChild;
  uint8_t childs;
  bool timeBased;
  uint16_t cycles;
  uint16_t currentTime;
  Loop(uint8_t totchilds, bool timebased, uint16_t tottime) {
    currentTime = 0;
    currentChild = 0;
    childs = totchilds;
    timeBased = timebased;
    cycles = tottime;
const int neoLeds = 50;
const int neoPin = 8;
const int neo2Leds = 5;
const int neo2Pin = 7;
const int btnPin = 2;
const int brightnessPin = 0;
const int pot2Pin = 1;
const int ledPin = 5;
const int buzzPin = 3;
const int dhtPin = 6;
const int switchLedPin = LED_BUILTIN;
int btnState, brightnessState, pot2State, brightness, neoSpeed, millisOffset, pixelNum, chk, prePixelNum, hue;
int mode = 1;
byte rgb[3];
float temp, rh, preTemp, preRh;
Strip NeoPixel(neoLeds, neoPin, neoLeds, NEO_GRB + NEO_KHZ800);
struct Loop strip0loop0(1, false, 1);
Strip NeoPixel2(neo2Leds, neo2Pin, neo2Leds, NEO_GRB + NEO_KHZ800);
dht DHT;
  pinMode(btnPin, INPUT_PULLUP);
  pinMode(brightnessPin, INPUT);
  pinMode(pot2Pin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(switchLedPin, OUTPUT);
  Serial.println("Power On\n");
  digitalWrite(switchLedPin, HIGH);
  digitalWrite(switchLedPin, LOW);
  led(0);
  NeoPixel.strip.begin();
  NeoPixel2.strip.begin();
  strip_off();
  strip2_off();
  test();
  strip_off();
  strip2_off();
  pixel2_up_to(1, 0, 0, 255);
  chk = DHT.read11(dhtPin);
  temp = DHT.temperature;
  rh = DHT.humidity;
  brightnessState = pot_to_value(analogRead(brightnessPin));
  brightness = value_to_brightness(brightnessState);
  pot2State = pot_to_value(analogRead(pot2Pin));
  btnState = digitalRead(btnPin);
  if (btnState) {
    while (btnState) {
    mode++;
    while (mode > 5) {
      mode -= 5;
    strip2_off();
    pixel2_up_to(mode, 0, 0, 255);
    if (mode == 3) {
      hue = 0;
    if (mode == 5) {
      preTemp = temp + 1;
      preRh = rh + 1;
    buzz(500);
  switch (mode) {
    case 1:
      all(255, 255, 255);
      led(value_to_led(pot2State));
    case 2:
      led(0);
      value_to_rgb(pot2State, rgb);
      all(rgb[0], rgb[1], rgb[2]);
    case 3:
      value_to_rgb(hue, rgb);
      hue += 8;
      if (hue > 1023) {
        hue -= 1023;
    case 4:
      strips_loop();
    case 5:
      if (!(temp == preTemp) || !(rh == preRh)) {
        all(5, 5, 0);
        pixel(temp_to_pixel(temp), 255, 0, 0);
        pixel(rh_to_pixel(rh), 0, 0, 255);
        preTemp = temp;
        preRh = rh;
    default:
      error("The variable 'mode' went over maximum value.");
  NeoPixel.strip.setBrightness(brightness);
  NeoPixel.strip.show();
  if (brightness <= 0) {
    NeoPixel2.strip.setBrightness(1);
    NeoPixel2.strip.setBrightness(brightness);
  NeoPixel2.strip.show();
void strips_loop() {
  if (strip0_loop0() & 0x01)
uint8_t strip0_loop0() {
  uint8_t ret = 0x00;
  switch (strip0loop0.currentChild) {
    case 0:
      ret = strip0_loop0_eff0(); break;
  if (ret & 0x02) {
    ret &= 0xfd;
    if (strip0loop0.currentChild + 1 >= strip0loop0.childs) {
      strip0loop0.currentChild = 0;
      if (++strip0loop0.currentTime >= strip0loop0.cycles) {
        strip0loop0.currentTime = 0;
        ret |= 0x02;
    else {
      strip0loop0.currentChild++;
  return ret;
uint8_t strip0_loop0_eff0() {
  // Strip ID: 0 - Effect: Rainbow - LEDS: 52
  // Steps: 52 - Delay: 20
  // Colors: 3 (255.0.0, 0.255.0, 0.0.255)
  // Options: rainbowlen=52, toLeft=true,
  if (millis() - NeoPixel.effStart < 52 * (NeoPixel.effStep)) return 0x00;
  float factor1, factor2;
  uint16_t ind;
  for (uint16_t j = 0; j < 52; j++) {
    ind = NeoPixel.effStep + j * 1;
    switch ((int)((ind % 52) / 17.333333333333332)) {
      case 0: factor1 = 1.0 - ((float)(ind % 52 - 0 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 0) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 255 * factor1 + 0 * factor2, 0 * factor1 + 255 * factor2, 0 * factor1 + 0 * factor2);
      case 1: factor1 = 1.0 - ((float)(ind % 52 - 1 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 17.333333333333332) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 255 * factor1 + 0 * factor2, 0 * factor1 + 255 * factor2);
      case 2: factor1 = 1.0 - ((float)(ind % 52 - 2 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 34.666666666666664) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 0 * factor1 + 255 * factor2, 0 * factor1 + 0 * factor2, 255 * factor1 + 0 * factor2);
  if (NeoPixel.effStep >= 52) {
    NeoPixel.Reset();
    return 0x03;
  else NeoPixel.effStep++;
  return 0x01;
int value_to_brightness(int value) {
  if (value >= 1000) {
    return 255;
    int brightness = map(value, 0, 1024, 0, 100);
    if (brightness < 0) {
      error("In 'value_to_brightness()', 'brightness' is less than 0.");
    if (brightness > 255) {
      error("In 'value_to_brightness()', 'brightness' is greater than 255.");
    return brightness;
int pot_to_value(int pot) {
  int value = map(pot, 200, 800, 0, 1024);
  if (value < 0) {
    value = 0;
  if (value > 1024) {
    value = 1024;
  return value;
int value_to_led(int value) {
  return map(value, 0, 1024, 0, 100);
int value_to_rgb(int value, byte rgb[]) {
  float H = map(value, 0, 1024, 0, 360);
  float C = 1;
  float X = 1 - abs(fmod(H / 60.0, 2) - 1);
  float m = 0;
  float r, g, b;
  if (H >= 0 && H < 60) {
    r = C, g = X, b = 0;
  } else if (H >= 60 && H < 120) {
    r = X, g = C, b = 0;
  } else if (H >= 120 && H < 180) {
    r = 0, g = C, b = X;
  } else if (H >= 180 && H < 240) {
    r = 0, g = X, b = C;
  } else if (H >= 240 && H < 300) {
    r = X, g = 0, b = C;
    r = C, g = 0, b = X;
  r = r * 255;
  g = g * 255;
  b = b * 255;
  if (r < 0) {
    error("In 'value_to_rgb()', 'r' is less than 0.");
  if (r > 255) {
    error("In 'value_to_rgb()', 'r' is greater than 255.");
  if (g < 0) {
  if (g > 255) {
  if (b < 0) {
  if (b > 255) {
  rgb[0] = r;
  rgb[1] = g;
  rgb[2] = b;
int time_left_to_pixel(int milli, int milli_left) {
  int pixels =  map(milli_left, 0, milli, 1, (neoLeds - 1));
  if (pixels < 0) {
    error("In 'time_left_to_pixels()', 'pixel' is less than 1.");
  if (pixels > (neoLeds - 1)) {
    error("In 'time_to_pixel()', 'pixels' is greater than neoLeds (minus 1 due to zero indexing).");
  return pixels;
int temp_to_pixel(int temp) {
  int pixel = map(temp, 15, 40, 0, (neoLeds - 1));
  if (pixel < 0) {
    pixel = 0;
  if (pixel > (neoLeds - 1)) {
    pixel = neoLeds - 1;
  return pixel;
int rh_to_pixel(int rh) {
  int pixel = map(rh, 30, 90, 0, (neoLeds - 1));
  if (pixel < 0) {
    pixel = 0;
  return pixel;
int pixel(int pixel, int r, int g, int b) {
  if (pixel < 0) {
    error("On function 'pixel()' first parameter (the pixel #) was above 0.");
    error("On function 'pixel()' first parameter (the pixel #) was above LEDs on the NeoPixel Strip (minus 1 because of zero indexing).");
  NeoPixel.strip.setPixelColor(pixel, NeoPixel.strip.Color(r, g, b));
int pixel2(int pixel, int r, int g, int b) {
  if (pixel < 0) {
    error("On function 'pixel2()' first parameter (the pixel #) was above 0.");
  if (pixel > (neo2Leds - 1)) {
    error("On function 'pixel2()' first parameter (the pixel #) was above LEDs on the NeoPixel Strip #2 (minus 1 because of zero indexing).");
  NeoPixel2.strip.setPixelColor(pixel, NeoPixel2.strip.Color(r, g, b));
int pixel_up_to(int pixels, int r, int g, int b) {
  for (int i = 0; i < pixels; i++) {
    NeoPixel.strip.setPixelColor(i, NeoPixel.strip.Color(r, g, b));
int pixel2_up_to(int pixels, int r, int g, int b) {
    NeoPixel2.strip.setPixelColor(i, NeoPixel2.strip.Color(r, g, b));
int buzz(int duration) {
  if (duration < 0) {
    error("On function 'buzz()' 'duration' is less than 0..");
  tone(buzzPin, 100, duration);
int error(String info) {
  NeoPixel.strip.setBrightness(255);
  NeoPixel2.strip.setBrightness(255);
  led(0);
  Serial.print("ERROR: ");
  Serial.println(info);
  while (!(digitalRead(btnPin))) {
    buzz(1000);
    all(255, 0, 0);
    all2(255, 0, 0);
    strip_off();
    strip2_off();
  Serial.println("Error Ignored");
void strip_off() {
  all(0, 0, 0);
int all(int r, int g, int b) {
  for (int i = 0; i < neoLeds; i++) {
void strip2_off() {
  all2(0, 0, 0);
int all2(int r, int g, int b) {
  for (int i = 0; i < neo2Leds; i++) {
int led(int dutyCycle) {
  analogWrite(ledPin, map(dutyCycle, 0, 100, 0, 255));
void test() {
  Serial.println("~~~ Start Test ~~~");
  buzz(500);
  Serial.println("  Red");
  all(255, 0, 0);
  all2(255, 0, 0);
  buzz(500);
  Serial.println("  Green");
  all(0, 255, 0);
  all2(0, 255, 0);
  buzz(500);
  Serial.println("  Blue");
  all(0, 0, 255);
  all2(0, 0, 255);
  buzz(500);
  Serial.println("  Yellow");
  all(255, 255, 0);
  all2(255, 255, 0);
  led(0);
  buzz(500);
  Serial.println("  White");
  all(255, 255, 255);
  all2(255, 255, 255);
  led(100);
  buzz(500);
  Serial.println("  Fade");
  for (int i = 255; i > 0; i--) {
    NeoPixel.strip.setBrightness(i);
    NeoPixel2.strip.setBrightness(i);
    analogWrite(ledPin, i);
    delay(6.666666666666);
  strip_off();
  strip2_off();
  led(0);
  buzz(500);
That tangle of wires tells us nothing.
Please post a schematic. Hand drawn, photographed and posted is fine. Include all parts, their part numbers and/or values, pin labels and power supplies. Post technical data for the components.
First, get the button working alone, with the simplest possible setup, then add it to that "mess of wires".
Maybe you're only closing the switch during one of the delays.
Testing this:
  int btnState = digitalRead(2);
  Serial.println(btnState, DEC);
Figured something out in Serial Monitor: the state of the button is reversed. Will code change this.
This works:
  int btnState = !digitalRead(2);
Thanks @jremington!
There was nothing wrong with the previous version
