I want to add up from every step i of every sensor the Force. The summation is wrong calculated or interrupted.Maybe I defined something in the wrong loop??? I tried an else if (i==3) statement, but it didnt work out. Who sees my mistake? Thanks in regard.
Gesamtgewicht [0]: Force 20g
Gesamtgewicht [1]: Force 25g
Gesamtgewicht [2]: Force 6g
Gesamtgewicht [3]: Force 0g
const int FSR_PIN[] = {A0, A1, A2, A3}; // Pin connected to FSR/resistor divider
// Measure the voltage at 5V and resistance of your 3.3k resistor, and enter
// their value's below:
const float VCC = 4.98; // Measured voltage of Ardunio 5V line
const float R_DIV = 9960.0; // Measured resistance of 3.3k resistor
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
//get number of pins being used
int numberOfPins = sizeof(FSR_PIN) / sizeof(FSR_PIN[0]);
int fsrADC[numberOfPins];
//collect data from all analog sources
for (int i = 0; i < numberOfPins; i++) {
fsrADC[i] = analogRead (FSR_PIN[i]);
Serial.println( "1:"+ String(fsrADC[0]));
delay (50);
Serial.println( "2:"+ String(fsrADC[1]));
delay (50);
Serial.println( "3:"+ String(fsrADC[2]));
delay (50);
Serial.println( "4:"+ String(fsrADC[3]));
delay (50);
float volt[numberOfPins];
float resist[numberOfPins];
float conduct[numberOfPins];
float Gesamtgewicht[numberOfPins];
if (fsrADC[i] != 0) // If the analog reading is non-zero
// Use ADC reading to calculate voltage:
float fsrV = fsrADC[i] * VCC / 1023.0;
volt[i] = fsrV;
// Use voltage and static resistor value to
// calculate FSR resistance:
float fsrR = R_DIV * (VCC / volt[i] - 1.0);
resist[i] = fsrR;
Serial.println(i);
Serial.println("Resistance___" + String(fsrR) + " ohms");
// Guesstimate force based on slopes in figure 3 of
// FSR datasheet:
float force;
float fsrC = 1.0 / resist[i]; // Calculate conductance
conduct[i] = fsrC;
// Break parabolic curve down into two linear slopes:
if (fsrR <= 600)
force = (fsrC - 0.00075) / 0.00000032639;
force = fsrC / 0.000000642857;
Gesamtgewicht[i]= force;
for (i=0; i=3; i++) {
// Summe von force, Gesamtgewicht übermitteln
float a=0;
a += Gesamtgewicht[i];
Serial.print("Gesamtgewicht: ");
Serial.println( String(a) + " g");
// No pressure detected
Please use code tags to increase code readability.. You have a bug here:
fsrADC = analogRead (FSR_PIN); //No array indicies applied
//fsrADC[i] = analogRead (FSR_PIN[i]); //Right way to do it
The same bug re-appears multiple places. Your code loops through the pins multiple times for various reasons, looping throgh the pins once should be enough and more efficient.
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask an effective question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
C:\Users\Olej\Desktop\Multiple_FSR\Multiple_FSR.ino: In function 'void loop()':
C:\Users\Olej\Desktop\Multiple_FSR\Multiple_FSR.ino:26:33: warning: invalid conversion from 'const int*' to 'uint8_t {aka unsigned char}' [-fpermissive]
In file included from sketch\Multiple_FSR.ino.cpp:1:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.39.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:137:5: note: initializing argument 1 of 'int analogRead(uint8_t)'
int analogRead(uint8_t pin);
Multiple_FSR:26:33: error: incompatible types in assignment of 'int' to 'int [numberOfPins]'
exit status 1
Hey Danois, I am sitting since 3 days on that code being at 0 progress. THe question was how can i read from every sensor the force?
I have no experience with arduino or C++, that I would understand where to change my code due to you. At the top you have my code. Would you be so nice and change it by yourself and upload it, so i could prove, if it works. And if yes, I would confirm and the next ones would have a solution for multipleFSR sensors systems.
You code is so messy and some of it was lost because you did not use code tags from the beginning. The variable "a" must change scope in order for the sum to be calculated:
float a = 0; //Declare it here
//float a=0; Do not declare it here
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
fsrADC [i] = analogRead (FSR_PIN [i]);
delay (50);
delay (101);
delay (152);
delay (203);
volt[i] = fsrV;
resist[i] = fsrR;
Serial.println(i);
// FSR datasheet:
float force;
conduct[i] = fsrC;
if (fsrR <= 600)
float a=0;
for (i=0; i < numberOfPins; i++) {
Still a negative scale :-(.
If I dont press on any sensor: first loop gives me
1:0
2:0
3:0
4:0
fsrAdc is 0 fo all sensors, due to no voltage.
And then it is looping 4 times over it, until my fingerpress (see picture, pressing sensor 1 and 3) is recognized. But then it doesnt take the force and sum it up correct.
It looks like thhey are ovverwriting. Have no clue??? ANy helps?
The problem with it is, that all 4 readings are printed to serial 4 times. The first time only fsrADC[0] is valid, the second time fsrADC[0] and fsrADC[1] are valid. If you only want to print valid values to serial, you must move the printing out of that for-loop or implement it differently.
//Read
//Print
Serial.println(String(i+1) + ":" + String(fsrADC[i]));
Even though I just used the "String" class, this should be avoided since it's known to cause problems.
Thank you very much Danois for supporting this :-). I have now almost done it. Here is the Code.
// Measure the voltage at 5V and resistance of your 10k resistor, and enter
const float R_DIV = 9950.0; // Measured resistance of 10k resistor
int printForces = 1;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
float all =0;
//Read
//Print of all Sensors
Serial.println("Sensor_"+ String(i+1) + ":" + String(fsrADC[i]));
delay (50);
float weight[numberOfPins];
//Pressure is present on the FSR Sensor
volt[i] = fsrV;
resist[i] = fsrR;
// Guesstimate force based on slopes in figure 3 of FSR datasheet:
float force;
conduct[i] = fsrC;
if (printForces) {
if (resist[i] <= 600) {
force = ((conduct[i] - 0.00075) / 0.00000032639);
else {
force = (conduct[i] / 0.000000642857);
weight[i]= force;
all += weight[i];
if ( i <= numberOfPins) {
Serial.println( String(all) + " g");
In the Attachhment you can see that I am pressing on 2 Sensors and the weight is summed up.
I am still thinking how to display only the weight value after sensor 4 is read out. Hmm, do you have an idea?
