Integrated External Servo Power Solution?
I am using three sizeable servos ( DGS S05NF). Distributors say powering them through the Arduino will result in damage (link below)
Servo DGS S90 S05NF - medium Botland - Robotic Shop.
Currently, the idea is to supply a external regulated DC voltage source to the three servos from the following wall adapter (GF18-US24075T)
Goforward Enterprise Corporation
The Schematic looks like the one below (if the link is not broken :grimacing:) but ideally, the barrel jack on the breadboard would be a regulated 5 volt supply.
My question is, is there a device that can provide an integrated solution to avoid the breadboard?
The current setup is a a bit tight (I have omitted many other components as they are not relevant).
Oh dear !
Luckily you spotted the mistake
You could solder the three red wires to the + side of the power jack and solder the four black wires (including the one to connect to Arduino ground) to the - side of the power jack.
You could use a Wago connector if you want to avoid soldering.
Easy, reusable, goes down to 24g wire. Avaiable from many sources.
Thank you for the very quick replies!
I guess I was hoping someone would be aware of a device similar to what is linked below but
  • Connection to a breadboard is not required
  • Minimum 3 pairs of Female connectors ( + and ground) on the board also.
Amazon.com: CorpCo MB102 Breadboard Power Supply Module 3.3V/5V for Arduino Board Solderless Breadboard : Electronics
As always, thank you to everyone who replied. It really does help a lot!
I don't know of any ready made solution for what you need... it is a pretty custom order :smile:
You could take a barrel jack adapter and wire it to the Uno and use a 3-way splitter adapter for the servos?
Alternatively, get a PCB mount barrel jack and using a perf-board, manually wire 3 sets of headers for the servos.
