To integrate Arduino with a website for real-time pet health monitoring, you'll need both hardware and software components. Below are some lines of code and steps to help you get started. Keep in mind that this is a simplified example, and you may need to adapt it based on your specific requirements.
1. Arduino Code:
cppCopy code
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme;
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
float temperature = bme.readTemperature();
float humidity = bme.readHumidity();
float pressure = bme.readPressure() / 100.0F;
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" *C");
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println(" %");
Serial.print("Pressure: ");
Serial.print(pressure);
Serial.println(" hPa");
delay(10000); // Adjust the delay based on your monitoring frequency
This code reads temperature, humidity, and pressure from a BME280 sensor.
2. Set up a server to send data:
You will need a server-side script to receive the data from the Arduino and store it or send it to the website. For simplicity, let's use a PHP script:
phpCopy code
<?php
if ($_SERVER['REQUEST_METHOD'] === 'POST') {
$data = json_decode(file_get_contents('php://input'), true);
// Process and store data as needed (e.g., save to a database)
echo "Data received successfully";
http_response_code(405);
echo "Method Not Allowed";
3. Arduino Code to Send Data to Server:
cppCopy code
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "your_wifi_ssid";
const char* password = "your_wifi_password";
const char* serverUrl = "http://your_server_address/data-receiver.php";
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
float temperature = /* read temperature from sensor */;
float humidity = /* read humidity from sensor */;
float pressure = /* read pressure from sensor */;
// Create JSON payload
String payload = "{\"temperature\":" + String(temperature) +
",\"humidity\":" + String(humidity) +
",\"pressure\":" + String(pressure) + "}";
// Send data to server
HTTPClient http;
http.begin(serverUrl);
http.addHeader("Content-Type", "application/json");
int httpCode = http.POST(payload);
if (httpCode > 0) {
Serial.printf("[HTTP] POST... code: %d\n", httpCode);
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_CREATED) {
Serial.println("Data sent successfully");
Serial.printf("[HTTP] POST... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(60000); // Adjust the delay based on your monitoring frequency
Make sure to replace placeholders like your_wifi_ssid, your_wifi_password, your_server_address, and adjust the code based on your specific requirements.
4. Website Integration:
Use HTML, CSS, and JavaScript to create a web interface that fetches and displays the real-time pet health data. You can use AJAX to periodically fetch data from the server and update the UI.
This is a basic starting point, and you may need to enhance and secure the system based on your specific use case. Additionally, consider using HTTPS for secure communication and implementing proper authentication and authorization mechanisms
