Intell Galileo Gen1 Error Compiling Arduino 1.8.16
This is my code
  digitalWrite(12, LOW);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(12, HIGH);    // turn the LED off by making the voltage LOW
This is the error message
Arduino: 1.8.16 (Windows 10), Board: "Intel® Galileo"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\banic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\banic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\banic\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\banic\AppData\Local\Temp\arduino_build_186469 -warnings=none -build-cache C:\Users\banic\AppData\Local\Temp\arduino_cache_821446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.sketchUploader-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Users\banic\AppData\Local\Temp\arduino_modified_sketch_434332\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\banic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\banic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\banic\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\banic\AppData\Local\Temp\arduino_build_186469 -warnings=none -build-cache C:\Users\banic\AppData\Local\Temp\arduino_cache_821446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.sketchUploader-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Users\banic\AppData\Local\Temp\arduino_modified_sketch_434332\Blink.ino
Using board 'izmir_fd' from platform in folder: C:\Users\banic\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0
Using core 'arduino' from platform in folder: C:\Users\banic\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0
Detecting libraries used...
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/i586-poky-linux-uclibc" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -w -x c++ -E -CC -march=i586 -m32 -DARDUINO=10816 "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\cores\\arduino" "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\variants\\galileo_fab_d" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/i586-poky-linux-uclibc" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -w -x c++ -E -CC -march=i586 -m32 -DARDUINO=10816 "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\cores\\arduino" "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\variants\\galileo_fab_d" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\sketch\\Blink.ino.cpp" -o "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/i586-poky-linux-uclibc" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -march=i586 -m32 -DARDUINO=10816 "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\cores\\arduino" "-IC:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\hardware\\i586\\1.6.7+1.0\\variants\\galileo_fab_d" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\sketch\\Blink.ino.cpp" -o "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\banic\AppData\Local\Temp\arduino_build_186469\core\variant.cpp.o
Using precompiled core: C:\Users\banic\AppData\Local\Temp\arduino_cache_821446\core\core_Intel_i586_izmir_fd_e80894d4c81a744022c821524eed4447.a
Linking everything together...
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/i586-poky-linux-uclibc" -Os -Wl,--gc-sections -march=i586 -o "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469/Blink.ino.elf" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\sketch\\Blink.ino.cpp.o" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469\\core\\variant.cpp.o" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469/..\\arduino_cache_821446\\core\\core_Intel_i586_izmir_fd_e80894d4c81a744022c821524eed4447.a" "-LC:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469" -lm -lpthread
C:\Users\banic\AppData\Local\Temp\arduino_build_186469/..\arduino_cache_821446\core\core_Intel_i586_izmir_fd_e80894d4c81a744022c821524eed4447.a(main.cpp.o): In function `main':
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0\cores\arduino/main.cpp:110: undefined reference to `setup()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Intel® Galileo.
You're missing the required setup() function. Also, your sketch never sets pin 12 to be an output.
  pinMode(12, OUTPUT);
Please help if you know how, i got this board as an prise for a science competition and i want to use it but it just wont compile!
Thank zou very much, now it compiles but than it gives this error message
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\banic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\banic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\banic\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\banic\AppData\Local\Temp\arduino_build_186469 -warnings=none -build-cache C:\Users\banic\AppData\Local\Temp\arduino_cache_821446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.sketchUploader-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Users\banic\AppData\Local\Temp\arduino_modified_sketch_144225\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\banic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\banic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\banic\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0000_0000 -ide-version=10816 -build-path C:\Users\banic\AppData\Local\Temp\arduino_build_186469 -warnings=none -build-cache C:\Users\banic\AppData\Local\Temp\arduino_cache_821446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.sketchUploader-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc-1.6.2+1.0.path=C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Users\banic\AppData\Local\Temp\arduino_modified_sketch_144225\Blink.ino
Compiling sketch...
Compiling core...
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-strip" "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469/Blink.ino.elf"
"C:\\Users\\banic\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\i586-poky-linux-uclibc\\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-size" -A "C:\\Users\\banic\\AppData\\Local\\Temp\\arduino_build_186469/Blink.ino.elf"
Sketch uses 57991 bytes (0%) of program storage space. Maximum is 10000000 bytes.
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin/bash.exe --verbose --noprofile C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\banic\AppData\Local\Temp\arduino_build_186469/Blink.ino.elf COM3
#!/bin/sh
starting download script
Args to shell: C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\banic\AppData\Local\Temp\arduino_build_186469/Blink.ino.elf COM3
# clupload script to invoke lsz
COM PORT 3
# Copyright (C) 2014 Intel Corporation
Converted COM Port COM3 to tty port /dev/ttyS2
Sending Command String to move to download if not already in download mode
# This library is free software; you can redistribute it and/or
Deleting existing sketch on target
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh: line 42: /dev/ttyS2: Permission denied
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh: line 46: /dev/ttyS2: Permission denied
# Execute the target download command
#Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh: line 51: /dev/ttyS2: Permission denied
Moving downloaded file to /sketch/sketch.elf on target
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\Users\banic\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh: line 56: /dev/ttyS2: Permission denied
An error occurred while uploading the sketch
It looks like @lmanmen was able to solve the upload failure and is now experiencing a runtime problem, for which they have created a dedicated topic:
As for the uploading failure, I notice that during the failed upload you had COM3 selected from the Tools > Port menu:
whereas during the successful upload you had COM8 selected:
So maybe the upload failure reported here was caused by having the wrong port selected.
