Interfacing Arduino Mega with 2.8 TFT by Itead Studio
Hi!
I am doing a project which involves interfacing the Arduino Mega R3 with a 2.8inch TFT Touch screen from Itead studio.
The link for the TFT display is
http://imall.iteadstudio.com/im120417020.html
The User Manual is
ftp://imall.iteadstudio.com/IM120417020_2.8_TFT_LCD_Touch_Shield/DS_IM120417020_2.8_TFT_LCD_Touch_Shield.pdf
I am trying to use the UTFT and UTouch libraries from Henning Karlsen
http://www.henningkarlsen.com/electronics/library.php
The display is included in list of supported models for the UTFT and UTouch libraries.
The Problem is this:
While assigning the various pins during Initialization of the display, I realize that the User Manual does not have any pins for Touch_CS and TFT_Reset.
Without assigning these pins to the initialization code, the display is not running the example codes given in UTouch library.
I have changed the model number to ITDB28 and assigned pins in the initialization code as per the datasheet of the Display.
Also, I am not using any jumper cables, just attaching the shield on top of the Arduino Mega. Itead Studio says that the shield is compatible with the Mega, but I am not entirely sure if this setup will work, or the Arduino is giving it's output to some other pins.
I have attached the initialization code here, with random pins assigned to the missing ones mentioned above.
UTFT        myGLCD(ITDB28, A5,A4,A3,A2);   // Remember to change the model parameter to suit your display module!
UTouch      myTouch(A1,41,A0,8,9);
I've got a similiar board (Its a 3.2 though) - using this:
UTFT myGLCD(ITDB32S, 38,39,40,41);
UTouch myTouch(6,5,4,3,2);
