interfacing of multiple ultrasonic sensors at same time
i am working on a project using three ultrasonic sensors(HC-SR04) .But the problem is i cant get the value of multiple ultrasonic sensors at same time.Only one sensor is reading output i want to check the value of two, three sensors at same time. Here the program shown below .i hope someone will help me with it thank you...!!
/* ForNext Labs
BLIND CANE SENSOR*/
#include <Ultrasonic.h>
#define trig1 8
#define echo1 9
#define trig2 10
#define echo2 11
#define trig3 12
#define echo3 13
#define playR 1
#define playF 2
#define playL 3
#define playRF 4
#define playRL 5
#define playFL 6
#define playRFL 7
Ultrasonic ultrasonic1(trig1, echo1);
Ultrasonic ultrasonic2(trig2, echo2);
Ultrasonic ultrasonic3(trig3, echo3);
Serial.begin(9600); // begin serial communitication
Serial.println("Initialising..!!");
pinMode(trig1, OUTPUT);// set the trig pin to output (Send sound waves)
pinMode(echo1, INPUT);// set the echo pin to input (recieve sound waves)
pinMode(trig2, OUTPUT);// set the trig pin to output (Send sound waves)
pinMode(echo2, INPUT);// set the echo pin to input (recieve sound waves)
pinMode(trig3, OUTPUT);// set the trig pin to output (Send sound waves)
pinMode(echo3, INPUT);// set the echo pin to input (recieve sound waves)
long duration1, distance1; // start the scan
digitalWrite(trig1, LOW);
delayMicroseconds(2); // delays are required for a succesful sensor operation.
digitalWrite(trig1, HIGH);
delayMicroseconds(10); //this delay is required as well!
duration1 = pulseIn(echo1, HIGH);
distance1 = (duration1/2) / 29.1;// convert the distance to centimeters.
long duration2, distance2; // start the scan
digitalWrite(trig2, LOW);
digitalWrite(trig2, HIGH);
duration2 = pulseIn(echo2, HIGH);
distance2 = (duration2/2) / 29.1; // convert the distance to centimeters.
long duration3, distance3; // start the scan
digitalWrite(trig3, LOW);
digitalWrite(trig3, HIGH);
duration3 = pulseIn(echo3, HIGH);
distance3 = (duration3/2) / 29.1; // convert the distance to centimeters.
//CONDITION FOR GUIDANCE
if (distance1 < 30)/*if there's an obstacle in right do the following: */
Serial.println("RIGHT");
Serial.print ("Distance From RIGHT is " );
Serial.print ( distance1);
Serial.print ( " CM!");// print out the distance in centimeters.
digitalWrite(playR,HIGH);
delay(400);
else if (distance2 < 30)/*if there's an obstacle in front do the following: */
Serial.println("FRONT");
Serial.print ("Distance From FRONT is " );
Serial.print ( distance2);
Serial.print ( " CM!"); // print out the distance in centimeters.
digitalWrite(playF,HIGH);
delay(400);
else if (distance3 < 30)/*if there's an obstacle in left do the following: */
Serial.println("LEFT");
Serial.print ("Distance From LEFT is " );
Serial.print ( distance3);
digitalWrite(playL,HIGH);
delay(400);
else if (distance1 < 30 && distance2 < 30)/*if there's an obstacle in right&front do the following: */
Serial.println("RIGHT & FRONT");
Serial.print ("Distance From RIGHT&FRONT is " );
digitalWrite(playRF,HIGH);
delay(400);
else if (distance1 < 30 && distance3 < 30)/*if there's an obstacle in right&LEFT do the following: */
Serial.println("RIGHT & LEFT");
Serial.print ("Distance From RIGHT&LEFT is " );
digitalWrite(playRL,HIGH);
delay(400);
else if (distance2 < 30 && distance3 < 30)/*if there's an obstacle in left&front do the following: */
Serial.println("LEFT & FRONT");
Serial.print ("Distance From LEFT&FRONT is " );
digitalWrite(playFL,HIGH);
delay(400);
else if (distance1 < 30 && distance2 < 30 && distance3 < 30)/*if there's an obstacle in right&left&front do the following: */
Serial.println("RIGHT & LEFT &Back");
digitalWrite(playRFL,HIGH);
delay(400);
Serial.println("walk");
Please edit your post and add code tags ("</>" button). See "How to use this forum".
You usually can't use more than one ultrasonic ranger at once, because they interfere with each other.
Did you try Google? Up at the top of 1000s of hits is mention of the NewPing lib: it supports multiple sensors. They're not used simultaneously...it cycles through them. But, maybe it is good enough for you.
I agree with the previous posters. You have to cycle through the sensors. In my obstacle avoidance rover Iuse five sensors that I read into an array and do the range test similar to you based on array element corresponding to the sensor platoon. Hope this helps
Thank you for your support... :slight_smile:
