Interfacing TDS sensor and dosing pump
Hello, I have some problem right here. I want to create a smart dosing system. I am using TDS sensor to check the conductivity of the solution while dosing pump used to deliver the nutrient solution into the water. In this project I want TDS sensor to measure the initial reading in the water first before the dosing pump can start the dosing process. If the TDS sensor get a reading below 1000 ppm at initial, the dosing pump will start its dosing process with 1 second delay. This process will be keep continue until the TDS sensor gets a reading of 1000 ppm. When the TDS sensor get a reading equal to 1000 ppm, the dosing pump will be stop working and print the reading in serial monitor and the dosing process is complete.
The problem is when I run the experiment, the TDS sensor reading does not change (which is it remain at 0 ppm) in the serial monitor even I have already submerge the TDS sensor into the solution causing the dosing pump keep continue ON.
Here is my coding:
#define TdsSensorPin 34
#define VREF 3.3              // analog reference voltage of the ADC
#define SCOUNT  30            // sum of sample point
#define RELAY_PIN_1 18
#define RELAY_PIN_2 19
int analogBuffer[SCOUNT];     // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0;
int copyIndex = 0;
float averageVoltage = 0;     // Floats to calculate average voltage & TDS value
float tdsValue = 0;
float temperature = 25;       // current temperature for compensation
// median filtering algorithm
int getMedianNum(int bArray[], int iFilterLen) {
  int bTab[iFilterLen];
  for (byte i = 0; i < iFilterLen; i++)
    bTab[i] = bArray[i];
  int i, j, bTemp;
  for (j = 0; j < iFilterLen - 1; j++) {
    for (i = 0; i < iFilterLen - j - 1; i++) {
      if (bTab[i] > bTab[i + 1]) {
        bTemp = bTab[i];
        bTab[i] = bTab[i + 1];
        bTab[i + 1] = bTemp;
  if ((iFilterLen & 1) > 0) {
    bTemp = bTab[(iFilterLen - 1) / 2];
  else {
    bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
  return bTemp;
  pinMode(TdsSensorPin, INPUT);
  pinMode(RELAY_PIN_1, OUTPUT);
  pinMode(RELAY_PIN_2, OUTPUT);
  static unsigned long analogSampleTimepoint = millis();
  if (millis() - analogSampleTimepoint > 40U) { //every 40 milliseconds,read the analog value from the ADC
    analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin);    //read the analog value and store into the buffer
    analogBufferIndex++;
    if (analogBufferIndex == SCOUNT) {
  static unsigned long printTimepoint = millis();
  if (millis() - printTimepoint > 800U) {
    for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++) {
      analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
      // read the analog value more stable by the median filtering algorithm, and convert to voltage value
      averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 4096.0;
      //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
      float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0);
      float compensationVoltage = averageVoltage / compensationCoefficient;
      //convert voltage value to tds value
      tdsValue = (133.42 * compensationVoltage * compensationVoltage * compensationVoltage - 255.86 * compensationVoltage * compensationVoltage + 857.39 * compensationVoltage) * 0.5;
      if (tdsValue < 1000) {
        Serial.print("TDS Value Low:");
        Serial.print(tdsValue, 0);
        Serial.println("ppm");
        // turn on pump A & B for 1 seconds
        digitalWrite(RELAY_PIN_1, LOW);
        digitalWrite(RELAY_PIN_2, LOW);
        digitalWrite(RELAY_PIN_1, HIGH);
        digitalWrite(RELAY_PIN_2, HIGH);
      else if (tdsValue = 1000) {
        Serial.print("TDS Value:");
      else {}
Here is my circuit diagram:
Here is my serial monitor during the process:
Serial monitor (error)
#esp32, #TDSsensor, #Minipump, #smart dosing system
Have you done the first step, which is to get the TDS sensor working properly without the pump?
try commenting out the
statement
GPI34 is already an analog input pin - you are setting it as digital input pin
Use a logic analyzer to see what happens.
Insert Serial.println()´s at points of interrest.
Yes. I have already test the TDS sensor and dosing pump separately and both of it is working fine and normal. But when I try to combine the codes, the TDS sensor reading does not changing (remain at 0 ppm) even after I already submerged the TDS sensor into the solution. The TDS sensor reading should be increase actually not remain at 0 ppm.
This is a serious mistake, but probably not the main problem.
For the mistake, can you state the reason, it would be really appreciated.
"==" is used for equality comparison. "=" assigns a value.
Thank you.
