I have some BLDC (brushless direct current) motors with hall sensor feedback that I want to control. I have sourced chinese controller ZS-X11A, which looks good to fit between motor & arduino. Has anyone trod this path before me? A few issues that I'm hoping someone on the forum might know the answers.
Controller, as delivered has 5 holes denoted CN2 for hall sensor connector. These are on a 2mm pitch, as is CN1, which provides +5V, SC, Z/F, VR & 0V. Does anyone know product codes &/or supplier for pcb mounted male connector and mating socket with or without pigtail lead set? I know I can solder flyng leads direct to board, but would like to find suitable connector.
Has anyone used this to drive a motor with hall sensor feedback? I'm just a bit concerned that lack of board mounted connector means the capability is somehow disabled on the finished board.
VR is variable voltage input to the controller to define speed setpoint. Does anyone know if this will accept ardiuno pwm output direct, without additional R/C filter? If it does, any recommendations for repetition frequency?
Has anyone made use of the SC connection? I have seen contradictory information about it. I think it's either an output from the controller giving a square waveform synchronised output drive cycle, or it's an input to the controller of some sort of pwm signal. If pwm in, is it unfiltered alternative to VR; is it something like servo drive waveform; is it something else?
