Interfacing with a salvaged laptop webcam board
Hi !
I salvaged a small webcam and microphone board from an old laptop that I had lying around. I'd like to use it in some smart mirror project, but I'm having a hard time finding documentation on how to interface with it and wondered if people here knew some more.
The circuit board is identified as FE03FF-99. Googling that shows result to buy the spare part, but I found no documentation, no datasheet, no diagram, no DIY project that hacked this particular model. I found some other webcam board where the person just had to attach a USB cable as the 4 pins they had were simply USB (or 5 pins with two GND). My board, however, has 5 pins, and I don't know how to identify these. Is it USB ? SPI, UART, I2C ? These pins connect to a cable that merges with the screen's cable and goes directly to the laptop motherboard.
I identified pin 5 as GND, but that's about it.
So I tried to identify the IC chips on it. There's two big one. The first one is a 25L512OIG from MX, which doesn't yield a lot of result online. I couldn't find any datasheet.
The second one, I couldn't clearly identify either. Probably some kind of micro-controller.
What could I do to identify the pins further ? I'm afraid to damage it if I give it 5V randomly when it expected 3.3V (or other). Any help would be greatly appreciated !
Here's a link to full res pictures. I attached some lower pictures for posterity !
A tech forum related to your laptop's brand has better chance of success, if only because Arduinos can't do anything useful with a raw camera image.
As a general rule, it is extremely unlikely that you will find any documentation for a proprietary part like that.
There are lots of tutorials how to attach a USB cable onto a laptop webcam, to reuse it for any purpose.
Try it with "laptop webcam usb pinout" or something and you will find plenty of pictutes and stuff!
wvmarle:
Yeah, sorry, I tried my luck here because I'm not sure where to go, and I figured maybe this part of the forum would know something !
jremington:
Still, I'm surprised that I can't even find datasheet for the two IC on the board.
TriB:
Thanks, googling that yields better results, although I can't find exactly my model. I'll try later today to find the correct pinout again, I'm pretty sure it's USB now !
Those ICs may very well be either proprietary or custom made. Either way there will be no publicly available datasheet for them.
wvmarle:
That´s not completely true. The manufacturers buy those peripheral devices from just a handful producers.
And as you can see, if you´d follow my search-term, the very most webcams are using USB as internal interface.
With that, they are interchangable within different models, even from different manufacturers.
So the USB-IC will be quite well documented and that´s the main part to reuse this device!
For any other IC on that board, you´ll might be right, that there is no documentation avaliable.
If so, OP should have no problem tracking down the USB chip that's on this webcam... or otherwise get a working USB connection.
A little bit of Saturday morning detective work here, but, searching for a semiconductor company called onix didn't reveal much. But looking at the top of the chip I figured there could be another letter at the start hidden under the epoxy. A guess at sonix revealed a semiconductor company in Taiwan (sonix.com) that produce video/image controllers which might fit.
