Interfacing with Paradox Spectra Security Systems
Hello,
Has anyone tried to decode Paradox Spectra Security Systems serial interface? My plan is to get activity reports via Spectra's serial interface with JeeNode. I connected my JeeNode to Spretra's serial interface and successfully managed to transfer serial data packets to JeeLink. But I need to decode this serial communication... :roll_eyes:
I want to know how too
well, if you can successfully communicate with it via serial, then you should be able to grab the serial data. Determine the baud rate and you should be good to go. Then try and see if there are any patterns in the data (meaning that it is a packet based communication).
Hi there, if you get the PRT3 module, you can have all the content sent to you over a serial bus, in either ascii or c-bus format.
http://www.paradox-alarm-systems.com/en/p/433/paradox-prt3-
regards John :D
Hello, I'm trying to comunicate with Paradox alarm system via serial connector (programming connector). My idea to decode the protocol is to capture serial packets sent from winload (default paradox programming software).
How you have connected the paradox serial connector to the PC/Arduino serial port?
Yes, I have. I tried to look at the packets sent by Paradox, but somehow forsaken this activity :~
I cannot comunicate with the alarm system. Can you help me? The pcb serial is RS232 or RS485? I can comunicate directly from a PC serial or I need an interface? My PC mount a RS232/485 card.
You need only simple RS232 To TTL Converter for communication between Paradox and computer.
Thank you. I have built the pcb and the comunication is working.
Very good. It's time to decode the packets. But the question is HOW? :)
I have the Paradox programming software (Winload). I try to sniff the packets. I have also received from Paradox the ASCII and CBUS protocol documentation. I don't know if the data exchanged via serial connector uses one of this protocol specifications. If needed I can send to you the documents.
It would be great to get these documents.
Thomas80,
Have you managed something?
I tried to sniffer this system’s serial interface and found that one packet length is 37 bytes. The first 6 bytes are always the same. When zone status changes then the 9th byte is zone number. From 16th to 31th is reported zone’s name. What means other bytes I have not managed yet.
And found similar testing on the web in Martin's blog: http://harizanov.com/2013/05/interfacing-with-paradox-home-security-system
Hi I have SP6000 Paradox. I use the babyware software and I have a simple usb-ttl converter to communicate.
Byte 8: zone status. If==0 zone is closed if==1 zone is opened Byte 9: zone number Byte 10: partition of the current zone. I made a program, and I can see the status of the zones on PC. I tryed to monitor the serial port to know what the other bytes mean, but it's difficult. I would like to manage all the functions of the system. Arm, disarm, alarm, troubles atc....
An update: Byte 1: unknown Bytes from 2 to 3: year Byte 4: month Byte 5: day Byte 6: hour Byte 7: minutes Byte 8: zone status. If==0 zone is closed if==1 zone is opened Byte 9: zone number Byte 10: partition of the current zone Bytes from 16 to 31: zone’s name ...
Hello, I am playing with Spectra 1738 panel. Connected the serial port to my Debian server using RS232 to USB converter. The boud rate I am using is 9600. But can see only 7 bytes sent when an event is triggered. It seems the bytes differ from the ones Mauzer described. Here is a sample of what I am dumping: (the first value is the time i inserted - not from the Paradox system) 1381052775 11 5b b0 8 1 5b b0 1381052775 11 5b b0 8 11 5b b0 1381052795 81 60 0 8 1 60 0 1381052795 81 60 0 8 11 60 0 1381052799 41 60 0 8 1 60 0 1381052799 41 60 0 8 11 60 0
It seems the 5th byte reports sensor state.
Just in case anyone is still looking for this, you can find the protocol doc for the Digiplex online. The file name is, "DIGIPLEX-ASCII-EP00-eng.pdf". (Sans quotes.)
For example: http://www.elektro-mahl.cz/dokumenty/DIGIPLEX/DIGIPLEX-ASCII-EP00-eng.pdf
You need to have the PRT3 module in, and configured to, "Home Automation," mode. Hope this helps. :)
An update: Byte 1: packet beginning?? Bytes from 2 to 3: year Byte 4: month Byte 5: day Byte 6: hour Byte 7: minutes Byte 8: zone status. If==0 zone is closed if==1 zone is opened Byte 9: zone number Byte 10: partition of the current zone Bytes from 16 to 31: zone’s name ... Byte 37: 1 byte checksum
Which kind of Spectra, 1738?
SP7000
