Interference in the ADC
Hi all! I am using an arduino nano with an atmega328p for voltage readouts (ADC). I have very large interference (change in the ADC value by 40 values), although I measured it on an accurate voltmeter, everything is in order with the voltage (it is stable). What could be wrong? I use an ADC measurement with a range of 0 - 1.1V (0...1024).
upload a schematic showing the wiring? show the analogue and digital grounds and how you power the system
upload the program (using code tags </>)
If you want reasonably reliable results you may find it useful to read this:
If your circuit has anything more than this
then other components may be introducing noise.
So the first step would be to disconnect everything except the supply and the voltage source.
And the next step would be to look at the voltage input AND the supply voltage with an oscilloscope. A DVM will not tell you if a voltage is stable.
Please provide the basics - a schematic, a photo and your code.
It's a 10-bit ADC, so you're seeing changes of 40 over a range of 1024 - that's under 4%.
A voltmeter will average over a (relatively) "long" time - so it probably won't see noise that the ADC does see.
Try averaging your ADC samples over a similar time...
OP's Full Scale: 1.1V
Resolution: 1.1V/1024 = 1.07 mV
ADC Error: +/- 2 LSB ==> 2.14 mV
So, a reading must flactuare within n+/-3.
Try putting 0.1uF capacitor at the input of the ADC channel. Also, include the following line in the setup() finction.
analogReference(INTERNAL);
Please, post your sketch.
