Hi everybody! I had a task to take values from the ADC on the arduino nano ATmega168PA. I noticed that the ADC value changes in the range of 40 values while the voltage on the multimeter is stable. What could be? How to overcome the noise problem?
Please show your test code and connection diagram
Smooth the raw data as your multimeter did.
// Подключаем библиотеки
#define F_CPU 16000000UL
#include <avr/io.h>
#include <util/delay.h>
#include <math.h>
#include <avr/interrupt.h>
// Define pins
#define HEATER_PIN PB0 // Heater pin (relay on/off)
#define CHECK_PIN PB1 // LED RED
#define TEMP_PIN PC2 // Temperature sensor pin PC2
// Define variables
//volatile float temp; // Current temperature in Celsius
volatile float u; // Control signal
volatile float I=0; // Integral component
void initADC()
ADMUX = (1 << REFS1) | (1 << REFS0) | (1 << MUX1) ; // Select internal 1.1V reference and ADC5 channel
ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // Enable ADC, set prescaler to 128
// Initialize timer
void initTimer()
TCCR1A = (1 << WGM01); // Set CTC mode
TCCR1B = (1 << CS01) | (1 << CS00); // Set prescaler to 64
OCR1B = 0x61A8; // Set compare match value to 25000, 100ms
TIMSK1 = (1 << OCIE1B); // Enable compare match interrupt
// Interrupt service routine for timer compare match
ISR(TIMER1_COMPB_vect)
uint16_t adcValue; // ADC value variable
ADCSRA |= (1 << ADSC); // Start ADC conversion
while(ADCSRA & (1 << ADSC)); // Wait for conversion to complete
adcValue = ADCW; // Read ADC value
Serial.println(ADCW);
// Main function
int main(void)
DDRB |= (1 << HEATER_PIN); // initialization of the pin (heater) to the output
DDRB |= (1 << CHECK_PIN); // initialization of the red test LED
// Set the PC2 pin to read
DDRC &= ~(1 << TEMP_PIN);
// Turn on the internal pull-up resistor on pin PC2
PORTC &= ~(1 << TEMP_PIN);
initTimer(); // Initialize timer
initADC();
sei(); // Enable global interrupts
while(1)
// Do other tasks if needed
return 0;
How to do it? I posted my code.
Hello roman_arduino
Take a view to gain the knowledge:
Your code is way overcomplicated. Why all this dances with registers, if finally your code is almost equivalent to this:
analogReference(INTERNAL);
Serial.println(analogRead(A0));
delay(100);
You use 1.1v reference, so the 40 units of ADC is only +/-0.02v. Your multimeter may not notice this changes.
And how then to configure the program? I wanted to take values in the range from 0 (0 ADC value) to 1.1 volts (1023 ADC value).
Blocking code and serial I/O in interrupt context - going for all the no-nos, huh?
What do you need to configure?
I need that at approximately constant voltage, the ADC value shows more or less the same value.
I think this has nothing to do with your program and its configuration.
The voltage variations has a completely external cause.
