I am trying to get a Rotary Encoder encoder to work on the Nano R4 processor. However, in all the official documents I can not see (or find with a search) any mention of interrupts.
However, when I download the User Manual Hardware direct from the Reneas Web site I find there are 132 pages that mention them.
I conclude that the official documentation from Arduino is totally inadequate, in this regard at least.
Well at least a third of it is not in Chinese like the Nano 328P one!
(Perhaps someone needs to finish the translation?)
I think the "datasheet" on the Arduino site is a datasheet for the board, whereas the one on the Renesas site is the datasheet for the actual MCU. Likely the Arduino one tells you about the board itself, but if you want to dig deeper then you have to go find the MCU manufacturer datasheet for the specific MCU. One is probably meant to look at both in conjunction with each other. Hopefully someone will clarify.
FYI.
I used the library EncoderButton with a NANO, and it worked well. Although some comments in the code mention interrupts, I looked through the library code and do not see any use of interrupts. I have not tested with the NANO R4.
Unfortunately, Renesas put their own weird interrupt system (the ICU) on top of what is essentially a CM0-style NVIC (32 vectors worth.) The ICU arbitrarily multiplexes close to 200 possible "Events" onto the 32 NVIC vectors.
So "attaching" an interrupt to an event is more complicated than a basic M4 NVIC configuration - basically you have to find a free NVIC slot, and then set up the ICU to bind that slot to the desired event.
I believe that the Arduino void attachInterrupt(pin_size_t pinNumber, voidFuncPtr func, PinStatus mode) does all of this, for pins on which interrupts are permitted. Except that I'm not sure which pins those are, since it looks like the Renesas "core" was written by ... someone at Renesas? It's dramatically different than any of the other ARM cores (and ugly, IMO. With a lot of confusing indirection.)
Oh! I see. This data is in ...variants/*/pinmux.inc ! My tools didn't see it since it doesn't have a usual source-file extension... (IDE 2 can't find it either.)
I am very disappointed that no Arduino Team member has not made a comment on this point. As I see this as a major fault with the documentation. When I try and run code on the Nano R4 board I get this
FQBN: arduino:renesas_uno:nanor4
Using board 'nanor4' from platform in folder: /Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
Using core 'arduino' from platform in folder: /Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1
Detecting libraries used...
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/Basic.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/sketch/Basic.ino.cpp -o /dev/null
Alternatives for Encoder.h: [Encoder@1.4.4]
ResolveLibrary(Encoder.h)
-> candidates: [Encoder@1.4.4]
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/Basic.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/sketch/Basic.ino.cpp -o /dev/null
Error while detecting libraries included by /Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/sketch/Basic.ino.cpp
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/Basic.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -I/Users/mikecook/Documents/Arduino/libraries/Encoder/utility -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.cpp -o /dev/null
Error while detecting libraries included by /Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.cpp
Generating function prototypes...
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/Basic.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/ABDA15FD3C58E87685BEA9EBF8C976BD/sketch/Basic.ino.cpp -o /private/var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/1381402581/sketch_merged.cpp
In file included from /Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:46:0,
from /Users/mikecook/Documents/Arduino/Nano A4 software/Encoder/examples/Basic/Basic.ino:7:
/Users/mikecook/Documents/Arduino/libraries/Encoder/utility/interrupt_pins.h:390:2: error: #error "Interrupts are unknown for this board, please add to this code"
/Users/mikecook/Documents/Arduino/libraries/Encoder/utility/interrupt_pins.h:393:2: error: #error "Encoder requires interrupt pins, but this board does not have any :("
/Users/mikecook/Documents/Arduino/libraries/Encoder/utility/interrupt_pins.h:394:2: error: #error "You could try defining ENCODER_DO_NOT_USE_INTERRUPTS as a kludge."
exit status 1
Compilation error: exit status 1
Can I remind all posters that this is a "Nano R4 board" I am talking about and not any other sort of of Uno R4 board.
I am setting up some new hardware to continue to test this out further.
More accurately, this is what you get when you try to use the 3rd party "Encoder" library. You will not get this error when compiling any code that does not use the Encoder library
The 3rd party Encoder library has architecture-specific code, so explicit support for each board architecture must be added to the library, rather than happening as a matter of course as occurs for libraries that only use the high level universal Arduino core API.
Support for the Renesas RA4M1-based UNO R4 Minima and UNO R4 WiFi boards has apparently already been added to the library:
So hopefully that indicates the addition of support to the library for the Nano R4 will be trivial.
This does not appear in any search I do. As you can see it defines pins 2 and 3 as external interrupts as Special Features. So how do I enable those special features?
AttachInterrupt() should do it, just like on any other Arduino...
yeah, Paul (of PJRC; author of the encoder library) writes nice, efficient, and clever code, but seems to be a bit careless about the idea of "easily portable/compatible to/with new platforms.") The interrupt code in the encoder library is ... really ugly.
I came across this in the documentation
Those are just the "normal" Arduino functions for those pins, aren't they? The Nano changes the form factor, but generally keeps most of the same functions on the same "Arduino pin numbers" as an Uno-like board...
So I got the latest version Encoder-1.4.4
I selected the No interrupts version and got the following error message:-
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/NoInterrupts.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/sketch/NoInterrupts.ino.cpp -o /dev/null
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/NoInterrupts.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/sketch/NoInterrupts.ino.cpp -o /dev/null
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/NoInterrupts.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -I/Users/mikecook/Documents/Arduino/libraries/Encoder/utility -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.cpp -o /dev/null
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/NoInterrupts.ino" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/sketch/NoInterrupts.ino.cpp -o /private/var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/1143218653/sketch_merged.cpp
/Users/mikecook/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/1143218653/sketch_merged.cpp
Compiling sketch...
/Users/mikecook/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -Wall -Wextra -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DARDUINO_NANO_R4 -DARDUINO_UNOR4_MINIMA -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/NoInterrupts.ino\"" -DARDUINO_nanor4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/tinyusb -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino/api/deprecated-avr-comp -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/cores/arduino -I/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4 -I/Users/mikecook/Documents/Arduino/libraries/Encoder -iprefix/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1 @/Users/mikecook/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.5.1/variants/NANOR4/includes.txt /Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/sketch/NoInterrupts.ino.cpp -o /Users/mikecook/Library/Caches/arduino/sketches/D1F7950AB046945C064EC94CC24E73FE/sketch/NoInterrupts.ino.cpp.o
In file included from /Users/mikecook/Desktop/Encoder-1.4.4/examples/NoInterrupts/NoInterrupts.ino:14:0:
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:68:11: error: 'IO_REG_TYPE' does not name a type
volatile IO_REG_TYPE * pin1_register;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:69:11: error: 'IO_REG_TYPE' does not name a type
volatile IO_REG_TYPE * pin2_register;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:70:2: error: 'IO_REG_TYPE' does not name a type
IO_REG_TYPE pin1_bitmask;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:71:2: error: 'IO_REG_TYPE' does not name a type
IO_REG_TYPE pin2_bitmask;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h: In constructor 'Encoder::Encoder(uint8_t, uint8_t)':
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:89:11: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
encoder.pin1_register = PIN_TO_BASEREG(pin1);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:89:27: error: 'PIN_TO_BASEREG' was not declared in this scope
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:89:27: note: suggested alternative: 'ITM_BASE'
ITM_BASE
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:90:11: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
encoder.pin1_bitmask = PIN_TO_BITMASK(pin1);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:90:26: error: 'PIN_TO_BITMASK' was not declared in this scope
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:90:26: note: suggested alternative: 'PIN_USE_MASK'
PIN_USE_MASK
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:91:11: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
encoder.pin2_register = PIN_TO_BASEREG(pin2);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:92:11: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
encoder.pin2_bitmask = PIN_TO_BITMASK(pin2);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:99:31: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
if (DIRECT_PIN_READ(encoder.pin1_register, encoder.pin1_bitmask)) s |= 1;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:99:54: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:99:7: error: 'DIRECT_PIN_READ' was not declared in this scope
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:100:31: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
if (DIRECT_PIN_READ(encoder.pin2_register, encoder.pin2_bitmask)) s |= 2;
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:100:54: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:100:7: error: 'DIRECT_PIN_READ' was not declared in this scope
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h: In static member function 'static void Encoder::update(Encoder_internal_state_t*)':
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:303:40: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
uint8_t p1val = DIRECT_PIN_READ(arg->pin1_register, arg->pin1_bitmask);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:303:60: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:303:19: error: 'DIRECT_PIN_READ' was not declared in this scope
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:304:40: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
uint8_t p2val = DIRECT_PIN_READ(arg->pin2_register, arg->pin2_bitmask);
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:304:60: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
Using library Encoder at version 1.4.4 in folder: /Users/mikecook/Documents/Arduino/libraries/Encoder
exit status 1
OK I have made some progress. First I. updated my Mac Software ti the latest MacOS Sequola 15.6.1. Next I permitted access to Discourse to allow it to access my computer for updates, Finally I ran the NoInterrupts code again and got this error message when I tried to compile it.
Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:76:7: warning: type 'struct Encoder' violates the C++ One Definition Rule [-Wodr]
class Encoder
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:76:7: note: a different type is defined in another translation unit
class Encoder
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:157:10: note: the first difference of corresponding definitions is field 'interrupts_in_use'
uint8_t interrupts_in_use;
/Users/mikecook/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/arduino_build_486633/NoInterrupts.ino.elf /var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/arduino_build_486633/NoInterrupts.ino.eep
/Users/mikecook/Documents/Arduino/libraries/Encoder/Encoder.h:76:7: note: a type with different number of fields is defined in another translation unit
class Encoder
Any other comments other than I told you his code was not very good and portable?
The version 1.4.4 of encoder.h available in the Arduino library manager does not appear to match the current version of encoder.h in github Encoder/Encoder.h at master · PaulStoffregen/Encoder · GitHub (as I now see @westfw has already pointed out). Changes were introduced on 13.03.2024 in the Github repository including several lines for the UNO R4 WIFI and Minima which are not present in the library manager version. Change details: pin register · PaulStoffregen/Encoder@063b390 · GitHub
I'll provide you with a copy of the library that already has the necessary changes. Please do this:
A. Remove existing installation
Select Sketch > Include Library > Manage Libraries... from the Arduino IDE menus to open the "Library Manager" view in the left side panel.
Type Encoder in the "Filter your search..." field.
Find the "Encoder" entry in the list of search results.
Hover the mouse pointer over the "Encoder" entry.
You will see a ●●● icon appear near the top right corner of the library entry. Click on that icon.
A context menu will open.
Select "Remove" from the menu.
An "Uninstall" dialog will open.
Click the "YES" button in the "Uninstall" dialog to confirm that you want to uninstall the library.
The dialog will close.
Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
ⓘ Successfully uninstalled library ...
B. Install variant of library with Nano R4 support
Click the following link to download the variant of the library that has the changes I described above: Encoder.zip (18.4 KB)
Wait for the download to finish.
Select Sketch > Include library > Add .ZIP Library from the Arduino IDE menus.
The "Select the zip file containing the library you'd like to add" dialog will open.
Select the downloaded file from the dialog.
Click the "Open" button.
Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
If your encoder is connected to pins other than 5 and 6, adjust the arguments in the begin call on line 8 in the sketch accordingly. For example, if you encoder was connected to pins 2 and 3, you would change the code from:
myEnc.begin(5, 6);
to this:
myEnc.begin(2, 3);
Upload the sketch to your Nano R4 board.
Wait for the upload to finish successfully.
Open Serial Monitor.
Rotate the encoder.
We would now expect to see numbers printed to Serial Monitor, incrementing or decrementing depending on which direction you turn the encoder.
I don't have access to a Nano R4, but it does work as expected for me with the similar UNO R4 Minima board.
Please let us know if you have any questions or problems while following those instructions, just let us know and we'll provide further assistance.
