I am trying to use the HidProxWeigand library from github with 2 HID iclass readers on a Zero.
The code works fine with one reader, but when a second reader is used only one or the readers outputs any data.
Can someone please help me with why this doesn't work.
Thank you.
Advanced HidProxWiegand usage example.
#include <Arduino.h>
#include "HidProxWiegand.h"
#define PIN_RDR1_DATA0 2 // The pin to use for reader 1, DATA 0.
#define PIN_RDR1_DATA1 3 // The pin to use for reader 1, DATA 1.
#define PIN_RDR2_DATA0 5 // The pin to use for reader 2, DATA 0.
#define PIN_RDR2_DATA1 6 // The pin to use for reader 2, DATA 1.
// Reader 1 outputs.
//#define PIN_RDR1_BUZZER 6
//#define PIN_RDR1_GREEN_LED 7
//#define PIN_RDR1_RED_LED 8
//Reader 2 outputs.
//#define PIN_RDR2_BUZZER 9
//#define PIN_RDR2_GREEN_LED 10
//#define PIN_RDR2_RED_LED 11
ProxReaderInfo* reader1; // Card reader 1.
ProxReaderInfo* reader2; // Card reader 2.
// Callback for handling card reads from reader 1.
void cardRead1Handler(ProxReaderInfo* reader) {
Serial.print(F("Card read: "));
Serial.print(reader->facilityCode);
Serial.print(F(":"));
Serial.println(reader->cardCode);
// Here you can add logic to see if the card that was read was actually
// valid or whatever. For example: reading stored card numbers from EEPROM
// and looking for a match. Ideal for access control applications.
// This would also be where you would want to change state of the buzzer
// and LEDs on the reader.
//digitalWrite(PIN_RDR1_BUZZER, HIGH);
//digitalWrite(PIN_RDR1_RED_LED, LOW);
//digitalWrite(PIN_RDR1_GREEN_LED, HIGH);
//delay(500);
//digitalWrite(PIN_RDR1_BUZZER, LOW);
//digitalWrite(PIN_RDR1_GREEN_LED, LOW);
//digitalWrite(PIN_RDR1_RED_LED, HIGH);
void cardRead2Handler(ProxReaderInfo* reader) {
//digitalWrite(PIN_RDR2_BUZZER, HIGH);
//digitalWrite(PIN_RDR2_RED_LED, LOW);
//digitalWrite(PIN_RDR2_GREEN_LED, HIGH);
//delay(500);
//digitalWrite(PIN_RDR2_BUZZER, LOW);
//digitalWrite(PIN_RDR2_GREEN_LED, LOW);
//digitalWrite(PIN_RDR2_RED_LED, HIGH);
// Handle interrupt for reader 1, DATA 0.
void handleInterrupt0() {
if (reader1 != NULL) {
reader1->ISR_Data0();
// Handle interrupt for reader 1, DATA 1.
void handleInterrupt1() {
reader1->ISR_Data1();
// Handle interrupt for reader 2, DATA 0.
void handleInterrupt2() {
if (reader2 != NULL) {
reader2->ISR_Data0();
// Handle interrupt for reader 2, DATA 1.
void handleInterrupt3() {
reader2->ISR_Data1();
while (!Serial) {
delay(10);
// Create the readers and attach them to the system.
reader1 = HidProxWiegand.addReader(PIN_RDR1_DATA0, PIN_RDR1_DATA1, cardRead1Handler);
reader2 = HidProxWiegand.addReader(PIN_RDR2_DATA0, PIN_RDR2_DATA1, cardRead2Handler);
// Attach interrupt handlers for readers 1 and 2.
HidProxWiegand_AttachReaderInterrupts(PIN_RDR1_DATA0, PIN_RDR1_DATA1, handleInterrupt0, handleInterrupt1);
HidProxWiegand_AttachReaderInterrupts(PIN_RDR2_DATA0, PIN_RDR2_DATA1, handleInterrupt2, handleInterrupt3);
// Init reader 1 outputs.
//pinMode(PIN_RDR1_BUZZER, OUTPUT);
//pinMode(PIN_RDR1_GREEN_LED, OUTPUT);
//pinMode(PIN_RDR1_RED_LED, OUTPUT);
// Init reader 2 outputs.
//pinMode(PIN_RDR2_BUZZER, OUTPUT);
//pinMode(PIN_RDR2_GREEN_LED, OUTPUT);
//pinMode(PIN_RDR2_RED_LED, OUTPUT);
// Process any cards that have been read.
HidProxWiegand.loop();
