This is a very large sketch and I cannot strip it down to the 120000 character limit. The snipit that I posted is sufficient to demonstrate the problem in my version of the IDE. I don't know how to answer your request. The best I can do is to give you up to void (setup) {
Dale Gloer
[code]
// Simple Wifi Throttle
// Version 4.3 Geoff Bunza 2018
// modified heavily by Phil Abernathy
// Feb 6 trying to get wifi ip as an input from the controls when starting up.
// Feb 8 trying to get new address scheme to work...
/* Feb 15- changes from SWIFT#2 for SWIFT#1
- Feb17
- changed all reading of function switches to the function call where it can be changed if needed.
- Added + 10 to setting address: bell & lights off = +/- 1
bell off lights on = +/- 10
bell on lights off = +/- 100
bell & lights ON = +/- 1000
- Feb 19, changed all necessary variables and constants to arrays of integers, use zero as throttle #1, 1 for #2, etc
- (This was necessary because I did not build each of my three SWIFTS using the same pins. I also found that I physically installed some switches
- ...Lights...horn...upside down so I merely swapped the functions)
- Feb 20 made tname into array, so only ThrottleNum needs to be changed
deleting extra code that was left while testing...
- Feb 23, added estop and accel/braking to throttles
basically, the oh-so-wierdly complicated code in Need for Speed is done to closer simulate notching and braking. When at speed, if switched to NEU, the Speed knob
becomes a brake (can only slow down, cannot speed up in NEU). But it will slow down quicker in NEU than in FWD or REV when Speedknob goes to 0.
- March 8, added !quit as loop requirement to allow throttle to gracefully disconnect from server. However, JMRI handles restarting the throttle very well regardless.
- March 9 added roster for choosing loco number.
- March 10, dressing up and changing-
- March 11-13 added code to investigate end of line characters in client messages-JMRI seems to use CR LF CR LF. Cannot get LNWI to communicate.
- March 21-added code to start heartbeat monitor in server (sends "*+"), and added send heartbeat function calls (where the throttle name is sent to server) in all "while"
loops.
(note to REAL programmers, don't judge...I got my Associates degree in Electronics Technology in 1985 and that was my last formal training, although I did take
Cobol 1 & 2 and "370 Assembler" classes)
Heartbeat is set in WiThrottle Preferences (defaults to 10 seconds) but once throttle dissappears, with 10 sec heartbeat, it takes about 11 seconds
before JMRI estops the loco and about 17 before dropping all communication.
- March 26. Funny, after adding comments and trying to document, I realize how much I don't know but put into code by using Google searches for examples.
"indexOf" for example: I kinda' know, but would have tp look it up again.
- March 27 added heartbeat color to print colon in display (next to Speed colon) as heartbeat.
added display "-" if heartbeat failed at all, clear it if success. Coded to QUIT after 2 or more fails.
- March 29 revised code in effort to streamline loop to avoid missing functions...
- March 30 -added fastclock code.
- March 30 add initial power on option to display fastclock instead of direction if DIM switch is active at power on.
- March 30/31-added track power on and power off awareness and displayed status if off
- April 1-3 added code to allow fastclock to be used without Internet connection. The board has a timer so I get the fastclock and subtract it from the board time,
then use the difference added to the board time to display as fast clock time.
- April 3- added code to allow a momentum factor to be introduced. heavy and HEAVIER are two levels, displayed with h or H, and set/reset: Neutral, Bell off, Dim, full throttle
then shorthorn for heavy (or if heavy already to HEAVIER). Horn reduces the momentum from HEAVIER to heavy, or from heavy to no extra momentum.
Also revised throttle speed code to be more reactive to higher throttle by looping faster because difference between throttle and speed is used
(actually, eighth or quarter of the difference).
- April 5- added code for fourth SWIFT (BlackSWIFT3)
changed battery chack to be called each time that the time is displayed (1/second), and added string for < 10 so 10+ doesn't leave remnant displayed when
battery falls below 10
- April 13-added code for indicating that the track power is off while selecting/acquiring new loco. Cleaned up screens when estop is active (avoided clock display)
- April 14-revised code to change the 1/4 speed mode on or off. With Neutral, Bell off, Lights on, not Dim and full throttle, ShortHorn turns on, Horn turns off.
- April 14 or so, changed code to allow FastClock display (in lieu of FWD/REV) Neutral, Bell ON, Lights off and full throttle, ShortHorn turns on, Horn turns off.
- April 15-added code to only display the battery voltage message if the throttle has a battery voltage resistor set up. Saved as array, then assigned to disp_battery variable
- added code to allow skipping of the IP addresses stored in the sketch and enter new by keeping REV when logging into SSID.
- April 20-adding code to allow new design with notching selector instead of Speed Pot. Not sure how to incorporate yet, so I will try then test.
- April 20-adding code to allow use of additional switch for "Run/Dispatch".
- April 22-added code for plus weight momentum (more than none, leass than heavy).
- April 22-added code to allow the notching throttles to increase or decrease the speed of each notch by up to 8
when 0 speed, in Neu, full notching, Bell ON & Dim, then the shorthorn increases (notch 1-1 up by 1, but only to 8) while
horn decreases (notch 1-7 down by 1, but only to where notch 1 is 1)
- April 25-changed code to say relknob (for relative position of knob) when using knob settings. Changed from reqspeed for most of
the sketch except the need for speed.
- June 4 - Starting to modify the code to eliminate the deprecated "T" commands to the command station and make them "M" commands.
- June 5 - Code working for multi throttle, but has issues with steal, and "Not Set" in WiThrottle Window. Also fails to re-connect to custom
input ssid/password/server IP.
- June 7 - Added code when dispatching to set velocity to 0 and release all locos from throttle. Solved "Not Set" messages.
- June 10-11-changing code for entering wifi and ip.
- June 14-16 Changed display of loco to be the name stored in the roster when chosen from the roster, or the address if not. Shortened dislay if battery monitor is active.
- June 14-16 Cleaned up some left-over code and sped up the loop slightly. Fixed timing issue when selecting characters in the SSID. Doubled up the connection attempts
for new server IP addresses that might be slow to report connection.
- June 17-got an LNWI for testing-failed immediately because the heartbeat (identified on my phone using Engine Driver) is 90 seconds, and SWIFT has it as 10.
- June 18-found that LNWI does not use the "f" force function value. Also, using the F1 works all the time, however, the horn and shorthorn use F1 and F0, but the
bell, lights and dimming don't like that so I added code to differentiate. Also I could not get the old functions to read in, so the bell, horn, lights or
dimming would have be opposite until fixed (if they are on when starting the loco). I worked on the code for starting a new loco to use existing state and
changng what I need to match how the switches are set when starting.
I added lots of debug printing to the serial monitor in the Arduino environment.
I have an awful time connecting to the LNWI, and it seems like every other try, it works. Hmmm, I've heard about that but not what the fix is.
I changed the array for sign-in ssid, password and server ip to have the LNWI listed twice. If if fails the first time, it connects the 2nd.
I changed the loop code to always read the client output and use it/display it to the debug serial monitor. I shortened the code run
during the heartbeat and used the loop client read to confirm heartbeat from the server.
- August-added code for starting and shutting down Paragon2 decoders. Two locos (1563 and 1863) have Paragon2 and always come up shutdown when track power is started
(or interrupted). Added the F9 on when acquiring, and toggle F9 when dispatching.
- August 18, looking at possible OTA code. Added new one to list, although not physically built
- Throttle Layout:
___________________________
- | TB TA | TB is Bell; TA is lights with UP=On, center off=on but dim
- | OLED DISPLAY |
- | OLED DISPLAY |
- | OLED DISPLAY |
- | TDir (PB) SpeedPot | PB is momentary; Horn (DOWN), TC=ShortHorn (UP)
- |__________________________|
// Usage:
// Turning Power On requests a Loco Address change
// 1. display will change -- direction indicates addr up or down
// 2. Setting Direction SW to center/neutral for about 1 second gets out of address set mode
// 3. Setting Lights to DIM before turning on sets the display to FastClock instead of direction
// 4. Setting Bell ON before turning on sets the start mode to "heavy" (momentum, with "h" in speed box)
// While running a train:
// Setting Bell off, Lights ON, Direction to NEUTRAL, SpeedPot full ON and ShortHorn makes 1/4 throttle for switching,
// Setting Bell off, Lights ON, Direction to NEUTRAL, SpeedPot full ON and Horn will change from 1/4 to FULL throttle available
// Setting Bell ON, Lights ON, Direction to NEUTRAL, and SpeedPot full ON will toggle the MUTE function (F8) on decoder.
// Setting Bell OFF, Lights to Dim, Direction to Neutral, SpeedPot full on with ShortHorn increases Momentum to h, or to H if h.
// Setting Bell OFF, Lights to Dim, Direction to Neutral, SpeedPot full on with Horn decreases Momentum to normal, or to h if H.
// While DISPATCHED, with Bell & Lights ON, and SpeedPot full ON, REV will turn track Power OFF via JMRI
// While DISPATCHED, with Bell & Lights ON, and SpeedPot full ON, FWD will turn track Power ON via JMRI
// While DISPATCHED, with Bell Off, Lights ON DIM, Direction to REV, and SpeedPot full ON will offer QUIT?,
// - Lights Off "quits" the server and disconnects from JMRI, however turning lights ON stays connected to JMRI server.
// When turning on, several options are available. Normally, all functions are OFF and Direction switch in Neutral, Speed pot off (full CCW).
// The sequence of normal startup is that it will use the 1st pre-programmed WiFi and Password to try to connect. A count will progress on the display
// with "Trying wifi..." and "FWD to try next" messages until it either connects to the wifi or the Direction lever is moved to FWD.
// If not connected, when Direction lever is in FWD, "NEU to try" and the next WiFi SSID will be shown. This contiunues for the 4 or 5 pre-programmed
// WiFi SSID and password combos.
// - Once connected, it looks for the JMRI server by trying (one at a time) the 3 pre-programmed IP addresses in the sketch (with the
// message "looking for port".
// - If the IP address is known to not be in the three pre-programmed, immediate REV will skip those three just as if no
// server is found (to allow manual entry). If no server is found, it falls through to manual entry of the IP address with "192.168." as a start, and the remainder
// to be added. The display says "New IP-Bell Sets" and in Neutral, the Speed Knob rotates through the pre-defined (allowable) characters. Using REV
// locks the display, and Horn adds the character to the string. When the IP is built to satisfaction (or a mistake is made like I do some times),
// turning the bell on submits the now complete IP address to the sketch to try to connect to the server. On the display, it shows the actual IP
// that it is trying to connect to. If it does not find a server, it throws up and eventually comes back to manual IP entry.
// To manually enter a new SSID/password (such as when visiting a foreign railroad not included in the sketch), before turning ON, turn the Direction lever to
// FWD and hold the ShortHorn ON. It will say "newSSID, Bell set" with "addon: " and a character in the bottom line. With the Direction lever in Neutral,
// the Speed knob rotates through all the pre-programmed (allowable) characters that can be added to the SSID. REV locks the character, and Horn adds
// it to the string being built in the middle line. When the string is built to satisfaction (or a mistakes is made-there is no backspace) turning the
// Bell Switch ON changes to "Pswd,lights set" and the password can be built a character at a time (Neu, spin to the char needed then REV and Horn to
// add the character to the string being built). When the string is built to satisfaction (or a mistakes is made-there is no backspace) turning the
// Light Switch ON submits the SSID and Password to the sketch to try to connect. If it connects, it falls through to NEW IP, otherwise it just counts up
// until REV is triggered to re-enter a new SSID. The manually entered SSID, Password and IP address are stored in the EEPROM for reuse later.
// If a manual entry has been made, it can be recalled from EEPROM (and used) upon re-starting by FWD and Horn when turning on. Very handy for visiting and
// the throttle is turned off, or battery dies.
// If a manual entry has been made, the SSID and Password can be recalled from EEPROM and only require the IP address by FWD, Full Speed, ShortHorn while turning on.
// Useful for when IP address of server has changed on the server since programming was done (I have no idea why the IP address of the server would change
// from one visit to the next, but it has...).
// At startup (power on of throttle), if DIM Switch is ON, the Fast Clock (as sent by the server, using computer time if not othwerwise set) is displayed instead
// of direction.
// At startup (power on of throttle), if Bell is ON, the throttle is started in heavy mode (with momentum programmed in)
// When MUTE wait screen is active, Direction Lever FWD displays Fast Clock time
// When Dispatched, DIM and ShortHorn will display the Fast Clock time.
// WiFi Server Definitions ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
const int tpPort = 12090;
char ssidchar [20] = "anything" ;
int ssidstrlen ;
char pwordchar [20] = "something" ;
int pwordstrlen ;
int mystringlen ;
int prom_address_start ;
// 2 dim array[rows][elements] each line is one wifi ssid (and password), and three IP addresses to be checked for the server at that ssid
String serverstrs [5][5] = {{"JMRI\0", "\0", "192.168.254.15\0" , "192.168.254.2\0" , "192.168.254.3\0"},
{"jmri\0", "\0", "192.168.0.100\0" , "192.168.0.101\0" , "192.168.0.101\0" },
{"Dtx1-LnServer_0007-7\0", "digitrax1234\0", "192.168.7.1\0" , "192.168.8.1\0" , "192.168.9.1\0"},
// {"Dtx5-GSMRRHO _0946-7\0", "digitrax1234\0", "192.168.7.1\0" , "192.168.8.1\0" , "192.168.9.1\0"},
// {"Dtx5-GSMRRHO _07CE-7\0", "\0", "192.168.7.1\0" , "192.168.8.1\0" , "192.168.9.1\0" },
{"PhilSue2500-RAV\0", "roger2008\0", "10.10.10.102\0" , "10.21.18.16\0" , "192.168.0.12\0" } };
// {"RAV-FileHub-162E\0", "11111111\0", "10.10.10.222\0" , "10.21.18.16\0" , "192.168.0.12\0" } };
// {"PhilSue\0", "roger2008\0", "192.168.1.128\0" , "192.168.1.132\0" , "192.168.1.100\0" } };
// {"JMRI\0", "\0", "192.168.254.15\0" , "192.168.254.3\0" , "192.168.254.2\0" }
int ipaddressstrlen ;
char ipaddresschar [ 17 ] ;
String LocalIPAddress ;
bool dispbattery = false ;
// Roster can be saved up to 30 locos in this configuration. Each Roster entry is sent as Loco name(String), Loco number(Integer), and Short or Long address (String)
// and is stored in three arrays.
String Lname[ 50 ] = { "BNSF 1000", "SF 8517"};
int Lnumber[ 50 ] = { 1000, 8517 } ;
String Llongshort[ 50 ] = { "L","L" } ;
String LnumberStr ;
String Lnametemp ;
String LocoDispName ;
bool Steal_Required = false ;
bool StealLoco = false ;
String rosterString ;
int heartbeat_timeout ;
bool timeset = false ;
String LtimeHourstr ;
long Ltime ;
long LtimeHour ;
int FastDiffHour ;
String LtimeMinutestr ;
int LtimeMinute ;
int LtimeSecond ;
int oldLtimeSecond ;
String LtimeSecondstr ;
int FastDiffMinute ;
int FastDiffSecond ;
bool FastLocalTimeSet = false;
bool showtime = false ;
char timeStringBuff [50]; // 50 chars should be enough
int tm_hour = 8 ;
int tm_min = 55 ;
int tempLMinute ;
bool DiffSet = false ;
String addressfromclient ;
int lenofaddress ;
String ClientString ;
String oldClientString ;
int ClientStringDelay = 50 ;
String OrigRosterString ;
String rosterEntriesStr ;
String VersionNumberStr ;
bool setfromroster = false ;
int rosterEntries= 0 ;
int rosterNumber ;
String rosterEntry ;
int rosterEntryLen ;
int rosterEntryStart ;
String rosterField ;
int rosterFieldLen ;
int rosterFieldStart ;
String rosterEntryStarter = "[" ;
String rosterEntryEnder = "]" ;
String rosterFieldStarter = "{" ;
String EndLine = "NL"; // carriage return is \r, while newline is \n.
long fastclock = 1553763535L ; // fastclock from Digitrax is number of seconds since 1/1/1970
String fastclockstr ;
#define minsperhour = 60 ; //
#define hoursperday = 24 ; //
String Ltimestr ;
char* localtm ;
long elapsedseconds ;
long elapsedminutes ;
long elapsedhours ;
int fasthour ; // hour to display
String fasthourstr ;
int fastminute ; // minute to display
String fastminutestr ;
int fastsecond ;
String fastsecondstr ;
bool Fclockget = false ;
int DispFastSecond ;
String DispFastSecondstr ;
int DispFastMinute ;
String DispFastMinutestr ;
int DispFastHour ;
String DispFastHourstr ;
bool useheartbeat = false ; // June 17-added to eliminate heartbeat for testing with LNWI
bool heartbeatconfirmed = false ;
int heartbeatfailcount = 0 ;
long HBmillis = 0 ;
long HBcheckmillis = 0 ;
bool HBtimingstarted = false ;
bool commfail = false ;
String heartbeatcolor ="white" ;
- As of August 7, all information needed for each throttle that might be different is listed in this section.
- As of Feb 23, 2019
- throttles built for Phil and Ron (paid and more); Requested by (and paid) Jerry K
- Requested by Tom P (paid), David C, and Ken says no more than TWO (but low priority) for the Depot
//_______________________________________________________________________________________________________________________________________________
//// -Throttle num: Phil=0, WhiteRed=1, DavidC-BlackBlueSwift=2, Jerry-BlackBlackSwift3=3, BlackRedSWIFT=4, Notched=5 |
//// TomSlideWhite=6 RonSlideBlack = 7 ANewOne=8 |
int ThrottleNum = 2 ; // arrays used a zero based numbering so Swift #1 is 0 |
//// Throttle: 0 is Phil, 1 is JimWsWhiteRed, 2 is David's, 3 is Jerry's, 4 is BlackW/RedKnob, 5 is Notched, |
//// 6 is TomsWhiteSlide, 7 is RonsBlackSlide, 8 is a New One |
String tname[ ] = { "SWIFT#0", "JimSWIFTRed#1", "DavidSWIFTBlue2", "JerrysBlackSwift3", "SWIFTRed4", "Notched5", "TomSlide6", "RonSlide7", "NewOneOTA" } ; // zero based numbering
bool flipScreenVertically[ ] = { true, true, false, true, true, false, false, false, false } ;
bool UsingNotches [ ] = {false, false, false, false, false, true, false, false, false } ; // only #5 uses notches...
int NumberOfThrottlesBuilt = 9 ;
// Switch assignment table: Ordered list of function pins
int TDirFwdLow [ ] = { 25, 32, 32, 32, 13, 25, 4, 4, 4 } ; // Forward on direction switch
int TDirRevLow [ ] = { 32, 25, 25, 25, 12, 32, 5, 5, 5 } ; // Reverse on direction switch
int PB [ ] = { 26, 27, 26, 26, 33, 27, 26, 27, 27 } ; // PB: - Horn, was a pushbutton-changed to momentary spdt switch
int TA [ ] = { 4, 5, 5, 2, 5, 5, 2, 2, 2 } ; // TA: - Lights switch
int TB [ ] = { 2, 4, 4, 4, 4, 4, 32, 32, 32 } ; // TB: - Bell
int TC [ ] = { 5, 2, 2, 5, 2, 2, 0, 0, 0 } ; // TC: - Dim
int SH [ ] = { 27, 26, 27, 27, 25, 26, 25, 26, 26 } ; // SH: - ShortHorn
int TD [ ] = { 12, 12, 12, 12, 14, 12, 12, 12, 12 } ; // TD: not used SPDT toggle active HIGH
int TE [ ] = { 13, 13, 13, 13, 15, 14, 14, 14, 14 } ; // TE: not used SPDT toggle active HIGH
int TF [ ] = { 14, 14, 14, 14, 16, 15, 15, 15, 15 } ; // TF: not used SPDT toggle active HIGH
int TG [ ] = { 15, 15, 15, 15, 18, 16, 16, 16, 16 } ; // TG: not used SPDT toggle active HIGH
int ADC_Ch [ ] = { 39, 39, 39, 39, 39, 39, 36, 36, 36 } ; // Center Wiper of 10K Speed Potentiometer Ends=GND & +3.3V
int ADC_Ch2 [ ] = { 36, 36, 36, 36, 36, 36, 39, 39, 39 } ; // Battery monitor through resistor divider 1/4 Ends=ground & center tap not used on SWIFT#1
int OLED_SDA [ ] = { 23, 21, 23, 22, 23, 22, 22, 22, 22 } ; // Data line for I2C OLED Display SDA: SWIFT#1 is 23, RonsSWIFT#2 is 21
int OLED_SCLK [ ] = { 22, 22, 21, 21, 22, 21, 21, 23, 23 } ; // Clock line for I2C OLED Display SCK for both #1 and #2
bool batterymonitor [ ] = {false, true, false, false, false, true, false, false, false } ;
- End of throttle uniqure information.
- August 7, 2019
// adding definition for pins used in notching throttle
int notchpin [ ] = { 13, 14, 15, 16, 17, 18, 19, 3, 1 } ; // notch refers to speed setting on rotary switch (which one is grounded)
int oldnotch ;
int notchsetting = 0 ;
bool NotchedThrottle = false ;
int initialnotchspeed[ ] = { 0, 1, 5, 11, 19, 30, 50, 111, 115 } ;
int notchspeed[ ] = { 0, 1, 5, 11, 19, 30, 50, 111, 115 } ;
#define strobes 1
#define LED_BIRED 16
#define LED_BIGRN 17
#define LED_BIBLU 18
#define LED_BIBLU2 19
#define lshift 2
//Function Assignments
#define F0_pin TA[ThrottleNum] // Function 0 pin assignment = lights
#define F1_pin TB[ThrottleNum] // Function 1 pin assignment = bell
#define F2_pin PB[ThrottleNum] // Function 2 pin assignment = horn
#define F3_pin SH[ThrottleNum] // Function 3 pin assignment = short horn
#define F4_pin TD[ThrottleNum] // Function 4 pin assignment - not used
#define F5_pin TE[ThrottleNum] // Function 5 pin assignment - not used
#define F6_pin TF[ThrottleNum] // Function 6 pin assignment - not used
#define F7_pin TC[ThrottleNum] // Function 7 pin assignment - not used
#define bounce_del 20
String lspeedstr ;
int num_functions = 8; // Number of functions supported by this throttle. Changed TO 8 (MAX) to include dimming (7) when reading new loco
int function_pin [ ] ={ F0_pin,F1_pin,F2_pin,F3_pin,F4_pin,F5_pin,F6_pin,F7_pin }; // Ordered list of function pins
int function_map [ ] ={ 0, 1, 2, 3, 4, 5 , 6, 7}; // this will map the pin list to actual functions
byte function_value [ ]={LOW, LOW, HIGH, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW };
// retained value of each function, more than used by SWIFT but 28 are sent from server
byte setF = 1;
byte setR = 1;
String lastDirection = "N" ; // Feb 2 added to allow neutral and back if in same direction
byte alternate = 0;
byte throttlealternate = 0;
byte LightLoopCount = 0 ;
byte BellLoopCount = 0 ;
byte DimLoopCount = 0 ;
int rawbattery = 0 ;
int relativebattery = 0 ;
String relativebatterystr ;
String batterystr = "..........,,,,,,,,,,,,,,,," ;
int oldrelativebattery = -1 ;
int F8 = 0;
int dispcount = 0; // counting while PB in and loco dispatched...
int wifiTries = 0;
int ipTries = 0 ;
String GetWiFiFrom = "table" ; // table, mem or entry
String GetIPFrom = "table" ; // table, mem or entry
int charposition = 1;
int arrayposition = 0;
int dispHeartbeat_x = 50 ;
int dispHeartbeat_y = 22 ;
int dispLoco_x = 0 ; // x coordinate for Loco to be displayed.
int dispLoco_y = 45 ;
int dispDCC_x = 42 ; // x coordinate for Loco Number to be displayed.
int dispDCC_y = 45 ;
int dispBell_x = 0 ; // x coordinate for Bell On to be displayed.
int dispBell_y = 0 ;
int dispLights_x = 106 ; // x coordinate for Lights On to be displayed.
int dispLights_y = 0 ;
int dispPower_x = 88 ; // x coordinate for Track Power status to be displayed.
int dispPower_y = 45 ;
int dispDim_x = 70 ; // x coordinate for Dim to be displayed.
int dispDim_y = 0 ;
int dispFull_x = 38 ; // x coordinate for throttle limit (1/4) to be displayed.
int dispFull_y = 0 ;
int dispBatt_x = 86 ; // x coordinate for Battery status to be displayed.
int dispBatt_y = 29 ;
int dispPlusMinus_x = 60 ;
int dispPlusMinus_y = 22 ;
String newcharacter;
String oldcharacter;
String wifimsg ;
char newssid[20] ;
String newssidstr ;
String ssidcharacters = "AaBbCcDdEeFfGgHhIiJjKkLlMmNnOoPpQqRrSsTtUuVvWwXxYyZz0123456789-. -";
char newpassword[20] ;
String newpasswordstr ;
String passwordcharacters = "AaBbCcDdEeFfGgHhIiJjKkLlMmNnOoPpQqRrSsTtUuVvWwXxYyZz0123456789-!@#$%^&*()+..";
String newipaddress = "192.168.1.100";
char ipaddress[16];
String newPort = "12090" ;
String ipaddresscharacters = "1234567890...";
bool LocoAssigned = false ;
bool newssidset ;
bool newpasswordset;
bool ipset ;
bool dispatched = true ;
bool runtrains = false ;
bool TurnFunctionOn= false ;
int function_number ;
String function_number_str ;
bool LightSwitchOn = false ;
bool oldLightSwitchOn = false ;
bool dim = false ;
bool olddim = false ;
bool BellSwitchOn = false ;
bool oldBellSwitchOn = false ;
bool hornon = false ;
bool HornDisp = true ;
bool oldhornon = false ;
bool shorthornon = false ;
bool oldshorthornon = false ;
bool mute = false ;
bool mute_displayed = false ;
bool newipset = false ;
bool mutewait = true ;
bool wificonnected = false ;
bool poweron = true ;
String poweronStatus[3] = {"Off","On","Unk"};
bool poweronsent = false ;
bool poweroffdisplayed = false ;
bool estop = false ;
String DirLever = "NEU" ;
bool inNeutral = true ;
bool goingforward = false ;
bool locostopped = true ;
bool goingbackward = false ;
int accellbump = 0 ;
int base_speed_repeat_bump = 6 ;
int base_speed_repeat_coast = 150 ;
int base_speed_repeat_brake = 2 ;
int speed_repeat_bump = base_speed_repeat_bump ;
int speed_repeat_coast = base_speed_repeat_coast ;
int speed_repeat_brake = base_speed_repeat_brake ;
int plusspeed_repeat_bump = 18 ;
int plusspeed_repeat_coast = 180 ;
int plusspeed_repeat_brake = 6 ;
int hspeed_repeat_bump = 50 ;
int hspeed_repeat_coast = 240 ;
int hspeed_repeat_brake = 12 ;
int Hspeed_repeat_bump = 180 ;
int Hspeed_repeat_coast = 360 ;
int Hspeed_repeat_brake = 18 ;
int speed_repeat_ctr = speed_repeat_bump;
bool plusweight = false ;
bool heavy = false ;
bool heavier = false ;
int heavywait = 0;
String heavystr ;
bool quit = false ;
String throttle = "Full" ;
// ******** REMOVE THE "//" IN THE FOLLOWING LINE TO SEND DEBUGGING -- -- -- I did remove that.
// ******** INFO TO THE SERIAL MONITOR
#define DEBUG
// For a connection via I2C using Wire include
#include "SSD1306Wire.h"
#include <WiFi.h>
#include <EEPROM.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
#include <time.h>
#include <sys/time.h>
// Initialize the OLED display using Wire library
SSD1306Wire display(0x3c, OLED_SDA[ThrottleNum], OLED_SCLK[ThrottleNum]); // I2C addr, SDA, SCK for SWIFT#1
boolean testv = false;
int DCC_address;
String LocoString ;
int temp_address;
byte foffset[ ] = {0, 17, 34, 51, 68, 85, 102, 119}; // not used but kept as reference to where digits can be printed.
String fcs[ ] = {"0","1","2","3","4","5","6","7"};
boolean fvalue [ ] = {false, false, false, false, false, false, false, false, false };
int lspeed = 0;
int ltemp = 0;
int rawpot = 0;
int oldrawpot = 0 ;
int throttlediff = 0;
int throttlediff_sixteenth = 0 ;
int throttlediff_eighth = 0 ;
int speedchange = 0;
int reqspeed = 0 ;
int relknob = 0 ;
int oldrelknob1 = 0 ;
int oldrelknob2 = 0 ;
int testrelknob = 0 ;
byte ftn_temp = 0;
int i,j,k,l = 0 ;
String xmits ; // to avoid string space overlap
// String newline = "\n" ;
String newline = "" ; // 7-6-2019 try to eliminate bad message from server due to null line
#define fdelay 1
#define ldelay 250
String jmri_res; //buffer to hold incoming response
int lastread = 0;
long delta = 290;
WiFiClient client;
boolean setaddr;
#define EEPROM_SIZE 64
// Setup starts, Setup starts, Setup starts, Setup starts, Setup starts, Setup starts, Setup starts, Setup starts,
