Hello everybody!, I'm working on a project Forward Kinematics of Differential Drive Robots and Odometry, This is my setup :
- 2 Motor PG28 with Rotary encoder Included 7ppr 16 gearbox ratio.
- 2 BTS7960 with setup 1 Pin PWM and 2 Pin for Forward and Backward.
- Arduino Uno R3 With Pin 2 : Interrupt and 4 : Digital Pin = Motor 1 and Pin 3 : Interrupt and 5 : Digital Pin = Motor 2.
I need my Robot can Drive in 2D Coordinate ( x,y) (0,0) to (15,15) from Point A to Point B but not in 90 degrees line (Green Line). but in Curve line (Rred Line)
Can some one help me with the code please ?,
The input for the robot is X, Y and Tetha and the output is for controling the PWM or RPM for each wheel.
I have been watch this Video Kinematics of Differential Drive Robots and Odometry - YouTube get the equation,
https://drive.google.com/drive/folders/1zhWFlHDuPBDP02ZoSGs2hpzbGMdcg89-?usp=sharing
but i confused implementating the equation in my code for the Right Wheel Velocity and Left Wheel Velocity. Where is the input and whare is the output for PWM. Thak you ![]()
This my code for robot running in 1 Meter :
#define ENCR 2 // WHITE
#define ENR 4 // BLACK
#define PWMR 10
#define INR2 6
#define INR1 7
#define ENCL 3 // GREEN
#define ENL 5 // BLUE
#define PWML 11
#define INL2 8
#define INL1 9
#define PI 3.1415926535897932384626433832795
// PARAMETER RODA
const float driveX = 100; // cm
const float driveY = 100;
const int wheel_d = 80; // Wheel diameter (mm)
const float wheel_c = PI * wheel_d; // Wheel circumference (mm) (KR)
const int counts_per_rev = 104; // (7 pairs N-S) * (16 : 1 gearbox) = 224 (RR)
int power = 75;
int moff = 5;
int pwR = 20 ;
int pwL = 20 ;
volatile int posR = 0; // specify posi as volatile: https://www.arduino.cc/reference/en/language/variables/variable-scope-qualifiers/volatile/
long prevTR = 0;
float eprevR = 0;
float eintegralR = 0;
volatile int posL = 0; // specify posi as volatile: https://www.arduino.cc/reference/en/language/variables/variable-scope-qualifiers/volatile/
long prevTL = 0;
float eprevL = 0;
float eintegralL = 0;
//PARAMETER ODOMETRY
const float wheelDistance = 220;
float meanDistance = 0;
float theta = 0;
float posX = 0;
float posY = 0;
int x = 0;
int y = 0;
int deg = 0;
// KEC 50
// PID constants 1/10 = 0.1
float kpR = 1.1;
float kiR = 0.0008;
float kdR = 0.016;
float kpL = 1.1;
float kiL = 0.0008;
float kdL = 0.016;
// KEC 75
float kpR = 0.68;
float kiR = 0.0008;
float kdR = 0.08;
float kpL = 0.7;
float kiL = 0.0008;
float kdL = 0.08;
pinMode(ENCR, INPUT);
pinMode(ENR, INPUT);
pinMode(ENCL, INPUT);
pinMode(ENL, INPUT);
attachInterrupt(digitalPinToInterrupt(ENCR), readEncoderR, RISING);
attachInterrupt(digitalPinToInterrupt(ENCL), readEncoderL, RISING);
pinMode(PWMR, OUTPUT);
pinMode(INR1, OUTPUT);
pinMode(INR2, OUTPUT);
pinMode(PWML, OUTPUT);
pinMode(INL1, OUTPUT);
pinMode(INL2, OUTPUT);
int drive = driveX + driveY;
if (pwR && pwL <= power) {
pwR += 5;
pwL += 5;
// Calculate target number of ticks
float num_rev = (drive * 10) / wheel_c; // Convert to mm (RPSE)
unsigned long target = num_rev * counts_per_rev;
unsigned long tmm = (num_rev * wheel_c) / 10;
setPID(target);
Odometry();
void setPID(int target) {
// RIGHT WHEEL
long currT = micros(); // time difference
float deltaTR = ((float) (currT - prevTR)) / ( 1.0e6 ); prevTR = currT;
float deltaTL = ((float) (currT - prevTL)) / ( 1.0e6 ); prevTL = currT;
int posiR = 0; noInterrupts(); // disable interrupts temporarily while reading
posiR = posR; interrupts(); // turn interrupts back on
int posiL = 0; noInterrupts(); // disable interrupts temporarily while reading
posiL = posL; interrupts(); // turn interrupts back on
int eR = posR - target; // error
int eL = posL - target; // error
float dedtR = (eR - eprevR) / (deltaTR); // derivative
eintegralR = eintegralR + eR * deltaTR; // integral
float dedtL = (eL - eprevL) / (deltaTL); // derivative
eintegralL = eintegralL + eL * deltaTL; // integral
float uR = (kpR * eR) + (kiR * eintegralR) + (kdR * dedtR); // control signal
float uL = (kpL * eL) + (kiL * eintegralL) + (kdL * dedtL); // control signal
eprevR = eR; // store previous error
eprevL = eL; // store previous error
unsigned long num_ticks_r;
unsigned long num_ticks_l;
unsigned long diff_r;
unsigned long diff_l;
unsigned long enc_r_prev = posR;
unsigned long enc_l_prev = posL;
int pwrR = fabs(uR); // motor power
int pwrL = fabs(uL); // motor power
if ( pwrR && pwrL >= power ) {
pwrR = pwR;
pwrL = pwL;
int dirR = 1; // motor direction
int dirL = 1; // motor direction
if (uR && uL <= 0 ) {
dirR = -1;
dirL = -1;
dirR = 2;
dirL = 2;
setMotorR(dirR, pwrR, PWMR, INR1, INR2); // signal the motor
setMotorL(dirL, pwrL, PWML, INL1, INL2); // signal the motor
Serial.print(" TARGET : "); Serial.print(target);
Serial.print("R_L : "); Serial.print(posR);
Serial.print("R_L : "); Serial.print(posL);
Serial.print("|");
Serial.print("P_R : "); Serial.print(pwrR);
Serial.print("P_L : "); Serial.print(pwrL);
void setMotorR(int dirR, int pwmValR, int pwmR, int inR1, int inR2) {
analogWrite(pwmR, pwmValR);
if (dirR == 1) {
digitalWrite(inR1, HIGH);
digitalWrite(inR2, LOW);
else if (dirR == -1) {
digitalWrite(inR1, LOW);
digitalWrite(inR2, HIGH);
else if (dirR == 2) {
void setMotorL(int dirL, int pwmValL, int pwmL, int inL1, int inL2) {
analogWrite(pwmL, pwmValL);
if (dirL == 1) {
digitalWrite(inL1, HIGH);
digitalWrite(inL2, LOW);
else if (dirL == -1) {
digitalWrite(inL1, LOW);
digitalWrite(inL2, HIGH);
else if (dirL == 2) {
void readEncoderR() {
int E = digitalRead(ENR);
if (E > 0) {
posR++;
else {
posR--;
void readEncoderL() {
int E = digitalRead(ENL);
if (E > 0) {
posL++;
else {
posL--;
void Odometry() {
float distancePerCount = 2.08;
static int encoderRPosPrev = 0;
static int encoderLPosPrev = 0;
float SR = distancePerCount * (posR - encoderRPosPrev);
float SL = distancePerCount * (posL - encoderLPosPrev);
encoderRPosPrev = posR;
encoderLPosPrev = posL;
x += SR * cos(theta);
y += SL * sin(theta);
theta += (SR - SL) / wheelDistance;
meanDistance = (SL + SR) / 2;
posX = posX + meanDistance * cos (theta);
posY = posY + meanDistance * sin(theta);
deg = theta * (180 / PI);
Serial.print(" DEG : "); Serial.print(deg);
Serial.print(" X : "); Serial.print(posX);
Serial.print(" Y : "); Serial.print(posY);
