i replaced a call to Encoder() with a call to a function, analyze() (see comments), that assumes the path is a constant radius and attempts to determine the radius and # of degrees traveled
while this may fairly accurate estimate the position and angle of the 'bot after each iteration, i'm doubt it's accurate enough to accurately determine the final position
800 TicPerRot
2 WheelDia
127.3 TicPerIn
24 Rad
163.4 CircOuter
138.2 CircInner
a 0, L 0, R 0 - 0.0000 fracCirc 0.0 dAngle -nan rad
a 15, L 866, R 733 - 0.0416 fracCirc 15.0 dAngle 24.0 rad
a 30, L 1733, R 1466 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 45, L 2600, R 2199 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 60, L 3466, R 2933 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 75, L 4333, R 3666 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 90, L 5200, R 4399 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 105, L 6066, R 5133 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 120, L 6933, R 5866 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 135, L 7800, R 6599 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 150, L 8666, R 7333 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 165, L 9533, R 8066 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 180, L 10400, R 8799 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 195, L 11266, R 9533 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 210, L 12133, R 10266 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 225, L 13000, R 10999 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 240, L 13866, R 11733 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 255, L 14733, R 12466 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 270, L 15600, R 13199 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 285, L 16466, R 13933 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 300, L 17333, R 14666 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 315, L 18200, R 15399 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 330, L 19066, R 16133 - 0.0413 fracCirc 14.9 dAngle 24.2 rad
a 345, L 19933, R 16866 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
a 360, L 20800, R 17599 - 0.0419 fracCirc 15.1 dAngle 23.9 rad
#include <stdio.h>
#include <math.h>
#define abs(a) (0 < a ? a : -a)
struct Encoder {
float _tics;
Encoder (int a, int b) { }
void set (float tics) { _tics = tics; }
int read (void) { return _tics; }
struct Serial {
void begin (int ) { }
void print (const char *s) { printf ("%s", s); }
void print (int i) { printf ("%d", i); }
void println (int i) { printf ("%d\n", i); }
} Serial;
unsigned long millis (void) {
static unsigned long msec;
return msec += 10;
Encoder Left(3, 2);
Encoder Right(11, 10);
float R = 385; //mm
float r = 12.5;
float L = 8;
double LeftDist = 0;
long LOldPos = -999;
float LNewPos;
int Correction;
double RightDist = 0;
long ROldPos = -999;
float RNewPos;
int fi = 0;
unsigned long t;
int Xt = 0;
int Xtb = 0;
int Yt = 0;
int Ytb = 0;
int fit = 0;
int fitb = 0;
int Vicc;
t = millis();
//0.9mm/1 deg
void Encoders() {
LNewPos = Left.read();
if (LNewPos != LOldPos) {
LOldPos = LNewPos;
LeftDist = ((LNewPos / 840) * (2 * r * 3.14)) / 10; //MM / Rev
RNewPos = Right.read();
if (RNewPos != ROldPos) {
ROldPos = RNewPos;
RightDist = ((RNewPos / 840) * (2 * r * 3.14)) / 10; //MM / Rev
fi = (abs(RightDist - LeftDist) * 0.9) - Correction;
if (fi >= 360)
Correction += 360;
else if (fi <= -360)
Correction -= 360;
Encoders();
if ((millis() - t) >= 100) {
Xt = Xtb;
Yt = Ytb;
fit = fitb;
Vicc = (L * (LeftDist / (RightDist / LeftDist))) + 0.5;
Xtb = Xt + (Vicc * (sin(fit + fi) - sin (fit)));
Ytb = Yt + (Vicc * (cos(fit) - cos(fit + fi)));
fitb = fit + fi;
t = millis();
Serial.print(Vicc);
Serial.print(" ");
Serial.print(Xtb);
Serial.print(" ");
Serial.println(Ytb);
const int TicPerRot = 800;
const int WheelDia = 2; // inches
const float TicPerIn = TicPerRot / (M_PI * WheelDia);
const int Rad = 24; // inches
const float CircOuter = M_TWOPI * (Rad + 2); // in.
const float CircInner = M_TWOPI * (Rad - 2); // in.
dL = circL * k = TwoPi * TicPerIn * fracCirc * (rad + 2)
dR = circR * k = TwoPi * TicPerIn * fracCirc * (rad - 2)
dL - dR = TwoPi * TicPerIn * fracCirc * 4
fracCirc = (dL - dR) / (TwoPi * TicPerIn * 4)
dL + dR = TwoPi * TicPerIn * fracCirc * ((rad + 2) - (rad - 2))
dL + dR = TwoPi * TicPerIn * fracCirc * 2 * rad
rad = (dL + dR) / (TwoPi * TicPerIn * fracCirc * 2)
dist = (dL + dR) / 2
int posL;
int posR;
void
analyze (void)
int pos = Left.read ();
int dL = pos - posL;
posL = pos;
pos = Right.read ();
int dR = pos - posR;
posR = pos;
float fracCirc = (dL - dR) / (M_TWOPI * TicPerIn * 4);
float rad = (dL + dR) / (M_TWOPI * TicPerIn * fracCirc * 2);
printf (" %6.4f fracCirc", fracCirc);
printf (" %6.1f dAngle", fracCirc * 360);
printf (" %6.1f rad", rad);
printf ("\n");
int
main ()
printf (" %6d TicPerRot\n", TicPerRot);
printf (" %6d WheelDia\n", WheelDia);
printf (" %6.1f TicPerIn\n", TicPerIn);
printf (" %6d Rad\n", Rad);
printf (" %6.1f CircOuter\n", CircOuter);
printf (" %6.1f CircInner\n", CircInner);
int dA = 15;
for (int a = 0; a <= 360; a += dA) {
Left.set (TicPerIn * CircOuter * a / 360);
Right.set (TicPerIn * CircInner * a / 360);
printf (" a %3d", a);
printf (", L %5d", Left.read ());
printf (", R %5d - ", Right.read ());
#if 0
loop ();
#else
analyze ();
#endif
return 0;
