Inverse of Mosfet
Hello everyone,
I need inverse of the attached circuit...means when I switch on led become off as soon as switch off led become on. LED should be on drain side as attached circuit shows. pls help me.
Translation:
when I turn switch on , led turns OFF.
when I turn switch off, led turns ON.
Pretty obvious you need to replace the P-channel mosfet with an N-CHANNEL one and move the led.
Add another PNP transistor before the NPN, so when you drive the base low it pulls up the gate
Note that using a P-type MOSFET on the high side is making life harder for yourself. If you use an N-type mosfet on the low side of the load (source to Gnd, drain to - side of LED) and use a logic level MOSFET, you could get the behavior you have now without the transistor, and get the inverted behavior with just one transistor instead of two... (oh, and N-channel MOSFETs have better performance at a given price point than P-channel ones - easier to manufacture)
What limits the LED current when it is on?
Good question I missed that one (-5 points)
...and circuit seems to use different grounds!
Ciao, Ale.
ilguargua:
Ciao, Ale.
Doesn't look like it to me - there are two ground connections drawn, but both connect to an identical ground symbol, indicating connection to a shared ground rail.
Yeah, most circuit diagrams don't draw lines between grounds, just terminate in the same symbol. Took me awhile to figure that one out. >:(
Yes, could be, maybe it's only bad drawn, I known that same symbol means same potential, but in this case a straight line could be better, at least for me.
Ciao, Ale.
DrAzzy:
Could you explain how do i connect those transistors?
thanks for all of you
I changed the circuit and add a 10k resistor at collector side of transistor. circuit is working good.
szacpp:
Why all that just to control an LED?
We never got any specs on the led but I would guess it is either very large or is a strip which draws a lot more than the usual 20 mA.
raschemmel:
Only the Shadow knows.
Because it is a class assignment he has been asked to do to prove he understands circuits. Which I will leave you to guess if he does.
Well if that's true and all he did was follow our advice what does that prove ?
It proves that education today is sadly lagging behind the reality of a students life and cheating is rife.
