IoT air quality checker device never connects to iot cloud
I've never done electronics and wanted to give it a try. So, I got the /iot-air-quality-checker-bundle and then followed the step-by-step guide exactly.
Device works great except that it does not connect to the IoT Cloud. Under devices, its always listed as "offline". I've followed the troubleshooting guide and deleted/ re-associated the device and thing multiple times.
Code is identical to code in the step-by-step guide (except for the thingID and network details)
Any advice on how to debug this would be appreciated!
Hello!
Did you check the serial monitor output? Did it print the message "Connected to IoT Cloud"?
It does not print that message:
/usr/local/bin/arduino-cli compile --fqbn arduino:samd:mkrwifi1010 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/715886876/build --build-path /tmp/arduino-build-13951A6ACF283DF34A23A17E902E0080 --library /home/builder/opt/libraries/arduinoiotcloud_1_6_1 /tmp/715886876/airQualityCheck_jul06a
Sketch uses 106872 bytes (40%) of program storage space. Maximum is 262144 bytes.
Global variables use 5920 bytes (18%) of dynamic memory, leaving 26848 bytes for local variables. Maximum is 32768 bytes.
Upload started
Programming with: Serial
Restarting in bootloader mode
Flashing with command:/home/kapa/.arduino-create/arduino/bossac/1.7.0-arduino3/bossac -i -d --port=ttyACM0 -U true -i -e -w -v /tmp/arduino-create-agent997347942/airQualityCheck_jul06a.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0
BOD : false
BOR : false
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.851 seconds
Write 106880 bytes to flash (1670 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[= ] 3% (64/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[== ] 7% (128/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[=== ] 11% (192/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x1000)
[==== ] 15% (256/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x6000, size=0x1000)
[===== ] 19% (320/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x7000, size=0x1000)
[====== ] 22% (384/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x8000, size=0x1000)
[======== ] 26% (448/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x9000, size=0x1000)
[========= ] 30% (512/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xa000, size=0x1000)
[========== ] 34% (576/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xb000, size=0x1000)
[=========== ] 38% (640/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xc000, size=0x1000)
[============ ] 42% (704/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xd000, size=0x1000)
[============= ] 45% (768/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xe000, size=0x1000)
[============== ] 49% (832/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xf000, size=0x1000)
[================ ] 53% (896/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x10000, size=0x1000)
[================= ] 57% (960/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x11000, size=0x1000)
[================== ] 61% (1024/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x12000, size=0x1000)
[=================== ] 65% (1088/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x13000, size=0x1000)
[==================== ] 68% (1152/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x14000, size=0x1000)
[===================== ] 72% (1216/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x15000, size=0x1000)
[====================== ] 76% (1280/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x16000, size=0x1000)
[======================== ] 80% (1344/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x17000, size=0x1000)
[========================= ] 84% (1408/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x18000, size=0x1000)
[========================== ] 88% (1472/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x19000, size=0x1000)
[=========================== ] 91% (1536/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x1a000, size=0x1000)
[============================ ] 95% (1600/1670 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x1b000, size=0x1000)
[============================= ] 99% (1664/1670 pages)write(addr=0x20005000,size=0x180)
writeBuffer(scr_addr=0x20005000, dst_addr=0x1c000, size=0x180)
[==============================] 100% (1670/1670 pages)
done in 0.696 seconds
Verify 106880 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 21e5
checksumBuffer(start_addr=0x3000, size=0x1000) = a0b4
checksumBuffer(start_addr=0x4000, size=0x1000) = d4f2
checksumBuffer(start_addr=0x5000, size=0x1000) = a1c6
checksumBuffer(start_addr=0x6000, size=0x1000) = 5514
checksumBuffer(start_addr=0x7000, size=0x1000) = 8ef6
checksumBuffer(start_addr=0x8000, size=0x1000) = 90fd
checksumBuffer(start_addr=0x9000, size=0x1000) = 5919
checksumBuffer(start_addr=0xa000, size=0x1000) = 3e85
checksumBuffer(start_addr=0xb000, size=0x1000) = d921
checksumBuffer(start_addr=0xc000, size=0x1000) = 3ea4
checksumBuffer(start_addr=0xd000, size=0x1000) = a7cb
checksumBuffer(start_addr=0xe000, size=0x1000) = f05c
checksumBuffer(start_addr=0xf000, size=0x1000) = dcbb
checksumBuffer(start_addr=0x10000, size=0x1000) = a3cb
checksumBuffer(start_addr=0x11000, size=0x1000) = a97f
checksumBuffer(start_addr=0x12000, size=0x1000) = 81f
checksumBuffer(start_addr=0x13000, size=0x1000) = ca8b
checksumBuffer(start_addr=0x14000, size=0x1000) = a4a8
checksumBuffer(start_addr=0x15000, size=0x1000) = 7803
checksumBuffer(start_addr=0x16000, size=0x1000) = 4f6d
checksumBuffer(start_addr=0x17000, size=0x1000) = a3a0
checksumBuffer(start_addr=0x18000, size=0x1000) = 285d
checksumBuffer(start_addr=0x19000, size=0x1000) = 6c13
checksumBuffer(start_addr=0x1a000, size=0x1000) = 73a
checksumBuffer(start_addr=0x1b000, size=0x1000) = eb75
checksumBuffer(start_addr=0x1c000, size=0x180) = 94a4
Verify successful
done in 0.091 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
This is not the serial monitor output, it's the compilation/upload output. Check here how to open it (see " 7. Editing the Sketch" section)
of course its something so basic.
device could not connect to the wifi. I retyped the name/password and this time I did this it fixed the issue. device connects and is writing to the dashboard. thanks @eclipse1985 !
Great! Glad to hear you solved your issue!
