IR diode laser
Hello.
I'm looking for infrared laser diodes that are small, cheap and low power (<5mW).
Some models to recommend?
With regard to its sensor, if i wanna reduce false readings (as there are several IR sources in the homes and offices) , could I insert the IR sensor into a black tube that looks in the direction of the laser?
Thank you
What do you want to do. Beam break, remote control, data, ?
Maybe easier to use narrow beam IR diodes.
Leo..
Wawa:
https://www.vishay.com/docs/84240/vsly5940.pdf
Leo..
I've a tiny robot wich will mount a ir receiver and that mustn't go beyond an imaginary line (so the line projected by the laser diode).
EXAMPLE
The IR led you posted is quite interesting as it can act a bit like a laser, having an angle of half intensity of 3°.
Because for my purposes i need a good straight line i thought about this one:
But i really appreciate the Led you posted because i need to work with tiny, tiny, electronicts as possible.
If my laser pointer is anything to go by, it's a really narrow beam and a pretty tiny overall device.
But what I don't understand: the laser is to act as barrier for the robot, so I expect it to be mounted somewhere not on the robot, and not too much of a space restraint there.
Using a visible light blocking filter to increase IR sensitivity in the presence of stray illumination
wvmarle:
The receiver will stay in the robot, not the laser emitter.
The robot move along a path in such a way the sensor looks against the transmitter.
For my purposes i need a small, small, scale diode laser. Don't know if an SMD manufactured IR laser diode exist :open_mouth:
MarkT:
Have common IR sensor inbuilt light filtering?
Such as the one used for proximity sensoring.
These are pretty small
http://www.mpja.com/Mini-LASER-Head-635nm-5mw/productinfo/19566+LZ
On sale too!
http://www.mpja.com/LASER-Diode-Red-Crosshair-Pattern/productinfo/33029+LZ
CrossRoads:
Pack of 5 - Mini LASER Head, 635nm, <5mw
On sale too!
Be careful friend, you posted red dot laser (650nm) not infrared (+- 750nm)
:wink:
