om1f
August 23, 2024, 5:02pm
1
Hello everyone. Today, I bought new IRFZ44N mosfet. I tried this mosfet. They worked. But when I solder this mosfet in 300 celcius degrees, my mosfet always close circuit with source and drain. I connect gate to gnd but still close circuit.
Can I fix it ot use for any circuit?
b707
August 23, 2024, 5:17pm
2
Please show your connection diagram.
How much experience of soldering do you have ?
Please post a clear 'photo of the MOSFET soldered in place in your project
om1f
August 23, 2024, 5:30pm
4
I didn't solder any wires. Only spread. I connected this mosfet to avometer to try
Which of those statements is correct ?
om1f
August 23, 2024, 5:33pm
6
I connecy two mosfets source in one
om1f
August 23, 2024, 5:36pm
9
Both of them, only a bit of soldering wire
It is the drains that you have connected together.
Why have you connected them together like that?
om1f
August 23, 2024, 5:42pm
11
I have four IRFZ44N I try connect to power supplys gnd to middle and they works
om1f
August 23, 2024, 5:46pm
12
And everyone will you help me or question me? I said "I test with avometer they didn't Work but other work"
The MOSFETS you have are N channel.
You have connected the drains together.
You wouldn't normally connect the drain of an N channel MOSFET to GND.
om1f
August 23, 2024, 5:53pm
14
I said I also test with a tester diode tester
om1f
August 23, 2024, 5:55pm
15
Please you Don't think other mosfet. I said my mosfet when I solder in 300 celcius, it broken
jim-p
August 23, 2024, 5:59pm
16
You are not supposed to solder the TAB parts together, only the pins.
You can use a screw and nut to hold the MOSFET tabs together.
If you connect them like that, how will you attach a heatsink?
om1f
August 23, 2024, 6:07pm
19
I try make my own motor driver
om1f
August 23, 2024, 6:09pm
20
It was a temporary situation for a few hours due to high heating. I would also like to thank some of you for questioning me and not focusing on the solution. Thanks @JohnLincoln @UKHeliBob @jim-p @b707
