IRreciver_cant_get
Hi
trying to operate with remote control to switch on blynk.
used that code
#include <IRremote.h>
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
  irrecv.enableIRIn();
  irrecv.blink13(true);
void loop(){
  if (irrecv.decode(&results)){
        Serial.println(results.value, HEX);
        irrecv.resume();
but when it comes to pressing any button I get FFFFFFFF code whatever button I press no matter how long either one time either for couple secs. Don't understand why can't I get normal code of each button?
Please help
Thanks so far.
I have moved your topic to Sensors....I don't think the topic was relevant to Emergency Response: Remote Learning.
Can you please give this demo sketch ago?
#include <IRremote.hpp> // include the library
    // Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
    IrReceiver.begin(2, ENABLE_LED_FEEDBACK);
    Serial.print(F("Ready to receive IR signals of protocols: "));
    printActiveIRProtocols(&Serial);
    Serial.println(F("at pin " STR(IR_RECEIVE_PIN)));
     * Check if received data is available and if yes, try to decode it.
     * Decoded result is in the IrReceiver.decodedIRData structure.
     * E.g. command is in IrReceiver.decodedIRData.command
     * address is in command is in IrReceiver.decodedIRData.address
     * and up to 32 bit raw data in IrReceiver.decodedIRData.decodedRawData
    if (IrReceiver.decode()) {
         * Print a short summary of received data
        IrReceiver.printIRResultShort(&Serial);
        IrReceiver.printIRSendUsage(&Serial);
        if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
            Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
            // We have an unknown protocol here, print more info
            IrReceiver.printIRResultRawFormatted(&Serial, true);
         * !!!Important!!! Enable receiving of the next value,
         * since receiving has stopped after the end of the current received data packet.
        IrReceiver.resume(); // Enable receiving of the next value
         * Finally, check the received data and perform actions according to the received command
        if (IrReceiver.decodedIRData.command == 0x10) {
            // do something
        } else if (IrReceiver.decodedIRData.command == 0x11) {
            // do something else
Your code work OK @ simulator.
