IRremote library
Does anybody know other libraru to take control to infrared remote system without using the typical library Arduino-IRremote-master, I have been trying to use it but it keeps giving me error, It's because there is a conflict between some libraries, I have removed them accordding to some post I have read with the same trouble, but It has been useless.
I would like to use my kit but i think I should need other library, I use Arduino 1.0.6 IDE.
Thanks!!
I ended up replacing the library with one that I downloaded from the web at GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols.
The IRRemote library that came included in the Arduino 1.6.4 would not allow any sketch that included IRremote.h to compile.
To resolve the issue, I simply moved the original library folder titled "RobotIRremote" stored at
C:\Program Files\Arduino\libraries to a folder elsewhere, and replaced it with the "IRremote" library I downloaded from GitHub.
I don't honestly know if the library will work with IDE 1.0.6, though. Is there a reason you can't update to the latest release of the Arduino IDE?
What remote are you using and what IR receiver?
Adafruit has a library.
I wrote this one for NEC.
http://forum.arduino.cc/index.php?topic=317625.0
