Is an amplifier needed for MP3 Player Module Dfplayer and which memory card is suitable
Hi!
I have 2 questions:
Question 1:
Is it possible to connect speakers to the following common module directly (amplifier built into the hardware) or should an external amplifier be used?
I ask because I see conflicting things online. Sometimes I see the use of an external amplifier and sometimes not.
Here for example with:
Whereas here the connection is direct without an amplifier:
Question 2:
I don't quite understand which memory cards are suitable for this module? There are important details to check when buying these cards - will every micro card work?
And - is an adapter needed for this card?
I would appreciate it if someone could send a link to AliExpress of a memory card that can fit this module:
https://www.aliexpress.us/item/3256804593776610.html?gatewayAdapt=glo2usa&_randl_shipto=US
What does the documentation for the unknown hardware say?
The DFPlayer can drive one mono speaker or it has stereo line outputs if you want to use an amplifier (or stereo and/or more power).
That link also has some information about formatting the Micro SDcard.
PAM8403 filterless 3W class-D stereo audio amplifier.
So difficult to find the answer to your question. First hit on Google shows: "Dual-channel stereo, 5V power supply can output 3W + 3W power, can directly drive small 4Ω and 8Ω speakers with high power and good sound quality. ".
Your question actually started with the title you gave to this thread, and about some unknown MP3 player.
Thanks!
Regarding this question of mine? I didn't find a clue here and I'm not that knowledgeable about the size of memory cards
