Sorry for asking a simple electronic question but I'm a newbie in electronics.
I am currently using Arduino UNO and L293D motor driver to drive 2 DC motors.
The Arduino UNO is powered by the USB port of my computer and the 2 DC motors are powered by a single 9V battery.
I am going to make my project mobile so I cannot use the USB cable as power supply anymore. Would it be okay to connect like the below image? Any disadvantages?
The problem with the 9v battery is the low capacity. This means that it is not able to supply sufficient current or won't last long.
What to use depends on what you actually want to do with the project. 9v made up of AA cells will work. Make sure you power the Arduino via the Vin if you use 9v or more. If you use 12v, it is better to drop it to 5v via a switch mode regulator. Or drop it to 7v and feed it into the Vin.
samcheng92:
What are the good way to power the Arduino and the motors?
Start with a battery suitable for the motors - a LiPo rechargeable - with the correct charger. If the motors operate at 9V, then perhaps a 3-cell battery.
This will provide enough voltage to power the regulator of the Arduino.
If on the other hand, you are only going to use two LiPo cells, then you need a 5V buck-boost regulator to power the Arduino from them at its "5 V" terminal, or use a separate battery such as 3 "AA" alkaline cells.
If the motors really are lightweight, then you might use a pack of "AA" alkalines according to the motor voltage and a separate pack as before, to power the Arduino.
I won't comment on whether the L293D is suitable for driving motors from batteries.
If i use 6 x AA cells, can i just replace the 9V battery as in the diagram to power both the Arduino and the motors? Or I have to power them using separate batteries?
I recently learned Fritzing has a schematic section. In the future, post from the generated schematic and it will make it easier for others to see how things are connected.
Alkaline batteries don't generally supply as much current as a good rechargeable battery. NiMH or LiPo cells are often good batteries for these sorts of projects.
Hi guys, I have decided to use a battery holder with 6 x 1.5 AA cells as it is easy to get.
Just one more question:
Should I use the 6 x 1.5 AA to power the Arduino and a 9V battery to power the two motors
OR
Use the 6 x 1.5 AA to power both the Arduino and the two motors?
