I am trying to use an Arduino UNO, an L298N, and 6 AA batteries to power 2 9.0V DC motors from OSEPP. I at first thought the motors were 5 volts so I was confused why it wasn't working but now that I know they're 9 volts it makes a little bit more sense. The reason I'm confused is that the robot is from an OSEPP kit so why would they package it with 2 9V motors and a battery pack that only provides 7.2 volts? Also, before I try getting more voltage, can the L298N motor driver even supply enough power to get both motors running at top speed?
This is the closest thing I could find to the motors I'm using: https://www.insplay.eu/en_US/shop/product/95052-a-set-of-motors-with-25mm-9v-185rpm-optical-encoders-3339#slogan
The L298 is an extremely inefficient dinosaur.
Use a modern motor driver to get full power to the motors. Pololu has the best selection .
Do you think there is anything weird about the motors or is the driver the only problem?
You haven't told us anything about the motors, other than they resemble some other motors.
To choose the appropriate motor driver you need to know the start/stall current, which is typically about 10X the free running (no load) current.
xfpd
April 10, 2025, 12:27am
5
You will need 9vdc at the output of the L298N, and some substantial current, probably.
6 batteries x 1.5vdc/battery = 9vdc
The L298N drops (consumes) 1.5vdc from 9vdc leaves your two 9vdc motors with only 7.5vdc
Much worse than that.
The L298N internally drops 3 to 5V at high load, so it can waste around half the battery voltage, powered by 9V.
From the L298N data sheet:
Note that even this is deceptive. With steady state current draw just over 1 A, the L298N starts to heat up and shut down.
They look similar but they also share specs. The motor I have says this: "25MM DC MOTOR DC 9.0V 185RPM+/-10% Gear Ratio 1:45"
So the problem is that I don't have enough voltage, and it's because of the motor driver, not the batteries or the motors?
Which one would you recommend? Or how should I choose one?
To make an informed choice more information is required. However I imagine that this Pololu driver would handle one of those motors
jim-p
April 10, 2025, 8:18am
11
I would do some troubleshooting before you spend more money on something that also may not work.
Many people have successfully used the L298 driver with toy robots.
FYI: 6 AA = 9V
1lab123_official:
The L298N can drive 9V motors but isn't very efficient, and the 7.2V battery may not provide enough power. A 9V or 12V battery could help. Have you thought about using a more efficient motor driver like a MOSFET-based one?
