Hi, I want to make an ir controller to control things like tv's, projectors, led lights etc but I cant find any information how would I even start.
hi @jorgos234 welcome to the forum.
I assume you know about google. Here's a pro tip: everything you can possibly think of doing with an Arduino has already been done, so adding arduino to even the vaguest search for something will turn up many examples
arduino ir remote
or
arduino lawn mower
Of course you will see some very questionable and even dangerously bad designs and software, but it will help get the lag of the land to poke around a bit.
a7
I have an project about this situation yes its possible. You can check this video detailed https://youtu.be/OB4jAc2033o?t=18m2s also you can make your project less cost with attiny 85. But you have to search that mcu a little bit. Also I strongly recommend to you use Arduino IDE version of 1.8.13. This IR libraries are works perfectly this versions. Every project dont forget to control IDE versions. Version iş everything for Arduino projects
The DroneBotWorkshop has a revised IR Remote page, including revised video, which should answer all your questions, even the ones you have not thought of yet.
