I recently made it possible to blow-on a regular M09 bulb with the help of Grove Temperature & Humidity Sensor. But this time remotely turning it on/off will be a major issue... in a distance of less than 1m. Do you think it's feasible? And any clues?
++ so previously I set the tolerance value for the temperature and humidity value on the sensor which determines HIGH/LOW status of the light so that if one blows at the sensor causing input value change the light can be turned on. And by remotely turning it on/off I mean: cordlessly sending data collected from the sensor (closely connected to arduino) to the light bulb, which will be 1 meter apart, to make it turned on or off.
Thanks
Processors read inputs and based on those set outputs so on the face of it the answer to your quastion is yes. However read your question, it really does not make any sense to anybody except perhaps you.
You need to explain exactly what you have done and what you want to do, forum members are not mind readers.
ardly:
Sorry I am kinda newb here and it shows.. Is it any clearer?
Daz1712:
Do you mean you blow on the sensor and the light is 1 meter away or the sensor is 1 meter away?
Daz
The former! The sensor will be right beside arduino all the time but I would like to cordlessly control the status of the light with the input data from this combi.
