Thank you Gentlemen,
Paul,
I can drive a simple 12v motor, controlled remotely by a 2.4 Gig radio system, at varying rpms, via PWM.
The whole project is a RC controlled rowing boat.The motor can run on 14.4 v NiMh batteries, the Uno on 9v.
Robin,
there are heaps of gearhead motors on the market, but what I have found by looking at the specs of individual motors is that the start-up amperage can be up to 10 amps. This would turn my battery pack inside out, suck it dry, and spit out the remains in a cloud of smoke!
Dave,
My Nema 17 is the top end (90.2 oz\in). When it is running loaded, it skips steps, NOT a good sign!
It's taken about 2 years to get to this stage, I don't intend giving up just because some stupid motor won't do what I want it to do!
Rupert,
Within each revolution, the motor runs slowly, ramping up to fast, then back to slowly. Finally, the ramping rate will be decided largely by trial and error, and what is possible.
It has to revolve 30 (max) times a minute.
Overall, the RC controls the 30 RPM stage.
I have looked at dc gearhead motors with encoders on the motor shaft, but these gearhead reductions are quoted to be 40:1, 500:1, etc, in reality they are 40.? ? ? ??:1, 500.? ? ? ?:1, They do this to reduce the wear on the teeth in the gearbox. It also means that if you tell the motor to do (say) 500 revolutions, the out-put shaft will do 1.? ? ? ? revolutions. Over a period of time, the out-put shaft, and therefore the whole mechanism will be out of sync, and the mechanism, the way it has to be designed, will have a massive heart attack.
I know, been there, done that.
That is the state of play at the moment, I will continue to research motors, encoder systems, programming issues etc,
Any pointers would be greatly appreciated.
Mick
ps: aarg, Ford Prefect hitchhiked, can you bring back a GargleBlaster for me please.
