Is there a possibility of that using closed loop stepper motors and drivers in 3d printer?
If any of my axis have two stepper motors, I will connect them parallel. Is same possible with closed loop steppers, since they have encoders attached?
Modbus RS485 Stepper Driver 0.5-5.6A 24-48VDC Fit Nema 17, Nema 23, Nema 24 Stepper Motor
https://www.oyostepper.com/goods-985-Modbus-RS485-Stepper-Driver-05-56A-24-48VDC-Fit-Nema-17-23-24-Stepper-Motor.html
DMRS Series are stepper driver based on standard Modbus RTU protocol, using RS485 communication can network up to 31 axes.
I moved your topic to an appropriate forum category @linain23.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Connect steppers in parallell? You should not do it electrically. They will not share the current equally and one will get too much current.
Why use 2 closed loop steppers on the same axis? It doessn't make sense.
No you can't parallel the motors, you would need to use one driver per motor and step them together.
