I am looking for a sensor with the help of which I can track and trace the x-y coordinate of the object I mount the sensor on. My scenario is just like a mouse. A mouse when moved makes the cursor move and I assume there is x-y coordinate tracking going on. Is there any such sensor that I can do a PoC with Arduino UNO board?
A PC mouse uses either an optical movement sensor or encoders (in older models). Both of those basic sensors could be used in your Arduino project.
Or dismantle an old USB mouse and capture the USB signal produced... i.e. mount you object on a mouse...
A mouse does not track x and y. It measures the distance it travels in x and y direction.
Important difference is that errors will accumulate. So to get reliable xy coordinates you will need regular calibration. For example a calibration each time your object hits some border or crosses some line.
True xy coordinates would need measurement of x and y compared to two fixed points with known x and y.
So it will depend on your needs if mouse like approach can work for you.
Thanks for replying. Essentially i wanted to design a stylus where i can write something on a board and it would be replicated in a whiteboard in laptop. Its very similar to an optical stylus. I may be wrong to consider only optical stylus because I was reading that mPU6050 may also help tracing sketching movement that i need from a stylus
This mPU6050 will measure acceleration. To derive distance, you would need to integrate.
Problem is that you do not know the integration constant (velocity in x and y direction at t=0).
Also you may get an ever increasing error due to integral windup. What happens if you rotate your object?
Clever programming may help to get around these issues. I never tried...
Did you find a library?
Does any stylus work the same way (with an accelerometer)? That would prove that this approach is doable.
I know about stylus things that work with a sensitive pad (where the pad gives x and y when the stylus hits the pad).
Edit: you need to integrate twice..
Acceleration -> velocity->position
Then you have 2 unknown integration constants...
Could the "board" be a touch screen which detects the x,y of the stylus or finger? Every phone and tablet has touch screen. If the board is completely passive (for example, a sheet of wood), this problem is much harder.
The board is completely passive, which is why I am thinking of a optical stylus kind of thing
You mean a graphics tablet?
https://www.scorptec.com.au/product/tablets/graphics-tablets?page=1
Tom...
@prc89 hey , did you find some solution . Actually i am also trying to do a similar thing but stucked at this point .
