Is this PNP transistor in my MIDI IN correct?
I thought i was saying that, but your explanation is probably more clear. Moreover, it was designed by people that had to put warrantee on the equipment they'd sell.
A very good point.
I am not following this thread closely because a lot of nonsense was posted here (what a shame with such simple circuit). As I understand the schematic it shows output of one device connected to the input of some other device - connected at points marked by (blue) 4 and 5:
So left hand part of the schematic is output, right hand part is input and the diode is in the right place to protect LED in H11L1 from ESD.
OK, I have clearly misinterpreted the meaning of the circuit.
So it appears now.
This is not really an circuit on its own, but nothing more than a concept diagram to analyse the voltages involved.
So ...
In an actual MIDI interface, the diode is present to protect against (mis-)connection to a Midi interface which operates at more than 5 V, the rated voltage of the opto-isolator.
No, just reverse application of a voltage in excess of 6 V. :face_with_raised_eyebrow:
I shall just quietly go away now ... :pleading_face:
No it is a full circuit, but the bits that are numbered 4 & 5 represent the plug and socket joining the transmitter to the receiver. To the right of these numbers is the MIDI receiver and the the left is the MIDI transmitter.
So those dots by the numbers signify a cable, which could be miss wired.
Those haven't appeared in my studio so far, but with USB-C the future may hold surprises. But that does make sense though. So to prevent damage from an incompatible device that is connected in reverse. Those guys though of everything.
